Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [teneo] XML(Gregorian)Calendar or GregorianCalendar
[teneo] XML(Gregorian)Calendar or GregorianCalendar [message #85609] Wed, 06 June 2007 10:56 Go to next message
Is it possible to use a GregorianCalendar or XMLGregorianCalendar or
XMLCalendar using Teneo/Hibernate? Date seems to work fine, but I get
exceptions such as :
The value '2007-06-06T14:42:43Z' is
invalid.">java.lang.IllegalArgumentException: The value
'2007-06-06T14:42:43Z' is invalid. at
org.eclipse.emf.ecore.impl.EFactoryImpl.createFromString(EFa ctoryImpl.java:439)
at . . .
Whenever I try to use an XMLCalendar. I get something similar for the other
types. I am setting the XMLTypePackages in my HbDataStore.setEPackages()
method, which I think is correct.
Re: [teneo] XML(Gregorian)Calendar or GregorianCalendar [message #85638 is a reply to message #85609] Wed, 06 June 2007 12:54 Go to previous messageGo to next message
Paul,
I recently changed this
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=190666) so that the
validation is no longer done during construction but rather as a
validation step later. I've noticed it's quite common to end up with a
"dateTime" type of result when only a "date" is expected...
> at . . .
Re: [teneo] XML(Gregorian)Calendar or GregorianCalendar [message #85678 is a reply to message #85638] Wed, 06 June 2007 17:20 Go to previous messageGo to next message
Hi Paul,
I would need a longer stack trace to really comment on this. Teneo should be able to support this.
As an example from a testcase I have:
This xsd:
<complexType name="TestDate">
<sequence>
<element name="date" type="date"></element>
<element name="datetime" type="dateTime"></element>
</sequence>
</complexType>
Results in this ecore:
<eStructuralFeatures xsi:type="ecore:EAttribute" name="date" unique="false" lowerBound="1"
eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//Date">
<eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="kind" value="element"/>
<details key="name" value="date"/>
<details key="namespace" value="##targetNamespace"/>
</eAnnotations>
</eStructuralFeatures>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="datetime" unique="false"
lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//DateTime">
<details key="name" value="datetime"/>
</eAnnotations>
Which results in this hbm:
<property name="date" lazy="false" insert="true" update="true" not-null="true" unique="false"
type="org.eclipse.emf.teneo.hibernate.mapping.XSDDate">
<column not-null="true" unique="false" name="`date`"/>
</property>
<property name="datetime" lazy="false" insert="true" update="true" not-null="true" unique="false"
type="org.eclipse.emf.teneo.hibernate.mapping.XSDDateTime">
<column not-null="true" unique="false" name="`datetime`"/>
</property>
gr. Martin
Ed Merks wrote:
> Paul,
>> at . . .
>> other types. I am setting the XMLTypePackages in my
>> HbDataStore.setEPackages() method, which I think is correct.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [teneo] XML(Gregorian)Calendar or GregorianCalendar [message #85798 is a reply to message #85678] Thu, 07 June 2007 10:28 Go to previous messageGo to next message
Before I send a stack trace, what type should I be using for dates/times?
My preference is GregorianCalendar, but I'm not sure if it's supported. Do
I need to add any specific ePackage? Also, do I need a type attribute on my
@model annotation?
"Martin Taal" <mtaal@elver.org> wrote in message
news:f478et$d1h$1@build.eclipse.org...
> Hi Paul,
> This xsd:
> <sequence>
> </sequence>
> </complexType>
> <eAnnotations
> </eAnnotations>
> unique="false"
> <eAnnotations
> </eAnnotations>
> </property>
> </property>
> gr. Martin
> Ed Merks wrote:
>> Paul,
>>> at . . .
> The Netherlands
Re: [teneo] XML(Gregorian)Calendar or GregorianCalendar [message #85825 is a reply to message #85798] Fri, 08 June 2007 08:35 Go to previous messageGo to next message
I just use the Date class myself.
I think also gregorian calendar is supported by Hibernate, you can try.
If it does not work then you need to create your own hibernate usertype and set a @Type/@TypeDef
annotation on the edatatype/eattribute having this.
gr. Martin
> @model annotation?
>> Hi Paul,
>> This xsd:
>> <sequence>
>> </sequence>
>> </complexType>
>> <eAnnotations
>> </eAnnotations>
>> unique="false"
>> <eAnnotations
>> </eAnnotations>
>> </property>
>> </property>
>> gr. Martin
>> Ed Merks wrote:
>>> Paul,
>>>> at . . .
>> The Netherlands
I
The Netherlands
[teneo] XMLGregorianCalendar [message #85895 is a reply to message #85825] Sat, 09 June 2007 04:17 Go to previous messageGo to next message
Hello, I have a similar problem:
There is a type in ecore model :
<eClassifiers xsi:type="ecore:EDataType" name="DateCategoriesCust"
instanceClassName="javax.xml.datatype.XMLGregorianCalendar" >
<eAnnotations source="http://www.eclipse.org/emf/2002/GenModel">
<details key="documentation" value="?"?
Re: [teneo] XMLGregorianCalendar [message #85913 is a reply to message #85895] Sat, 09 June 2007 05:57 Go to previous messageGo to next message
--------------040607090305070004080900
Wolf,
This was a bug that we encountered earlier this week and should be fixed
in this weeks 2.3 build
https://bugs.eclipse.org/bugs/show_bug.cgi?id=191219
The problem only occurs on the Sun JDK and looks to be a bug in the JDK
where Sun's JDK doesn't implement .equals properly. It's never valid to
fail comparison with a cast cast exception. The equals implementation
of any subclass of XMLGregorianCalendard should be tolerant of any other
implementation of XMLGregorianCalendar rather than assume that only a
particular implementation is present. I'm not sure if there is a Sun
bug report about it...
Re: [teneo] XMLGregorianCalendar [message #85941 is a reply to message #85913] Sat, 09 June 2007 07:32 Go to previous message
------=_NextPart_000_0017_01C7AAAB.55685960
charset="ISO-8859-1"
Content-Transfer-Encoding: quoted-printable
Thanks, well work!
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2900.3086" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Thanks, well =
work!</FONT></DIV></BODY></HTML>
------=_NextPart_000_0017_01C7AAAB.55685960--
Re: [teneo] XML(Gregorian)Calendar or GregorianCalendar [message #606874 is a reply to message #85609] Wed, 06 June 2007 12:54 Go to previous message
Paul,
> at . . .
Re: [teneo] XML(Gregorian)Calendar or GregorianCalendar [message #606879 is a reply to message #85638] Wed, 06 June 2007 17:20 Go to previous message
Hi Paul,
This xsd:
<sequence>
</sequence>
</complexType>
</eAnnotations>
</eAnnotations>
</property>
</property>
gr. Martin
Ed Merks wrote:
> Paul,
>> at . . .
The Netherlands
Re: [teneo] XML(Gregorian)Calendar or GregorianCalendar [message #606887 is a reply to message #85678] Thu, 07 June 2007 10:28 Go to previous message
@model annotation?
> Hi Paul,
> This xsd:
> <sequence>
> </sequence>
> </complexType>
> <eAnnotations
> </eAnnotations>
> unique="false"
> <eAnnotations
> </eAnnotations>
> </property>
> </property>
> gr. Martin
> Ed Merks wrote:
>> Paul,
>>> at . . .
> The Netherlands
Re: [teneo] XML(Gregorian)Calendar or GregorianCalendar [message #606889 is a reply to message #85798] Fri, 08 June 2007 08:35 Go to previous message
gr. Martin
> @model annotation?
>> Hi Paul,
>> This xsd:
>> <sequence>
>> </sequence>
>> </complexType>
>> <eAnnotations
>> </eAnnotations>
>> unique="false"
>> <eAnnotations
>> </eAnnotations>
>> </property>
>> </property>
>> gr. Martin
>> Ed Merks wrote:
>>> Paul,
>>>> at . . .
>> The Netherlands
I
The Netherlands
[teneo] XMLGregorianCalendar [message #606893 is a reply to message #85825] Sat, 09 June 2007 04:17 Go to previous message
Re: [teneo] XMLGregorianCalendar [message #606894 is a reply to message #85895] Sat, 09 June 2007 05:57 Go to previous message
Wolf,
Re: [teneo] XMLGregorianCalendar [message #606896 is a reply to message #85913] Sat, 09 June 2007 07:32 Go to previous message
Thanks, well work!
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
Previous Topic:[Teneo] Exception and Persistence mapping
Next Topic:[Teneo] Exception and Persistence mapping
Current Time: Thu Jul 24 23:30:54 EDT 2025
Powered by FUDForum. Page generated in 0.08736 seconds
