Home » Archived » Visual Editor (VE) » Icons on the custom widgets in VE are not visible
Icons on the custom widgets in VE are not visible [message #87874] Wed, 20 April 2005 11:59 Go to next message
I have my own custom widget: panel with a button; the button has an icon
on it.
If I test my component with "Run |Java Application" I can see the icon.
If I drop my component from the palette in VE in the debug mode my icon is
not visible.
What can I do to make my icon visible ? Do I have to set some paths ?
Thank you :-)
Elena
Re: Icons on the custom widgets in VE are not visible [message #87888 is a reply to message #87874] Wed, 20 April 2005 13:52 Go to previous messageGo to next message
What does the code look like that sets icon on the button? In what
method is this code called from?
Elena wrote:
> Hello,
> on it.
> is not visible.
> Thank you :-)
> Elena
Rich Kulp
Re: Icons on the custom widgets in VE are not visible [message #87961 is a reply to message #87888] Thu, 21 April 2005 02:40 Go to previous messageGo to next message
here is the code below. I hope that the formatting is ok. You can see that
my "plusMinusButton" has an icon. And the icon is in a folder "icons" in
my plugin-project.
Elena
public class ButtonPlusPanel extends JPanel
public ButtonPlusPanel()
super();
public ButtonPlusPanel(ActionListener controller, String actionCommand,
String[] resourceNames, String[] resourceKeys, String[] imageNames)
super();
ButtonPanel buttonPanel = new ButtonPanel(controller, resourceNames,
resourceKeys, imageNames, 6, 1, 1);
JButton plusMinusButton = new JButton(new
ImageIcon("icons/Close_Button.gif"));
this.add(buttonPanel);
this.add(plusMinusButton);
this.setVisible(true);
Re: Icons on the custom widgets in VE are not visible [message #88032 is a reply to message #87961] Thu, 21 April 2005 09:51 Go to previous message
When we drop a button we use the default ctor. Since the default ctor
doesn't call any of the code in the other ctor, the other code is never
executed.
Rich Kulp
Re: Icons on the custom widgets in VE are not visible [message #607195 is a reply to message #87874] Wed, 20 April 2005 13:52 Go to previous message
Elena wrote:
> Hello,
> on it.
> is not visible.
> Thank you :-)
> Elena
Rich Kulp
Re: Icons on the custom widgets in VE are not visible [message #607200 is a reply to message #87888] Thu, 21 April 2005 02:40 Go to previous message
my plugin-project.
Elena
super();
super();
Re: Icons on the custom widgets in VE are not visible [message #607205 is a reply to message #87961] Thu, 21 April 2005 09:51 Go to previous message
executed.
Rich Kulp
Previous Topic:About Creation of Table
Next Topic:SWT controls in palette not visible, only SWING and AWT?!?
Current Time: Thu Nov 06 13:15:08 EST 2025
Powered by FUDForum. Page generated in 0.05801 seconds
