Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » subclasses not being recreated
subclasses not being recreated [message #85988] Mon, 11 June 2007 13:40 Go to next message
I have a model that is created in java, that gets perisisted fine, but
doesn't get recreated when I read it back in.
When I create and save an instance of the subclass, and then look in the
database, I can see all of its properties in the corresponding table. When
I read it back in, the properties from the superclass are ok, and the getter
methods work fine. However, the properties that are defined in the subclass
are all null.
Re: subclasses not being recreated [message #86002 is a reply to message #85988] Mon, 11 June 2007 13:44 Go to previous messageGo to next message
Sorry, I forgot to mark it teneo.
"Paul Gardiner" <pgardiner@syntellect.com> wrote in message
news:f4k1es$tvr$1@build.eclipse.org...
> When I read it back in, the properties from the superclass are ok, and the
> getter methods work fine. However, the properties that are defined in the
> subclass are all null.
Re: subclasses not being recreated [message #86017 is a reply to message #86002] Mon, 11 June 2007 14:31 Go to previous messageGo to next message
I would need some more information to be able to comment. Can you make a small example which shows
this behavior?
gr. Martin
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: subclasses not being recreated [message #86093 is a reply to message #86017] Tue, 12 June 2007 15:20 Go to previous message
I tried recreating and was unsuccessful. It turned out to be a bug in my
implementation classes on my part.
"Martin Taal" <mtaal@elver.org> wrote in message
news:f4k4dg$4da$1@build.eclipse.org...
>small example which shows this behavior?
> gr. Martin
>>> the getter methods work fine. However, the properties that are defined
>>> in the subclass are all null.
> The Netherlands
Re: subclasses not being recreated [message #606900 is a reply to message #85988] Mon, 11 June 2007 13:44 Go to previous message
Re: subclasses not being recreated [message #606901 is a reply to message #86002] Mon, 11 June 2007 14:31 Go to previous message
this behavior?
gr. Martin
The Netherlands
Re: subclasses not being recreated [message #606910 is a reply to message #86017] Tue, 12 June 2007 15:20 Go to previous message
> gr. Martin
> The Netherlands
Previous Topic:[Teneo - JPOX] Enhanced classes
Next Topic:How to generate schema with jpoxhelper
Current Time: Fri Jul 25 09:09:04 EDT 2025
Powered by FUDForum. Page generated in 0.26659 seconds
