| Using FormAttachment in FormLayout [message #89281] |
Mon, 02 May 2005 23:51  |
------=_NextPart_000_0102_01C54F58.AA4CE690
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Problem: How to create a FormAttachment using VE.
Eclipse 3.0.1
org.eclipse.ve 1.0.2.1
org.eclipse.emf 2.0.1
org.eclipse.gef 3.0.1=20
I used the Visual Class wizard to create a subclass of Composite called =
MyComposite.
I then used a FormLayout manager for MyComposite.
I created a FormData bean using Choose Bean.
At this point, I am unclear how to create a FormAttachment using VE.
Moreover, the FormData instance does not let me add a value to
its top, bottom, left, and right.
The "Using the Visual Editor for Java" help does not appear to provide =
any specifics.
I appreciate any feedback.
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2900.2627" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>Problem: How to create a FormAttachment =
using=20
VE.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Eclipse 3.0.1</FONT></DIV>
<DIV><FONT face=3DArial =
size=3D2> org.eclipse.ve &n bsp;=20
1.0.2.1</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>org.eclipse.emf =20
2.0.1</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>org.eclipse.gef =
3.0.1 </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I used the Visual Class wizard to =
create a subclass=20
of Composite called MyComposite.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I then used a FormLayout manager =
for=20
<DIV><FONT face=3DArial size=3D2>I created a FormData bean using Choose=20
Bean.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>At this point, I am unclear how to =
create a=20
FormAttachment using VE.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Moreover, the FormData instance does =
not let me add=20
a value to</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>its top, bottom, left, and =
right.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>The "Using the Visual Editor for Java" =
help does=20
not appear to provide any specifics.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I appreciate any=20
feedback.</FONT></DIV></BODY></HTML>
------=_NextPart_000_0102_01C54F58.AA4CE690--
| Re: Using FormAttachment in FormLayout [message #89505 is a reply to message #89490] |
Tue, 03 May 2005 14:23  |
------=_NextPart_000_002D_01C54FD2.996E0D20
Jeff
Thank you for the clarification.
John
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2></FONT><FONT face=3DArial =
size=3D2>Jeff</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Thank you for the =
clarification.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>John</FONT></DIV></BODY></HTML>
------=_NextPart_000_002D_01C54FD2.996E0D20--
| Re: Using FormAttachment in FormLayout [message #607314 is a reply to message #89281] |
Tue, 03 May 2005 09:01  |
John,
The VE currently doesn't have design time support for creating
containers using FormLayout. This feature is on the plan for a future
release of the VE. Perhaps you can use GridLayout in the meantime?
Hope this helps,
- Jeff
> Eclipse 3.0.1
> MyComposite.
> any specifics.
| Re: Using FormAttachment in FormLayout [message #607321 is a reply to message #89371] |
Tue, 03 May 2005 12:44  |
------=_NextPart_000_0009_01C54FC4.A73463E0
Jeff
I appreciate your feedback.
Is there a recommendation for how to manually write our code so
that when FormLayout is supported by VE, VE will
recognize our manual coding.
By the way, I did not find any mention of the fact that
VE does not support FormLayout in the VE FAQ or elsewhere.
Was it hiding somewhere on the VE website?
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>Jeff</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I appreciate your =
<DIV><FONT face=3DArial size=3D2>Is there a recommendation for how to =
manually write=20
our code so</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>that when FormLayout is supported by =
VE, VE=20
will</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>recognize our manual =
coding.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>By the way, I did not find any mention =
of the fact=20
that</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>VE does not </FONT><FONT face=3DArial =
size=3D2>support=20
FormLayout in the VE FAQ or elsewhere.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Was it hiding somewhere on the VE=20
website?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT><FONT face=3DArial=20
size=3D2></FONT> </DIV></BODY></HTML>
------=_NextPart_000_0009_01C54FC4.A73463E0--
| Re: Using FormAttachment in FormLayout [message #607322 is a reply to message #89476] |
Tue, 03 May 2005 12:57  |
John, see the help VE help within Eclipse, topic: Editing Java in the
Visual Editor->Developing Java Classes with the Visual Editor->Laying
out components->SWT Layout Managers.
Unfortuately the source code pattern for using the FormLayout in the VE
hasn't been specified yet, so it'd be hard to code against it. We're
looking for help from the community in designing this feature (what the
UI feedback will be like and the code pattern used) so any feedback or
ideas would be helpful. You can participate in the discussion here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=77683
Hope this helps,
- Jeff
John wrote:
> Jeff
| Re: Using FormAttachment in FormLayout [message #607323 is a reply to message #89490] |
Jeff
John
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV> </DIV>
FUDForum. Page generated in 0.05321 seconds
