Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo+Hibernate]Help! A hibernate mapping question
[Teneo+Hibernate]Help! A hibernate mapping question [message #84377] |
Mon, 21 May 2007 23:37  |
I have several classes in a EMF model and these classes will be mapped
into ONE table . How to write the mapping file to only let one class to
insert/update/delete the table record and the others just mapped to some
fields?
Thanks in advance!
Anthony
Re: [Teneo+Hibernate]Help! A hibernate mapping question [message #84453 is a reply to message #84440] |
Tue, 22 May 2007 05:09   |
Anthony,
Model refers to one instance of Network and one instance of OptimizedResult and you want the
features of Network and OptimizedResult to be mapped to the same table as Model. When a Model is
saved also the Network and OptimizedResult are saved.
Is this what you want?
gr. Martin
Anthony wrote:
> Martin,
> Thank you for help.
> I just learn to write my mapping file.
> It seems that when a new persistable object was saved
> a new record will be inserted into its mapped table.
> In my case, the sample structure of my EMF model list below:
> Model
> |____Network
> |____OptimizedResult
> There is a table called T_Model which will store all the attribute in
> Model,Netwrok and OptimizedResult.
> So I cannot map 3 classes into T_Model.
> But I am not sure if it is possible to map into DB View.
> Regards,
> Anthony
>> Hi Anthony,
>> I think you mean embedded but to be sure can you give a small example
>> of what you want to achieve?
>> gr. Martin
>> Anthony wrote:
>>> Hi,
>>> mapped
>>> to insert/update/delete the table record and the others just mapped
>>> to some fields?
>>> Thanks in advance!
>>> Anthony
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo+Hibernate]Help! A hibernate mapping question [message #84479 is a reply to message #84465] |
Tue, 22 May 2007 05:21   |
Anthony,
To achieve this you can set the @Embedded annotation in the ereferences Model.Network and
Model.OptimizedResult.
If there are nameclashes between Network, OptimizedResult and Model then you can use
@AttributeOverrides.
gr. Martin
Anthony wrote:
> Martin,
> Exactly.
> Anthony
>> Anthony,
>> OptimizedResult and you want the features of Network and
>> is saved also the Network and OptimizedResult are saved.
>> gr. Martin
>> Anthony wrote:
>>> Martin,
>>> Thank you for help.
>>> Model
>>> |____Network
>>> |____OptimizedResult
>>> in
>>> Regards,
>>> Anthony
>>>> Hi Anthony,
>>>> example of what you want to achieve?
>>>> gr. Martin
>>>> Anthony wrote:
>>>>> Hi,
>>>>> mapped
>>>>> class to insert/update/delete the table record and the others just
>>>>> mapped to some fields?
>>>>> Thanks in advance!
>>>>> Anthony
The Netherlands
Re: [Teneo+Hibernate]Help! A hibernate mapping question [message #84489 is a reply to message #84479] |
Tue, 22 May 2007 06:02   |
Martin,
OK. I will try it.
I have another question :
In my case ,the model structure list as below:
Network
|________ProductCatalog
| |_______Product collection
|________CustomerCatlog
|_______Customer collection
When UI want to show product collections,
the ProductCatalog object will act as collection's
parent object to avoid getting customer collecitons.
(If no ***catalog, ContentProvider will return Network's children)
Do I have to have table to mapped ***Catalog class?
Anthony
> Anthony,
> ereferences Model.Network and Model.OptimizedResult.
> then you can use @AttributeOverrides.
> gr. Martin
> Anthony wrote:
>> Martin,
>> Exactly.
>> Anthony
>>> Anthony,
>>> Model is saved also the Network and OptimizedResult are saved.
>>> gr. Martin
>>> Anthony wrote:
>>>> Martin,
>>>> Thank you for help.
>>>> Model
>>>> |____Network
>>>> |____OptimizedResult
>>>> attribute in
>>>> Regards,
>>>> Anthony
>>>>> Hi Anthony,
>>>>> gr. Martin
>>>>> Anthony wrote:
>>>>>> Hi,
>>>>>> mapped
>>>>>> just mapped to some fields?
>>>>>> Thanks in advance!
>>>>>> Anthony
Re: [Teneo+Hibernate]Help! A hibernate mapping question [message #84501 is a reply to message #84489] |
Tue, 22 May 2007 06:10  |
Anthony,
You can try to set @Embedded also on Network.ProductCatalog/CustomerCatalog to get it into the same
table as Model and Network. Is that whay you want/mean?
gr. Martin
Anthony wrote:
> Martin,
> OK. I will try it.
> Network
> Anthony
>> Anthony,
>> gr. Martin
>> Anthony wrote:
>>> Martin,
>>> Exactly.
>>> Anthony
>>>> Anthony,
>>>> gr. Martin
>>>> Anthony wrote:
>>>>> Martin,
>>>>> Thank you for help.
>>>>> Model
>>>>> |____Network
>>>>> |____OptimizedResult
>>>>> attribute in
>>>>> Regards,
>>>>> Anthony
>>>>>> Hi Anthony,
>>>>>> gr. Martin
>>>>>> Anthony wrote:
>>>>>>> Hi,
>>>>>>> mapped
>>>>>>> Thanks in advance!
>>>>>>> Anthony
The Netherlands
Re: [Teneo+Hibernate]Help! A hibernate mapping question [message #606757 is a reply to message #84377] |
Tue, 22 May 2007 03:27  |
Hi Anthony,
I think you mean embedded but to be sure can you give a small example of what you want to achieve?
gr. Martin
Anthony wrote:
> fields?
> Thanks in advance!
> Anthony
The Netherlands
Re: [Teneo+Hibernate]Help! A hibernate mapping question [message #606759 is a reply to message #84410] |
Tue, 22 May 2007 04:57  |
Martin,
Thank you for help.
Model
|____Network
|____OptimizedResult
Anthony
> Hi Anthony,
> gr. Martin
> Anthony wrote:
>> Hi,
>> mapped
>> to some fields?
>> Thanks in advance!
>> Anthony
Re: [Teneo+Hibernate]Help! A hibernate mapping question [message #606760 is a reply to message #84440] |
Anthony,
gr. Martin
Anthony wrote:
> Martin,
> Thank you for help.
> Model
> |____Network
> |____OptimizedResult
> Regards,
> Anthony
>> Hi Anthony,
>> gr. Martin
>> Anthony wrote:
>>> Hi,
>>> mapped
>>> to some fields?
>>> Thanks in advance!
>>> Anthony
The Netherlands
Re: [Teneo+Hibernate]Help! A hibernate mapping question [message #606761 is a reply to message #84453] |
Tue, 22 May 2007 05:13  |
Martin,
Exactly.
Anthony
> Anthony,
> gr. Martin
> Anthony wrote:
>> Martin,
>> Thank you for help.
>> Model
>> |____Network
>> |____OptimizedResult
>> in
>> Regards,
>> Anthony
>>> Hi Anthony,
>>> gr. Martin
>>> Anthony wrote:
>>>> Hi,
>>>> mapped
>>>> Thanks in advance!
>>>> Anthony
Re: [Teneo+Hibernate]Help! A hibernate mapping question [message #606762 is a reply to message #84465] |
Anthony,
gr. Martin
Anthony wrote:
> Martin,
> Exactly.
> Anthony
>> Anthony,
>> gr. Martin
>> Anthony wrote:
>>> Martin,
>>> Thank you for help.
>>> Model
>>> |____Network
>>> |____OptimizedResult
>>> in
>>> Regards,
>>> Anthony
>>>> Hi Anthony,
>>>> gr. Martin
>>>> Anthony wrote:
>>>>> Hi,
>>>>> mapped
>>>>> Thanks in advance!
>>>>> Anthony
The Netherlands
Re: [Teneo+Hibernate]Help! A hibernate mapping question [message #606763 is a reply to message #84479] |
Martin,
OK. I will try it.
Network
Anthony
> Anthony,
> gr. Martin
> Anthony wrote:
>> Martin,
>> Exactly.
>> Anthony
>>> Anthony,
>>> gr. Martin
>>> Anthony wrote:
>>>> Martin,
>>>> Thank you for help.
>>>> Model
>>>> |____Network
>>>> |____OptimizedResult
>>>> attribute in
>>>> Regards,
>>>> Anthony
>>>>> Hi Anthony,
>>>>> gr. Martin
>>>>> Anthony wrote:
>>>>>> Hi,
>>>>>> mapped
>>>>>> Thanks in advance!
>>>>>> Anthony
Re: [Teneo+Hibernate]Help! A hibernate mapping question [message #606764 is a reply to message #84489] |
Anthony,
gr. Martin
Anthony wrote:
> Martin,
> OK. I will try it.
> Network
> Anthony
>> Anthony,
>> gr. Martin
>> Anthony wrote:
>>> Martin,
>>> Exactly.
>>> Anthony
>>>> Anthony,
>>>> gr. Martin
>>>> Anthony wrote:
>>>>> Martin,
>>>>> Thank you for help.
>>>>> Model
>>>>> |____Network
>>>>> |____OptimizedResult
>>>>> attribute in
>>>>> Regards,
>>>>> Anthony
>>>>>> Hi Anthony,
>>>>>> gr. Martin
>>>>>> Anthony wrote:
>>>>>>> Hi,
>>>>>>> mapped
>>>>>>> Thanks in advance!
>>>>>>> Anthony
The Netherlands
Current Time: Thu Jul 24 22:28:09 EDT 2025
Powered by FUDForum. Page generated in 0.11790 seconds
