| Code Generation [message #60718] |
Thu, 23 September 2004 18:00   |
Eclipse User  |
Originally posted by: stefan.baramov.trx.com
I am happy to see a support for SWT from the latest VE 1.0. However, I am
kind of disappointed with the generated code. For example:
 private void createComposite() {
  GridData gridData3 = new GridData();
  GridData gridData2 = new GridData();
  GridLayout gridLayout1 = new GridLayout();
  composite = new Composite(sShell, SWT.NONE);
  label = new Label(composite, SWT.NONE);
  text = new Text(composite, SWT.BORDER);
  button = new Button(composite, SWT.NONE);
  createComposite1();
  composite.setLayout(gridLayout1);  // Generated
  gridLayout1.numColumns = 3;  // Generated
  label.setText("Project :");  // Generated
  label.setLayoutData(gridData3);  // Generated
  button.setText("Browse...");  // Generated
  gridData2.horizontalAlignment = org.eclipse.swt.layout.GridData.FILL;  //
Generated
  gridData2.grabExcessHorizontalSpace = true;  // Generated
  text.setLayoutData(gridData2);  // Generated
  gridData3.horizontalAlignment = org.eclipse.swt.layout.GridData.END;  //
Generated
It is difficult to read and understand. This is not the case when the
generated code is Swing.
So are there any plans to imporve the code generation for SWT? If there are
any, then when ? May be VE 1.1 ?
Stefan
| Re: Code Generation [message #62344 is a reply to message #61516] |
Tue, 28 September 2004 12:24   |
Eclipse User  |
Originally posted by: mendelgili.netscape.net
Stefan Baramov wrote:
> Joe Winchester wrote:
>> We did at one point generate SWT code the way you describe with lots
>> of methods, however we then steered away from it and settled on the
>> one where each composite has a method.  This is controlled by a flag
>> that unfortunately isn't public, although one of the things we want to
>> work on it to open up the whole API for code generation with user
>> configurable styles and also ones where plugin developers can
>> customize the VE code generation.
> Apperantly, if I refactor my code in the desire pattern the VE still
> reconginize it and allows me to edit it. Works for me !
> - Stefan
There are two levels to the code pattern you suggested:
	1. a separate create method for each visual component (similar to the getter Swing version)
		VE can generate/reverse parse these methods as long as the method initializes/create a
		(single) instance.  At this point for SWT, the default behavior
		is to create a separate method for composites only - we can provide a pref. support to override this.
		However, the pattern that is mostly used with SWT is a factory method that mostly is called once
		(but not always). This method contains the initialization for all the "root" components.
		Our goal is to support factory methods.
	2. Better grouping of expressions within a method
		VE uses a rough weight base dependency rule when it determines where to insert a new expression...
		We can definitly do a better job there.
| Re: Code Generation [message #599115 is a reply to message #60718] |
Fri, 24 September 2004 05:32   |
Eclipse User  |
Hi Stefan,
Could you please rewrite by hand the generated code you included, but in
the way you'd like to see it have been created by the VE ?
Joe Winchester
| Re: Code Generation [message #599155 is a reply to message #60720] |
Fri, 24 September 2004 10:45   |
Eclipse User  |
Here is an example how to code could look like:
 // layout data
 // elements
 createLabel(composite);
 createText(composite);
 createButton(composite);
private void createLabel(Composite parent) {
 // layout data
 GridData gridData = new GridData();
 gridData.horizontalAlignment = org.eclipse.swt.layout.GridData.END;
 label.setLayoutData(gridData);
private void createText(Composite parent) {
 // layout data
private void createButton(Composite parent) {
Note: this is the same pattern used by the Swing version of the VE. All I am
saying is if the Swing VE can generate a good looking code, why can't the
SWT VE generate a good looking code?
- Stefan
| Re: Code Generation [message #599577 is a reply to message #60725] |
Mon, 27 September 2004 06:26   |
Eclipse User  |
Hi Stefan,
Thanks very much for your code examples.  We did at one point generate
SWT code the way you describe with lots of methods, however we then
steered away from it and settled on the one where each composite has a
method.  This is controlled by a flag that unfortunately isn't public,
although one of the things we want to work on it to open up the whole
API for code generation with user configurable styles and also ones
where plugin developers can customize the VE code generation.  One of
the things we also want to do is allow factory style generation where
the same method can be used multiple times which often occurs in SWT
where you have something like
private Button createButton(Composite parent, String text);
that creates the Button and sets its text and creates the correct
GridData constraint.
I'll check with the VE developers who are more knowledgeable in code gen
than me whether or not what you want with the style switch to do can be
done easily.
Joe
| Re: Code Generation [message #599637 is a reply to message #61330] |
Mon, 27 September 2004 09:54   |
Eclipse User  |
- Stefan
| Re: Code Generation [message #599904 is a reply to message #61516] |
Eclipse User  |
> - Stefan
FUDForum. Page generated in 0.05001 seconds
