[teneo] XML(Gregorian)Calendar or GregorianCalendar [message #85609] |
Wed, 06 June 2007 10:56  |
Is it possible to use a GregorianCalendar or XMLGregorianCalendar or
XMLCalendar using Teneo/Hibernate? Date seems to work fine, but I get
exceptions such as :
The value '2007-06-06T14:42:43Z' is
invalid.">java.lang.IllegalArgumentException: The value
'2007-06-06T14:42:43Z' is invalid. at
org.eclipse.emf.ecore.impl.EFactoryImpl.createFromString(EFa ctoryImpl.java:439)
at . . .
Whenever I try to use an XMLCalendar. I get something similar for the other
types. I am setting the XMLTypePackages in my HbDataStore.setEPackages()
method, which I think is correct.
Re: [teneo] XML(Gregorian)Calendar or GregorianCalendar [message #85798 is a reply to message #85678] |
Thu, 07 June 2007 10:28   |
Before I send a stack trace, what type should I be using for dates/times?
My preference is GregorianCalendar, but I'm not sure if it's supported. Do
I need to add any specific ePackage? Also, do I need a type attribute on my
@model annotation?
"Martin Taal" <mtaal@elver.org> wrote in message
news:f478et$d1h$1@build.eclipse.org...
> Hi Paul,
> I would need a longer stack trace to really comment on this. Teneo should
> be able to support this.
> As an example from a testcase I have:
> This xsd:
> <complexType name="TestDate">
> <sequence>
> <element name="date" type="date"></element>
> <element name="datetime" type="dateTime"></element>
> </sequence>
> </complexType>
> Results in this ecore:
> <eStructuralFeatures xsi:type="ecore:EAttribute" name="date"
> unique="false" lowerBound="1"
> eType="ecore:EDataType
> http://www.eclipse.org/emf/2003/XMLType#//Date">
> <eAnnotations
> source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
> <details key="kind" value="element"/>
> <details key="name" value="date"/>
> <details key="namespace" value="##targetNamespace"/>
> </eAnnotations>
> </eStructuralFeatures>
> <eStructuralFeatures xsi:type="ecore:EAttribute" name="datetime"
> unique="false"
> lowerBound="1" eType="ecore:EDataType
> http://www.eclipse.org/emf/2003/XMLType#//DateTime">
> <eAnnotations
> <details key="name" value="datetime"/>
> </eAnnotations>
> Which results in this hbm:
> <property name="date" lazy="false" insert="true" update="true"
> not-null="true" unique="false"
> type="org.eclipse.emf.teneo.hibernate.mapping.XSDDate">
> <column not-null="true" unique="false" name="`date`"/>
> </property>
> <property name="datetime" lazy="false" insert="true" update="true"
> type="org.eclipse.emf.teneo.hibernate.mapping.XSDDateTime">
> <column not-null="true" unique="false" name="`datetime`"/>
> </property>
> gr. Martin
> Ed Merks wrote:
>> Paul,
>> I recently changed this
>> (https://bugs.eclipse.org/bugs/show_bug.cgi?id=190666) so that the
>> validation is no longer done during construction but rather as a
>> validation step later. I've noticed it's quite common to end up with a
>> "dateTime" type of result when only a "date" is expected...
>>> at . . .
>>> other types. I am setting the XMLTypePackages in my
>>> HbDataStore.setEPackages() method, which I think is correct.
> With Regards, Martin Taal
> Springsite/Elver.org
> Office: Hardwareweg 4, 3821 BV Amersfoort
> Postal: Nassaulaan 7, 3941 EC Doorn
> The Netherlands
> Tel: +31 (0)84 420 2397
> Fax: +31 (0)84 225 9307
> Mail: mtaal@springsite.com - mtaal@elver.org
> Web: www.springsite.com - www.elver.org
Re: [teneo] XML(Gregorian)Calendar or GregorianCalendar [message #85825 is a reply to message #85798] |
Fri, 08 June 2007 08:35   |
I just use the Date class myself.
I think also gregorian calendar is supported by Hibernate, you can try.
If it does not work then you need to create your own hibernate usertype and set a @Type/@TypeDef
annotation on the edatatype/eattribute having this.
gr. Martin
> @model annotation?
>> Hi Paul,
>> This xsd:
>> <sequence>
>> </sequence>
>> </complexType>
>> <eAnnotations
>> </eAnnotations>
>> unique="false"
>> <eAnnotations
>> </eAnnotations>
>> </property>
>> </property>
>> gr. Martin
>> Ed Merks wrote:
>>> Paul,
>>>> at . . .
>> The Netherlands
I
The Netherlands
Re: [teneo] XMLGregorianCalendar [message #85941 is a reply to message #85913] |
Sat, 09 June 2007 07:32  |
------=_NextPart_000_0017_01C7AAAB.55685960
Content-Type: text/plain;
charset="ISO-8859-1"
Content-Transfer-Encoding: quoted-printable
Thanks, well work!
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2900.3086" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Thanks, well =
work!</FONT></DIV></BODY></HTML>
------=_NextPart_000_0017_01C7AAAB.55685960--
Re: [teneo] XML(Gregorian)Calendar or GregorianCalendar [message #606874 is a reply to message #85609] |
Wed, 06 June 2007 12:54  |
Paul,
> at . . .
Re: [teneo] XML(Gregorian)Calendar or GregorianCalendar [message #606879 is a reply to message #85638] |
Wed, 06 June 2007 17:20  |
Hi Paul,
I would need a longer stack trace to really comment on this. Teneo should be able to support this.
This xsd:
<sequence>
</sequence>
</complexType>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="date" unique="false" lowerBound="1"
eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//Date">
<eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="datetime" unique="false"
lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//DateTime">
</eAnnotations>
<property name="date" lazy="false" insert="true" update="true" not-null="true" unique="false"
</property>
<property name="datetime" lazy="false" insert="true" update="true" not-null="true" unique="false"
</property>
gr. Martin
Ed Merks wrote:
> Paul,
>> at . . .
The Netherlands
Re: [teneo] XML(Gregorian)Calendar or GregorianCalendar [message #606887 is a reply to message #85678] |
@model annotation?
> Hi Paul,
> This xsd:
> <sequence>
> </sequence>
> </complexType>
> <eAnnotations
> </eAnnotations>
> unique="false"
> <eAnnotations
> </eAnnotations>
> </property>
> </property>
> gr. Martin
> Ed Merks wrote:
>> Paul,
>>> at . . .
> The Netherlands
Re: [teneo] XML(Gregorian)Calendar or GregorianCalendar [message #606889 is a reply to message #85798] |
gr. Martin
> @model annotation?
>> Hi Paul,
>> This xsd:
>> <sequence>
>> </sequence>
>> </complexType>
>> <eAnnotations
>> </eAnnotations>
>> unique="false"
>> <eAnnotations
>> </eAnnotations>
>> </property>
>> </property>
>> gr. Martin
>> Ed Merks wrote:
>>> Paul,
>>>> at . . .
>> The Netherlands
I
The Netherlands
Re: [teneo] XMLGregorianCalendar [message #606894 is a reply to message #85895] |
Sat, 09 June 2007 05:57  |
--------------040607090305070004080900
Wolf,
This was a bug that we encountered earlier this week and should be fixed
in this weeks 2.3 build
https://bugs.eclipse.org/bugs/show_bug.cgi?id=191219
The problem only occurs on the Sun JDK and looks to be a bug in the JDK
where Sun's JDK doesn't implement .equals properly. It's never valid to
fail comparison with a cast cast exception. The equals implementation
of any subclass of XMLGregorianCalendard should be tolerant of any other
implementation of XMLGregorianCalendar rather than assume that only a
particular implementation is present. I'm not sure if there is a Sun
bug report about it...
wolf_roma wrote:
> Hello, I have a similar problem:
> There is a type in ecore model :
> <eClassifiers xsi:type="ecore:EDataType" name="DateCategoriesCust"
> instanceClassName="javax.xml.datatype.XMLGregorianCalendar" >
> <eAnnotations source="http://www.eclipse.org/emf/2002/GenModel">
> <details key="documentation" value="?"?
Re: [teneo] XMLGregorianCalendar [message #606896 is a reply to message #85913] |
Thanks, well work!
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
FUDForum. Page generated in 0.06151 seconds
