Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [teneo] primary key in java code
| [teneo] primary key in java code [message #86229] |
Wed, 13 June 2007 12:44  |
This has likely been answered, but I can't seem to find it.
I am unsure how to set a primary key using annotations in the java source --
not in an external xml file. I tried something like this
* @model
public interface A {
* @model changeable="false"
@Id
String getUniqueName();
Then I create a genmodel/ecore model from the code, generate the model, and
the uniquename property doesn't end up as the primary key. It's set to
changeable="false" because I am creating the value from other data, and that
gets stored find in the database.
Paul
| Re: [teneo] primary key in java code [message #86244 is a reply to message #86229] |
Wed, 13 June 2007 13:58   |
Hi Paul,
Just for the id I would try the annotation id="true" in the java source. For other annotations: I
don't think that they will work, at least I don't think that eannotations can be specified in java
source. But maybe Ed can answer this question.
gr. Martin
> * @model
> @Id
> Paul
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: [teneo] primary key in java code [message #86274 is a reply to message #86244] |
Wed, 13 June 2007 14:36   |
do you mean by using @model id="true", or something else?
"Martin Taal" <mtaal@elver.org> wrote in message
news:f4pb7n$eaj$1@build.eclipse.org...
> Hi Paul,
> For other annotations: I don't think that they will work, at least I don't
> think that eannotations can be specified in java source. But maybe Ed can
> gr. Martin
>> source -- not in an external xml file. I tried something like this
>> * @model
>> @Id
>> and the uniquename property doesn't end up as the primary key. It's set
>> to changeable="false" because I am creating the value from other data,
>> and that gets stored find in the database.
>> Thanks,
>> Paul
> The Netherlands
| Re: [teneo] primary key in java code [message #86289 is a reply to message #86274] |
Wed, 13 June 2007 14:44   |
Yes, that's what I mean.
gr. Martin
>> Hi Paul,
>> gr. Martin
>>> * @model
>>> @Id
>>> Thanks,
>>> Paul
>> The Netherlands
The Netherlands
| Re: [teneo] primary key in java code [message #86320 is a reply to message #86244] |
Wed, 13 June 2007 15:02   |
It's working. I set @model id="true", and it becomes the primary key. It
did have a problem with my method name, though. I had declared the getter
as "getFQName()", and it complained that the impl class didn't have a get
method for property fQName. I changed it to "getFqname()", and it works
fine.
Paul
> Hi Paul,
> gr. Martin
>> * @model
>> @Id
>> Thanks,
>> Paul
> The Netherlands
| Re: [teneo] primary key in java code [message #86335 is a reply to message #86244] |
Wed, 13 June 2007 15:37  |
--------------090604030608040903010006
Martin,
Yes they can. :-) Like this:
* @model annotation="http://www.example.com foo='bar'"
So the syntax is {<source-URI> {<key>='<value>}*}* and you can use \ to
escape characters with special meaning.
Martin Taal wrote:
> Hi Paul,
> source. For other annotations: I don't think that they will work, at
> least I don't think that eannotations can be specified in java source.
> gr. Martin
>> * @model
>> @Id
>> model, and the uniquename property doesn't end up as the primary
>> key. It's set to changeable="false" because I am creating the value
>> from other data, and that gets stored find in the database.
>> Thanks,
>> Paul
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Martin,<br>
<br>
Yes they can. :-) Like this:<br>
<blockquote>* @model annotation=<a class="moz-txt-link-rfc2396E" href="http://www.example.comfoo='bar'">"http://www.example.com foo='bar'"</a><br>
</blockquote>
and you can use \ to escape characters with special meaning.<br>
<br>
<br>
Martin Taal wrote:
<blockquote cite="mid:f4pb7n$eaj$1@build.eclipse.org" type="cite">Hi
Paul,
<br>
<br>
<br>
gr. Martin
<br>
<br>
<br>
<blockquote type="cite">This has likely been answered, but I can't
seem to find it.
<br>
<br>
<br>
<br>
<br>
* @model
<br>
<br>
<br>
<br>
<br>
<br>
@Id
<br>
<br>
<br>
<br>
set to changeable="false" because I am creating the value from other
<br>
<br>
<br>
Paul <br>
<br>
</blockquote>
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------090604030608040903010006--
| Re: [teneo] primary key in java code [message #606946 is a reply to message #86229] |
Hi Paul,
gr. Martin
> * @model
> @Id
> Paul
The Netherlands
| Re: [teneo] primary key in java code [message #606952 is a reply to message #86244] |
> Hi Paul,
> gr. Martin
>> * @model
>> @Id
>> Thanks,
>> Paul
> The Netherlands
| Re: [teneo] primary key in java code [message #606954 is a reply to message #86274] |
gr. Martin
>> Hi Paul,
>> gr. Martin
>>> * @model
>>> @Id
>>> Thanks,
>>> Paul
>> The Netherlands
The Netherlands
| Re: [teneo] primary key in java code [message #606958 is a reply to message #86244] |
fine.
Paul
> Hi Paul,
> gr. Martin
>> * @model
>> @Id
>> Thanks,
>> Paul
> The Netherlands
| Re: [teneo] primary key in java code [message #606963 is a reply to message #86244] |
Martin,
Martin Taal wrote:
> Hi Paul,
> gr. Martin
>> * @model
>> @Id
>> Thanks,
>> Paul
<html>
<head>
</head>
Martin,<br>
<br>
</blockquote>
<br>
<br>
Paul,
<br>
<br>
<br>
gr. Martin
<br>
<br>
<br>
seem to find it.
<br>
<br>
<br>
<br>
<br>
* @model
<br>
<br>
<br>
<br>
<br>
<br>
@Id
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Paul <br>
<br>
</blockquote>
<br>
<br>
</blockquote>
<br>
</body>
</html>
Current Time: Wed Nov 05 12:57:08 EST 2025
Powered by FUDForum. Page generated in 0.05521 seconds
