Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » how to paging big model and still reserve EMF.Edit command framework?
how to paging big model and still reserve EMF.Edit command framework? [message #82506] |
Tue, 08 May 2007 06:37  |
My project is based on EMF . It make use of EMF.Edit command
framework.
As the model file is too large, I want to use Teneo to promote the
performance,for example , paging the records , sort records in db, etc.
By customed loadUsingDefinedQueries() method, paging function is
implemented.
But in my Interceptor's onLoad() output, I found out that each time
the RemoveCommand is being created, all records will be loaded.
After I use my customed PersistableEList to override contains
()/containsAll()/listIterator(), the extra load disappear.
But some delegate***() still load records from db...
In fact, all the content appear in UI has been in resource , but the
object's persistableEList's delegate don't know.
Has anyone solved this kind of issue?
Any idea would be appriciated.
Anthony
Re: how to paging big model and still reserve EMF.Edit command framework? [message #83675 is a reply to message #82506] |
Wed, 16 May 2007 08:07   |
Anthony,
The delete command needs to look for any other references to the object
being deleted to also clean those up. I suppose that's what's causing
all the loads. I'm not sure how to avoid that. I don't know Teneo well
enough to answer that part of the question...
Anthony Lee wrote:
> framework.
> implemented.
> Anthony
Re: how to paging big model and still reserve EMF.Edit command framework? [message #83704 is a reply to message #83675] |
Wed, 16 May 2007 08:33  |
As an add-on to Ed's reply. The HbDataStore offers methods to efficiently retrieve all the referers
to a certain object. Based on the ecore-model it will only fire the queries required to retrieve all
the referers for that specific type, so you won't require a full-database scan for delete constraint
checking.
I have not tried to integrate this functionality with the EMF.Edit(or) framework but it could be
worth a try.
gr. Martin
Ed Merks wrote:
> Anthony,
> Anthony Lee wrote:
>> Hi,
>> My project is based on EMF . It make use of EMF.Edit command framework.
>> implemented.
>> Anthony
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: how to paging big model and still reserve EMF.Edit command framework? [message #606708 is a reply to message #82506] |
Anthony,
Anthony Lee wrote:
> framework.
> implemented.
> Anthony
Re: how to paging big model and still reserve EMF.Edit command framework? [message #606710 is a reply to message #83675] |
checking.
worth a try.
gr. Martin
Ed Merks wrote:
> Anthony,
> Anthony Lee wrote:
>> Hi,
>> implemented.
>> Anthony
The Netherlands
Current Time: Thu Jul 24 22:45:11 EDT 2025
Powered by FUDForum. Page generated in 0.26881 seconds
