Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEList
[teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEList [message #83177] Fri, 11 May 2007 06:54 Go to next message
In my EMF model , Product and ProductRegistry has many-To-one
relationship and ProductRegistry set as transient.
I create a new Product and set it's eContainer as not null
and then add this Product element into HibernateResourse's
contents, in inverseAdd() ,the eContainer is removed.
If I set the referenceFeature's proxyFlag as 65536 in debug mode
to make the isResolveProxy() return true, I could stop this removal.
Do I need to set something in hibernate.hbm.xml?
Anthony
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #83193 is a reply to message #83177] Fri, 11 May 2007 07:11 Go to previous messageGo to next message
Is parent of the Product already present in the resource?
gr. Martin
Anthony wrote:
> Anthony
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #83204 is a reply to message #83177] Fri, 11 May 2007 07:19 Go to previous messageGo to next message
Anthony,
This sounds like expected behavior. For non-proxy resolving containment
reference (EReference.isResolveProxies == true), eContainer and
eDirectResource mutually exclusive, i.e., you can't have an EObject
container and be contained directly by a resource's getContents. Only
for proxy resolving containment is it possible to put a "child" in to a
separate resource. Note that if Products parent is already in a
resource then product.eResource() will be non-null, and there is no need
to put the Product directly in the resource since it's indirectly
contained in the resource by virtue of the parent being contained in a
resource.
Anthony wrote:
> Anthony
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #83211 is a reply to message #83193] Fri, 11 May 2007 07:21 Go to previous messageGo to next message
Martin Taal <mtaal@elver.org> wrote in news:f21j0e$hdh$1
@build.eclipse.org:
> gr. Martin
> Anthony wrote:
>> Hi,
>> Anthony
It is not.
I have to use another resource to init the parent to get it
as EMF owner object to create AddChild command.
It seems the saving action would fail since the parent is not in the
same resource, but if the eContainer is not removed then the element is
saved in DB.
Anthony
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #83227 is a reply to message #83204] Fri, 11 May 2007 07:41 Go to previous messageGo to next message
Ed Merks <merks@ca.ibm.com> wrote in news:f21jgu$ihr$1
@build.eclipse.org:
Merks,
Thanks.
So if the container is set as transient, how to persist the
container's element ?
Anthony
> Anthony,
containment
a
need
> resource.
> Anthony wrote:
>> Hi,
>> Anthony
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #83243 is a reply to message #83227] Fri, 11 May 2007 08:07 Go to previous messageGo to next message
--------------040705060809080707090006
Anthony,
I'm not sure I completely follow what you are asking (container is set
as transient implies you don't want to serialize it), but in the XMI
serialization, to serialize a reference to the container, you need to
define a non-transient container feature (i.e., an EReference that's the
eOpposite of the containment feature).
> @build.eclipse.org:
> Merks,
> Thanks.
> Anthony
>> Anthony,
> containment
> a
> need
>> resource.
>> Anthony wrote:
>>> Hi,
>>> Anthony
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Anthony,<br>
<br>
the eOpposite of the containment feature).<br>
<br>
<br>
Anthony wrote:
<blockquote cite="midXns990FC81B5A375AnthonyLee@206.191.52.34"
type="cite">
<pre wrap="">Ed Merks <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in <a class="moz-txt-link-freetext" href="news:f21jgu$ihr$1">news:f21jgu$ihr$1</a>
@build.eclipse.org:
Merks,
Thanks.
Anthony
</pre>
<blockquote type="cite">
<pre wrap="">Anthony,
</pre>
</blockquote>
<pre wrap=""><!---->containment
</pre>
<pre wrap="">reference (EReference.isResolveProxies == true), eContainer and
</pre>
</blockquote>
<pre wrap=""><!---->a
</pre>
<pre wrap="">separate resource. Note that if Products parent is already in a
</pre>
</blockquote>
<pre wrap=""><!---->need
</pre>
<pre wrap="">to put the Product directly in the resource since it's indirectly
resource.
Anthony wrote:
</pre>
<pre wrap="">Hi,
Anthony
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------040705060809080707090006--
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #83257 is a reply to message #83243] Fri, 11 May 2007 08:26 Go to previous messageGo to next message
Merks,
Actually I used Teneo to save my model into DB.
Let me introduce the picture:
When the first time the model is created , the only one
ProductRegistry element is created and saved.
And then when user click the Product node in UI, I need to
show a table to list the products.
Because the products collection could be really huge, so I choose
to change them to many-to-one's (so only persist the reference from the
child to the parent) and load the one-to-many relation (parent to child)
on demand through an explicit query (make the many-reference from the
parent to the child transient). Adding to the parent is then done by
setting the parent feature in the child.
Anthony
> Anthony,
>> @build.eclipse.org:
>> Merks,
>> Thanks.
>> Anthony
>>> Anthony,
>> containment
>>> Only for proxy resolving containment is it possible to put a "child"
>>> in to
>> a
>> need
>>> a resource.
>>> Anthony wrote:
>>>> Hi,
>>>> removal.
>>>> Anthony
> Attachment decoded: untitled-2.txt
> <html>
> <head>
> </head>
> Anthony,<br>
> <br>
> <br>
> <br>
> type="cite">
> @build.eclipse.org:
> Merks,
> Thanks.
> Anthony
> </pre>
> </pre>
> </blockquote>
> </pre>
> eContainer and
> </pre>
> </blockquote>
> </pre>
> already in a
> </pre>
> </blockquote>
> </pre>
> it's indirectly
> resource.
> Anthony wrote:
> </pre>
> <pre wrap="">Hi,
> Anthony
> </pre>
> </blockquote>
> </blockquote>
> </pre>
> </blockquote>
> <br>
> </body>
> </html>
> Attachment decoded: untitled-3.htm
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #83273 is a reply to message #83257] Fri, 11 May 2007 08:31 Go to previous messageGo to next message
--------------010208080105080404000706
Anthony,
There isn't actually a question in your note so I'm not sure if you are
trying to ask one...
Do you have explicit EReferences for both ends of the relationship? Have
you made the container side non-transient? And have you made both ends
proxy resolving?
Anthony wrote:
> Merks,
> Anthony
>> Anthony,
>>> @build.eclipse.org:
>>> Merks,
>>> Thanks.
>>> Anthony
>>>> Anthony,
>>> containment
>>>> in to
>>> a
>>> need
>>>> a resource.
>>>> Anthony wrote:
>>>>> Hi,
>>>>> removal.
>>>>> Anthony
>> <html>
>> <head>
>> </head>
>> Anthony,<br>
>> <br>
>> <br>
>> <br>
>> type="cite">
>> @build.eclipse.org:
>> Merks,
>> Thanks.
>> Anthony
>> </pre>
>> </pre>
>> </blockquote>
>> </pre>
>> eContainer and
>> </pre>
>> </blockquote>
>> </pre>
>> already in a
>> </pre>
>> </blockquote>
>> </pre>
>> it's indirectly
>> resource.
>> Anthony wrote:
>> </pre>
>> <pre wrap="">Hi,
>> Anthony
>> </pre>
>> </blockquote>
>> </blockquote>
>> </pre>
>> </blockquote>
>> <br>
>> </body>
>> </html>
<html>
<head>
</head>
Anthony,<br>
<br>
trying to ask one...<br>
<br>
Have you made the container side non-transient? And have you made both
ends proxy resolving?<br>
<br>
<br>
Anthony wrote:
<blockquote cite="midXns990FCFB6F89BDAnthonyLee@206.191.52.34"
type="cite">
<pre wrap="">Merks,
Anthony
</pre>
Anthony wrote:
</pre>
@build.eclipse.org:
Merks,
Thanks.
Anthony
</pre>
</pre>
</blockquote>
<pre wrap="">containment
</pre>
in to
</pre>
</blockquote>
<pre wrap="">a
</pre>
</pre>
</blockquote>
<pre wrap="">need
</pre>
a resource.
Anthony wrote:
</pre>
<pre wrap="">Hi,
removal.
Anthony
</pre>
</blockquote>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
<pre wrap="">
&lt;!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"&gt;
&lt;html&gt;
&lt;head&gt;
&lt;meta content="text/html;charset=ISO-8859-1"
http-equiv="Content-Type"&gt;
&lt;/head&gt;
&lt;body bgcolor="#ffffff" text="#000000"&gt;
Anthony,&lt;br&gt;
&lt;br&gt;
the eOpposite of the containment feature).&lt;br&gt;
&lt;br&gt;
&lt;br&gt;
Anthony wrote:
&lt;blockquote cite=<a class="moz-txt-link-rfc2396E" href="mailto:midXns990FC81B5A375AnthonyLee@206.191.52.34">"midXns990FC81B5A375AnthonyLee@206.191.52.34"</a>
type="cite"&gt;
&lt;pre wrap=""&gt;Ed Merks &lt;a class="moz-txt-link-rfc2396E"
href=<a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">"mailto:merks@ca.ibm.com"</a>&gt;&amp;lt;merks@ca.ibm.com&amp;gt;&lt;/a&gt; wrote in
&lt;a class="moz-txt-link-freetext"
href=<a class="moz-txt-link-rfc2396E" href="news:f21jgu$ihr$1">"news:f21jgu$ihr$1"</a>&gt; <a class="moz-txt-link-freetext" href="news:f21jgu$ihr$1">news:f21jgu$ihr$1</a>&lt;/a&gt;
@build.eclipse.org:
Merks,
Thanks.
Anthony
&lt;/pre&gt;
&lt;blockquote type="cite"&gt;
&lt;pre wrap=""&gt;Anthony,
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;pre wrap=""&gt;&lt;!----&gt;containment
&lt;/pre&gt;
&lt;pre wrap=""&gt;reference (EReference.isResolveProxies == true),
eContainer and
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;pre wrap=""&gt;&lt;!----&gt;a
&lt;/pre&gt;
&lt;pre wrap=""&gt;separate resource. Note that if Products parent is
already in a
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;pre wrap=""&gt;&lt;!----&gt;need
&lt;/pre&gt;
&lt;pre wrap=""&gt;to put the Product directly in the resource since
it's indirectly
resource.
Anthony wrote:
&lt;/pre&gt;
&lt;pre wrap=""&gt;Hi,
Anthony
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;br&gt;
&lt;/body&gt;
&lt;/html&gt;
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------010208080105080404000706--
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #83290 is a reply to message #83273] Fri, 11 May 2007 08:46 Go to previous messageGo to next message
Merks,
Yes, both ends has explicit EReferences and the container side is
transient, both ends are not proxy resolving.
The question is :
When I try to add new element which has set eContainer into resource
contents , the eContainer is removed by inverseAdd(). So I don't know
how to save these elements.
Anthony
> Anthony,
> are trying to ask one...
> Anthony wrote:
>> Merks,
>> choose
>> the child to the parent) and load the one-to-many relation (parent to
>> child) on demand through an explicit query (make the many-reference
>> from the parent to the child transient). Adding to the parent is then
>> done by setting the parent feature in the child.
>> Anthony
>>> Anthony,
>>> set as transient implies you don't want to serialize it), but in the
>>> XMI serialization, to serialize a reference to the container, you
>>> need to define a non-transient container feature (i.e., an
>>> EReference that's the eOpposite of the containment feature).
>>>> @build.eclipse.org:
>>>> Merks,
>>>> Thanks.
>>>> Anthony
>>>>> Anthony,
>>>> containment
>>>>> EObject container and be contained directly by a resource's
>>>>> getContents. Only for proxy resolving containment is it possible
>>>> a
>>>>> no
>>>> need
>>>>> in a resource.
>>>>> Anthony wrote:
>>>>>> Hi,
>>>>>> removal.
>>>>>> Anthony
>>> <html>
>>> <head>
>>> </head>
>>> Anthony,<br>
>>> <br>
>>> EReference that's the eOpposite of the containment feature).<br>
>>> <br>
>>> <br>
>>> type="cite">
>>> @build.eclipse.org:
>>> Merks,
>>> Thanks.
>>> Anthony
>>> </pre>
>>> </pre>
>>> </blockquote>
>>> </pre>
>>> eContainer and
>>> in to
>>> </pre>
>>> </blockquote>
>>> </pre>
>>> already in a
>>> </pre>
>>> </blockquote>
>>> </pre>
>>> it's indirectly
>>> a resource.
>>> Anthony wrote:
>>> </pre>
>>> <pre wrap="">Hi,
>>> Anthony
>>> </pre>
>>> </blockquote>
>>> </blockquote>
>>> </pre>
>>> </blockquote>
>>> <br>
>>> </body>
>>> </html>
> <html>
> <head>
> </head>
> Anthony,<br>
> <br>
> are trying to ask one...<br>
> <br>
> <br>
> <br>
> type="cite">
> <pre wrap="">Merks,
> choose
> Anthony
> </pre>
> Anthony wrote:
> </pre>
> @build.eclipse.org:
> Merks,
> Thanks.
> Anthony
> </pre>
> </pre>
> </blockquote>
> </pre>
> eContainer and
> in to
> </pre>
> </blockquote>
> <pre wrap="">a
> </pre>
> is already in a
> </pre>
> </blockquote>
> <pre wrap="">need
> </pre>
> it's indirectly
> a resource.
> Anthony wrote:
> </pre>
> <pre wrap="">Hi,
> removal.
> Anthony
> </pre>
> </blockquote>
> </blockquote>
> <pre wrap="">
> </pre>
> </blockquote>
> <pre wrap="">
> &lt;html&gt;
> &lt;head&gt;
> &lt;/head&gt;
> Anthony,&lt;br&gt;
> &lt;br&gt;
> &lt;br&gt;
> &lt;br&gt;
> type="cite"&gt;
&amp;
> lt;merks@ca.ibm.com&amp;gt;&lt;/a&gt; wrote in &lt;a
> class="moz-txt-link-freetext" href=<a class="moz-txt-link-rfc2396E"
> @build.eclipse.org:
> Merks,
> Thanks.
> Anthony
> &lt;/pre&gt;
> &lt;/pre&gt;
> &lt;/blockquote&gt;
> &lt;/pre&gt;
> &lt;/pre&gt;
> &lt;/blockquote&gt;
> &lt;/pre&gt;
> &lt;/pre&gt;
> &lt;/blockquote&gt;
> &lt;/pre&gt;
> resource.
> Anthony wrote:
> &lt;/pre&gt;
> Anthony
> &lt;/pre&gt;
> &lt;/blockquote&gt;
> &lt;/blockquote&gt;
> &lt;/pre&gt;
> &lt;/blockquote&gt;
> &lt;br&gt;
> &lt;/body&gt;
> &lt;/html&gt;
> </pre>
> </blockquote>
> </pre>
> </blockquote>
> <br>
> </body>
> </html>
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #83310 is a reply to message #83290] Fri, 11 May 2007 08:50 Go to previous messageGo to next message
--------------010504090600060301080902
Anthony,
If you really need the parent and the child to be in separate resources
then you must make both ends proxy resolving, i.e., set
EReference.isResolveProxies to true. And I'm not sure how Teneo
handles it, but I imagine that a transient feature will not be
persisted, so probably you want to make the container side non-transient...
Anthony wrote:
> Merks,
> The question is :
> Anthony
>> Anthony,
>> Anthony wrote:
>>> Merks,
>>> choose
>>> Anthony
>>>> Anthony,
>>>>> @build.eclipse.org:
>>>>> Merks,
>>>>> Thanks.
>>>>> Anthony
>>>>>> Anthony,
>>>>> containment
>>>>> a
>>>>>> no
>>>>> need
>>>>>> in a resource.
>>>>>> Anthony wrote:
>>>>>>> Hi,
>>>>>>> removal.
>>>>>>> Anthony
>>>> <html>
>>>> <head>
>>>> </head>
>>>> Anthony,<br>
>>>> <br>
>>>> <br>
>>>> <br>
>>>> type="cite">
>>>> @build.eclipse.org:
>>>> Merks,
>>>> Thanks.
>>>> Anthony
>>>> </pre>
>>>> </pre>
>>>> </blockquote>
>>>> </pre>
>>>> eContainer and
>>>> in to
>>>> </pre>
>>>> </blockquote>
>>>> </pre>
>>>> already in a
>>>> </pre>
>>>> </blockquote>
>>>> </pre>
>>>> it's indirectly
>>>> a resource.
>>>> Anthony wrote:
>>>> </pre>
>>>> <pre wrap="">Hi,
>>>> Anthony
>>>> </pre>
>>>> </blockquote>
>>>> </blockquote>
>>>> </pre>
>>>> </blockquote>
>>>> <br>
>>>> </body>
>>>> </html>
>> <html>
>> <head>
>> </head>
>> Anthony,<br>
>> <br>
>> <br>
>> <br>
>> <br>
>> type="cite">
>> <pre wrap="">Merks,
>> choose
>> Anthony
>> </pre>
>> Anthony wrote:
>> </pre>
>> @build.eclipse.org:
>> Merks,
>> Thanks.
>> Anthony
>> </pre>
>> </pre>
>> </blockquote>
>> </pre>
>> eContainer and
>> in to
>> </pre>
>> </blockquote>
>> <pre wrap="">a
>> </pre>
>> is already in a
>> </pre>
>> </blockquote>
>> <pre wrap="">need
>> </pre>
>> it's indirectly
>> a resource.
>> Anthony wrote:
>> </pre>
>> <pre wrap="">Hi,
>> removal.
>> Anthony
>> </pre>
>> </blockquote>
>> </blockquote>
>> <pre wrap="">
>> </pre>
>> </blockquote>
>> <pre wrap="">
>> &lt;html&gt;
>> &lt;head&gt;
>> &lt;/head&gt;
>> Anthony,&lt;br&gt;
>> &lt;br&gt;
>> &lt;br&gt;
>> &lt;br&gt;
>> type="cite"&gt;
> &amp;
>> @build.eclipse.org:
>> Merks,
>> Thanks.
>> Anthony
>> &lt;/pre&gt;
>> &lt;/pre&gt;
>> &lt;/blockquote&gt;
>> &lt;/pre&gt;
>> &lt;/pre&gt;
>> &lt;/blockquote&gt;
>> &lt;/pre&gt;
>> &lt;/pre&gt;
>> &lt;/blockquote&gt;
>> &lt;/pre&gt;
>> resource.
>> Anthony wrote:
>> &lt;/pre&gt;
>> Anthony
>> &lt;/pre&gt;
>> &lt;/blockquote&gt;
>> &lt;/blockquote&gt;
>> &lt;/pre&gt;
>> &lt;/blockquote&gt;
>> &lt;br&gt;
>> &lt;/body&gt;
>> &lt;/html&gt;
>> </pre>
>> </blockquote>
>> </pre>
>> </blockquote>
>> <br>
>> </body>
>> </html>
<html>
<head>
</head>
Anthony,<br>
<br>
EReference.isResolveProxies to true. &nbsp; And I'm not sure how Teneo
non-transient...<br>
<br>
<br>
Anthony wrote:
<blockquote cite="midXns990FD32108BCCAnthonyLee@206.191.52.34"
type="cite">
<pre wrap="">Merks,
The question is :
Anthony
</pre>
Anthony wrote:
</pre>
<pre wrap="">Merks,
choose
Anthony
</pre>
Anthony wrote:
</pre>
@build.eclipse.org:
Merks,
Thanks.
Anthony
</pre>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
<pre wrap="">a
</pre>
no
</pre>
</blockquote>
<pre wrap="">need
</pre>
in a resource.
Anthony wrote:
</pre>
<pre wrap="">Hi,
removal.
Anthony
</pre>
</blockquote>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
<pre wrap="">Attachment decoded: untitled-2.txt
&lt;html&gt;
&lt;head&gt;
&lt;/head&gt;
Anthony,&lt;br&gt;
&lt;br&gt;
EReference that's the eOpposite of the containment feature).&lt;br&gt;
&lt;br&gt;
&lt;br&gt;
type="cite"&gt;
in &lt;a class="moz-txt-link-freetext"
@build.eclipse.org:
Merks,
Thanks.
Anthony
&lt;/pre&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
eContainer and
in to
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
already in a
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
it's indirectly
a resource.
Anthony wrote:
&lt;/pre&gt;
Anthony
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;br&gt;
&lt;/body&gt;
&lt;/html&gt;
</pre>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
<pre wrap="">
&lt;html&gt;
&lt;head&gt;
&lt;/head&gt;
Anthony,&lt;br&gt;
&lt;br&gt;
are trying to ask one...&lt;br&gt;
&lt;br&gt;
ends proxy resolving?&lt;br&gt;
&lt;br&gt;
&lt;br&gt;
Anthony wrote:
&lt;blockquote cite=<a class="moz-txt-link-rfc2396E" href="mailto:midXns990FCFB6F89BDAnthonyLee@206.191.52.34">"midXns990FCFB6F89BDAnthonyLee@206.191.52.34"</a>
type="cite"&gt;
&lt;pre wrap=""&gt;Merks,
choose
Anthony
&lt;/pre&gt;
Anthony wrote:
&lt;/pre&gt;
wrote in &lt;a class="moz-txt-link-freetext"
@build.eclipse.org:
Merks,
Thanks.
Anthony
&lt;/pre&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;pre wrap=""&gt;containment
&lt;/pre&gt;
eContainer and
in to
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;pre wrap=""&gt;a
&lt;/pre&gt;
is already in a
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;pre wrap=""&gt;need
&lt;/pre&gt;
it's indirectly
a resource.
Anthony wrote:
&lt;/pre&gt;
removal.
Anthony
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/blockquote&gt;
&lt;pre wrap=""&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;pre wrap=""&gt;
&amp;lt;!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"&amp;gt;
&amp;lt;html&amp;gt;
&amp;lt;head&amp;gt;
&amp;lt;meta content="text/html;charset=ISO-8859-1"
http-equiv="Content-Type"&amp;gt;
&amp;lt;/head&amp;gt;
&amp;lt;body bgcolor="#ffffff" text="#000000"&amp;gt;
Anthony,&amp;lt;br&amp;gt;
&amp;lt;br&amp;gt;
the eOpposite of the containment feature).&amp;lt;br&amp;gt;
&amp;lt;br&amp;gt;
&amp;lt;br&amp;gt;
Anthony wrote:
&amp;lt;blockquote cite=&lt;a class="moz-txt-link-rfc2396E"
href="<a class="moz-txt-link-freetext" href="mailto:midXns990FC81B5A375AnthonyLee@">mailto:midXns990FC81B5A375AnthonyLee@ </a>
</pre>
</blockquote>
<pre wrap=""><!---->206.191.52.34"&gt;"midXns990FC8
</pre>
<pre wrap=""><a class="moz-txt-link-abbreviated" href="mailto:1B5A375AnthonyLee@206.191.52.34">1B5A375AnthonyLee@206.191.52.34</a>"&lt;/a&gt;
type="cite"&amp;gt;
&amp;lt;pre wrap=""&amp;gt;Ed Merks &amp;lt;a class="moz-txt-link-rfc2396E"
href=&lt;a class="moz-txt-link-rfc2396E"
href=<a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">"mailto:merks@ca.ibm.com"</a>&gt;<a class="moz-txt-link-rfc2396E" href="mailto:merks@ca..ibm.com">"mailto:merks@ca.ibm.com"</a>&lt;/a&gt;&amp;gt;
</pre>
</blockquote>
<pre wrap=""><!---->&amp;amp;
</pre>
<pre wrap=""> <a class="moz-txt-link-abbreviated" href="mailto:lt;merks@ca.ibm.com&amp;gt;&lt;/a&gt">lt;merks@ca.ibm.com&amp;amp;gt;&amp;lt;/a&amp;gt</a>; wrote in &amp;lt;a
class="moz-txt-link-freetext" href=&lt;a class="moz-txt-link-rfc2396E"
href=<a class="moz-txt-link-rfc2396E" href="news:f21jgu$ihr$1">"news:f21jgu$ihr$1"</a>&gt; <a class="moz-txt-link-rfc2396E" href="news:f21jgu$ihr$1">"news:f21jgu$ihr$1"</a>&lt;/a&gt;&amp;gt;&lt;a
href=<a class="moz-txt-link-rfc2396E" href="news:f21jgu$ihr$1">"news:f21jgu$ihr$1"</a>&gt; <a class="moz-txt-link-freetext" href="news:f21jgu$ihr$1">news:f21jgu$ihr$1</a>&lt;/a&gt;&amp;lt;/a&amp;gt;
@build.eclipse.org:
Merks,
Thanks.
Anthony
&amp;lt;/pre&amp;gt;
&amp;lt;blockquote type="cite"&amp;gt;
&amp;lt;pre wrap=""&amp;gt;Anthony,
&amp;lt;/blockquote&amp;gt;
&amp;lt;pre wrap=""&amp;gt;&amp;lt;!----&amp;gt;containment
&amp;lt;pre wrap=""&amp;gt;reference (EReference.isResolveProxies ==
&amp;lt;pre wrap=""&amp;gt;&amp;lt;!----&amp;gt;a
&amp;lt;pre wrap=""&amp;gt;separate resource. Note that if Products
&amp;lt;pre wrap=""&amp;gt;&amp;lt;!----&amp;gt;need
&amp;lt;pre wrap=""&amp;gt;to put the Product directly in the resource
resource.
&amp;lt;pre wrap=""&amp;gt;Hi,
Anthony
&amp;lt;br&amp;gt;
&amp;lt;/body&amp;gt;
&amp;lt;/html&amp;gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;br&gt;
&lt;/body&gt;
&lt;/html&gt;
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------010504090600060301080902--
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #83325 is a reply to message #83310] Fri, 11 May 2007 10:12 Go to previous messageGo to next message
Anthony,
I am not sure but does your first remark:
not already solve this issue? It seems like what Ed suggests.
gr. Martin
Ed Merks wrote:
> Anthony,
> Anthony wrote:
>> Merks,
>> The question is :
>> Anthony
>>> Anthony,
>>> Anthony wrote:
>>>> Merks,
>>>> choose
>>>> Anthony
>>>>> Anthony,
>>>>>> @build.eclipse.org:
>>>>>> Merks,
>>>>>> Thanks.
>>>>>> Anthony
>>>>>>> Anthony,
>>>>>> containment
>>>>>> a
>>>>>>> no
>>>>>> need
>>>>>>> in a resource.
>>>>>>> Anthony wrote:
>>>>>>>> Hi,
>>>>>>>> removal.
>>>>>>>> Anthony
>>>>> <html>
>>>>> <head>
>>>>> </head>
>>>>> Anthony,<br>
>>>>> <br>
>>>>> <br>
>>>>> <br>
>>>>> type="cite">
>>>>> @build.eclipse.org:
>>>>> Merks,
>>>>> Thanks.
>>>>> Anthony
>>>>> </pre>
>>>>> </pre>
>>>>> </blockquote>
>>>>> </pre>
>>>>> eContainer and
>>>>> in to
>>>>> </pre>
>>>>> </blockquote>
>>>>> </pre>
>>>>> already in a
>>>>> </pre>
>>>>> </blockquote>
>>>>> </pre>
>>>>> it's indirectly
>>>>> a resource.
>>>>> Anthony wrote:
>>>>> </pre>
>>>>> <pre wrap="">Hi,
>>>>> Anthony
>>>>> </pre>
>>>>> </blockquote>
>>>>> </blockquote>
>>>>> </pre>
>>>>> </blockquote>
>>>>> <br>
>>>>> </body>
>>>>> </html>
>>> <html>
>>> <head>
>>> </head>
>>> Anthony,<br>
>>> <br>
>>> <br>
>>> <br>
>>> <br>
>>> type="cite">
>>> <pre wrap="">Merks,
>>> choose
>>> Anthony
>>> </pre>
>>> Anthony wrote:
>>> </pre>
>>> @build.eclipse.org:
>>> Merks,
>>> Thanks.
>>> Anthony
>>> </pre>
>>> </pre>
>>> </blockquote>
>>> </pre>
>>> eContainer and
>>> in to
>>> </pre>
>>> </blockquote>
>>> <pre wrap="">a
>>> </pre>
>>> is already in a
>>> </pre>
>>> </blockquote>
>>> <pre wrap="">need
>>> </pre>
>>> it's indirectly
>>> a resource.
>>> Anthony wrote:
>>> </pre>
>>> <pre wrap="">Hi,
>>> removal.
>>> Anthony
>>> </pre>
>>> </blockquote>
>>> </blockquote>
>>> <pre wrap="">
>>> </pre>
>>> </blockquote>
>>> <pre wrap="">
>>> &lt;html&gt;
>>> &lt;head&gt;
>>> &lt;/head&gt;
>>> Anthony,&lt;br&gt;
>>> &lt;br&gt;
>>> &lt;br&gt;
>>> &lt;br&gt;
>>> type="cite"&gt;
>> &amp;
>>> @build.eclipse.org:
>>> Merks,
>>> Thanks.
>>> Anthony
>>> &lt;/pre&gt;
>>> &lt;/pre&gt;
>>> &lt;/blockquote&gt;
>>> &lt;/pre&gt;
>>> &lt;/pre&gt;
>>> &lt;/blockquote&gt;
>>> &lt;/pre&gt;
>>> &lt;/pre&gt;
>>> &lt;/blockquote&gt;
>>> &lt;/pre&gt;
>>> resource.
>>> Anthony wrote:
>>> &lt;/pre&gt;
>>> Anthony
>>> &lt;/pre&gt;
>>> &lt;/blockquote&gt;
>>> &lt;/blockquote&gt;
>>> &lt;/pre&gt;
>>> &lt;/blockquote&gt;
>>> &lt;br&gt;
>>> &lt;/body&gt;
>>> &lt;/html&gt;
>>> </pre>
>>> </blockquote>
>>> </pre>
>>> </blockquote>
>>> <br>
>>> </body>
>>> </html>
The Netherlands
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #83367 is a reply to message #83325] Sat, 12 May 2007 04:25 Go to previous messageGo to next message
Martin,
In my xxx.genmodel's properties, there is 'Contaiment Proxies'
property in 'Model' section, the description for this property
is "Whether to respect the resolveProxies setting for containment
references" and its default value is 'false'.
After I changed this value as 'true' , everything is OK.
Thanks .
Anthony
> Anthony,
> gr. Martin
> Ed Merks wrote:
>> Anthony,
>> resources then you must make both ends proxy resolving, i.e., set
>> non-transient...
>> Anthony wrote:
>>> Merks,
>>> The question is :
>>> resource
>>> know how to save these elements.
>>> Anthony
>>>> Anthony,
>>>> both ends proxy resolving?
>>>> Anthony wrote:
>>>>> Merks,
>>>>> choose
>>>>> from the child to the parent) and load the one-to-many relation
>>>>> (parent to child) on demand through an explicit query (make the
>>>>> many-reference from the parent to the child transient). Adding to
>>>>> the parent is then done by setting the parent feature in the
>>>>> child.
>>>>> Anthony
>>>>>> Anthony,
>>>>>> is set as transient implies you don't want to serialize it), but
>>>>>> in the XMI serialization, to serialize a reference to the
>>>>>> container, you need to define a non-transient container feature
>>>>>> (i.e., an EReference that's the eOpposite of the containment
>>>>>> feature).
>>>>>>> @build.eclipse.org:
>>>>>>> Merks,
>>>>>>> Thanks.
>>>>>>> Anthony
>>>>>>>> Anthony,
>>>>>>> containment
>>>>>>> a
>>>>>>>> a resource then product.eResource() will be non-null, and there
>>>>>>>> is no
>>>>>>> need
>>>>>>>> indirectly contained in the resource by virtue of the parent
>>>>>>>> being contained in a resource.
>>>>>>>> Anthony wrote:
>>>>>>>>> Hi,
>>>>>>>>> many-To-one
>>>>>>>>> mode
>>>>>>>>> removal.
>>>>>>>>> Anthony
>>>>>> <html>
>>>>>> <head>
>>>>>> </head>
>>>>>> Anthony,<br>
>>>>>> <br>
>>>>>> feature).<br> <br>
>>>>>> <br>
>>>>>> type="cite">
>>>>>> @build.eclipse.org:
>>>>>> Merks,
>>>>>> Thanks.
>>>>>> Anthony
>>>>>> </pre>
>>>>>> </pre>
>>>>>> </blockquote>
>>>>>> </pre>
>>>>>> eContainer and
>>>>>> </pre>
>>>>>> </blockquote>
>>>>>> </pre>
>>>>>> is already in a
>>>>>> no
>>>>>> </pre>
>>>>>> </blockquote>
>>>>>> </pre>
>>>>>> in a resource.
>>>>>> Anthony wrote:
>>>>>> </pre>
>>>>>> <pre wrap="">Hi,
>>>>>> removal.
>>>>>> Anthony
>>>>>> </pre>
>>>>>> </blockquote>
>>>>>> </blockquote>
>>>>>> </pre>
>>>>>> </blockquote>
>>>>>> <br>
>>>>>> </body>
>>>>>> </html>
>>>> <html>
>>>> <head>
>>>> </head>
>>>> Anthony,<br>
>>>> <br>
>>>> <br>
>>>> both ends proxy resolving?<br>
>>>> <br>
>>>> <br>
>>>> type="cite">
>>>> <pre wrap="">Merks,
>>>> choose
>>>> the parent is then done by setting the parent feature in the child.
>>>> Anthony
>>>> </pre>
>>>> the XMI serialization, to serialize a reference to the container,
>>>> you need to define a non-transient container feature (i.e., an
>>>> Anthony wrote:
>>>> </pre>
>>>> @build.eclipse.org:
>>>> Merks,
>>>> Thanks.
>>>> Anthony
>>>> </pre>
>>>> </pre>
>>>> </blockquote>
>>>> </pre>
>>>> "child" in to
>>>> </pre>
>>>> </blockquote>
>>>> <pre wrap="">a
>>>> </pre>
>>>> </pre>
>>>> </blockquote>
>>>> <pre wrap="">need
>>>> </pre>
>>>> in a resource.
>>>> Anthony wrote:
>>>> </pre>
>>>> <pre wrap="">Hi,
>>>> removal.
>>>> Anthony
>>>> </pre>
>>>> </blockquote>
>>>> </blockquote>
>>>> <pre wrap="">
>>>> </pre>
>>>> </blockquote>
>>>> <pre wrap="">
>>>> Transitional//EN"&gt; &lt;html&gt;
>>>> &lt;head&gt;
>>>> &lt;/head&gt;
>>>> Anthony,&lt;br&gt;
>>>> &lt;br&gt;
>>>> feature).&lt;br&gt; &lt;br&gt;
>>>> &lt;br&gt;
>>>> type="cite"&gt;
>>> &amp;
>>>> @build.eclipse.org:
>>>> Merks,
>>>> Thanks.
>>>> Anthony
>>>> &lt;/pre&gt;
>>>> &lt;/pre&gt;
>>>> &lt;/blockquote&gt;
>>>> &lt;/pre&gt;
>>>> "child" in to
>>>> &lt;/pre&gt;
>>>> &lt;/blockquote&gt;
>>>> &lt;/pre&gt;
>>>> &lt;/pre&gt;
>>>> &lt;/blockquote&gt;
>>>> &lt;/pre&gt;
>>>> in a resource.
>>>> Anthony wrote:
>>>> &lt;/pre&gt;
>>>> removal.
>>>> Anthony
>>>> &lt;/pre&gt;
>>>> &lt;/blockquote&gt;
>>>> &lt;/blockquote&gt;
>>>> &lt;/pre&gt;
>>>> &lt;/blockquote&gt;
>>>> &lt;br&gt;
>>>> &lt;/body&gt;
>>>> &lt;/html&gt;
>>>> </pre>
>>>> </blockquote>
>>>> </pre>
>>>> </blockquote>
>>>> <br>
>>>> </body>
>>>> </html>
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #83384 is a reply to message #83367] Sat, 12 May 2007 07:17 Go to previous message
--------------030303050303080507020407
Anthony,
Sorry, I really should have thought to mention that. :-(
Anthony wrote:
> Martin,
> Thanks .
> Anthony
>> Anthony,
>> gr. Martin
>> Ed Merks wrote:
>>> Anthony,
>>> non-transient...
>>> Anthony wrote:
>>>> Merks,
>>>> The question is :
>>>> resource
>>>> Anthony
>>>>> Anthony,
>>>>> Anthony wrote:
>>>>>> Merks,
>>>>>> choose
>>>>>> child.
>>>>>> Anthony
>>>>>>> Anthony,
>>>>>>> feature).
>>>>>>>> @build.eclipse.org:
>>>>>>>> Merks,
>>>>>>>> Thanks.
>>>>>>>> Anthony
>>>>>>>>> Anthony,
>>>>>>>> containment
>>>>>>>> a
>>>>>>>>> is no
>>>>>>>> need
>>>>>>>>> Anthony wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> many-To-one
>>>>>>>>>> mode
>>>>>>>>>> removal.
>>>>>>>>>> Anthony
>>>>>>> <html>
>>>>>>> <head>
>>>>>>> </head>
>>>>>>> Anthony,<br>
>>>>>>> <br>
>>>>>>> feature).<br> <br>
>>>>>>> <br>
>>>>>>> type="cite">
>>>>>>> @build.eclipse.org:
>>>>>>> Merks,
>>>>>>> Thanks.
>>>>>>> Anthony
>>>>>>> </pre>
>>>>>>> </pre>
>>>>>>> </blockquote>
>>>>>>> </pre>
>>>>>>> eContainer and
>>>>>>> </pre>
>>>>>>> </blockquote>
>>>>>>> </pre>
>>>>>>> is already in a
>>>>>>> no
>>>>>>> </pre>
>>>>>>> </blockquote>
>>>>>>> </pre>
>>>>>>> in a resource.
>>>>>>> Anthony wrote:
>>>>>>> </pre>
>>>>>>> <pre wrap="">Hi,
>>>>>>> removal.
>>>>>>> Anthony
>>>>>>> </pre>
>>>>>>> </blockquote>
>>>>>>> </blockquote>
>>>>>>> </pre>
>>>>>>> </blockquote>
>>>>>>> <br>
>>>>>>> </body>
>>>>>>> </html>
>>>>> <html>
>>>>> <head>
>>>>> </head>
>>>>> Anthony,<br>
>>>>> <br>
>>>>> <br>
>>>>> <br>
>>>>> <br>
>>>>> type="cite">
>>>>> <pre wrap="">Merks,
>>>>> choose
>>>>> Anthony
>>>>> </pre>
>>>>> Anthony wrote:
>>>>> </pre>
>>>>> @build.eclipse.org:
>>>>> Merks,
>>>>> Thanks.
>>>>> Anthony
>>>>> </pre>
>>>>> </pre>
>>>>> </blockquote>
>>>>> </pre>
>>>>> "child" in to
>>>>> </pre>
>>>>> </blockquote>
>>>>> <pre wrap="">a
>>>>> </pre>
>>>>> </pre>
>>>>> </blockquote>
>>>>> <pre wrap="">need
>>>>> </pre>
>>>>> in a resource.
>>>>> Anthony wrote:
>>>>> </pre>
>>>>> <pre wrap="">Hi,
>>>>> removal.
>>>>> Anthony
>>>>> </pre>
>>>>> </blockquote>
>>>>> </blockquote>
>>>>> <pre wrap="">
>>>>> </pre>
>>>>> </blockquote>
>>>>> <pre wrap="">
>>>>> &lt;head&gt;
>>>>> &lt;/head&gt;
>>>>> Anthony,&lt;br&gt;
>>>>> &lt;br&gt;
>>>>> &lt;br&gt;
>>>>> type="cite"&gt;
>>>> &amp;
>>>>> @build.eclipse.org:
>>>>> Merks,
>>>>> Thanks.
>>>>> Anthony
>>>>> &lt;/pre&gt;
>>>>> &lt;/pre&gt;
>>>>> &lt;/blockquote&gt;
>>>>> &lt;/pre&gt;
>>>>> "child" in to
>>>>> &lt;/pre&gt;
>>>>> &lt;/blockquote&gt;
>>>>> &lt;/pre&gt;
>>>>> &lt;/pre&gt;
>>>>> &lt;/blockquote&gt;
>>>>> &lt;/pre&gt;
>>>>> in a resource.
>>>>> Anthony wrote:
>>>>> &lt;/pre&gt;
>>>>> removal.
>>>>> Anthony
>>>>> &lt;/pre&gt;
>>>>> &lt;/blockquote&gt;
>>>>> &lt;/blockquote&gt;
>>>>> &lt;/pre&gt;
>>>>> &lt;/blockquote&gt;
>>>>> &lt;br&gt;
>>>>> &lt;/body&gt;
>>>>> &lt;/html&gt;
>>>>> </pre>
>>>>> </blockquote>
>>>>> </pre>
>>>>> </blockquote>
>>>>> <br>
>>>>> </body>
>>>>> </html>
<html>
<head>
<title></title>
</head>
Anthony,<br>
<br>
Sorry, I really should have thought to mention that.&nbsp; :-(<br>
<br>
<br>
Anthony wrote:
<blockquote cite="midXns992EA6DCB84CDAnthonyLee@206.191.52.34"
type="cite">
<pre wrap="">Martin,
Thanks .
Anthony
</pre>
gr. Martin
Ed Merks wrote:
</pre>
non-transient...
Anthony wrote:
</pre>
<pre wrap="">Merks,
The question is :
resource
Anthony
</pre>
Anthony wrote:
</pre>
<pre wrap="">Merks,
choose
child.
Anthony
</pre>
feature).
Anthony wrote:
</pre>
@build.eclipse.org:
Merks,
Thanks.
Anthony
</pre>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
<pre wrap="">a
</pre>
is no
</pre>
</blockquote>
<pre wrap="">need
</pre>
Anthony wrote:
</pre>
<pre wrap="">Hi,
many-To-one
mode
removal.
Anthony
</pre>
</blockquote>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
&lt;html&gt;
&lt;head&gt;
&lt;/head&gt;
Anthony,&lt;br&gt;
&lt;br&gt;
&lt;br&gt;
type="cite"&gt;
@build.eclipse.org:
Merks,
Thanks.
Anthony
&lt;/pre&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
eContainer and
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
is already in a
no
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
in a resource.
Anthony wrote:
&lt;/pre&gt;
removal.
Anthony
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;br&gt;
&lt;/body&gt;
&lt;/html&gt;
</pre>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
&lt;html&gt;
&lt;head&gt;
&lt;/head&gt;
Anthony,&lt;br&gt;
&lt;br&gt;
&lt;br&gt;
both ends proxy resolving?&lt;br&gt;
&lt;br&gt;
&lt;br&gt;
type="cite"&gt;
choose
Anthony
&lt;/pre&gt;
Anthony wrote:
&lt;/pre&gt;
@build.eclipse.org:
Merks,
Thanks.
Anthony
&lt;/pre&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
"child" in to
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
in a resource.
Anthony wrote:
&lt;/pre&gt;
removal.
Anthony
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/blockquote&gt;
&lt;pre wrap=""&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;pre wrap=""&gt;
Transitional//EN"&amp;gt; &amp;lt;html&amp;gt;
&amp;lt;br&amp;gt;
feature).&amp;lt;br&amp;gt; &amp;lt;br&amp;gt;
&amp;lt;br&amp;gt;
</pre>
</blockquote>
<pre wrap="">206.191.52.34"&gt;"midXns990FC8
</pre>
type="cite"&amp;gt;
href=<a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">"mailto:merks@ca.ibm.com"</a>&gt;<a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">"mailto:merks@ca.ibm.com"</a>&lt;/a&gt;&amp;gt;
</pre>
</blockquote>
<pre wrap="">&amp;amp;
</pre>
@build.eclipse.org:
Merks,
Thanks.
Anthony
&amp;lt;/pre&am
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #606676 is a reply to message #83177] Fri, 11 May 2007 07:11 Go to previous message
gr. Martin
Anthony wrote:
> Anthony
The Netherlands
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #606677 is a reply to message #83177] Fri, 11 May 2007 07:19 Go to previous message
Anthony,
resource.
Anthony wrote:
> Anthony
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #606678 is a reply to message #83193] Fri, 11 May 2007 07:21 Go to previous message
@build.eclipse.org:
> gr. Martin
> Anthony wrote:
>> Hi,
>> Anthony
It is not.
saved in DB.
Anthony
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #606679 is a reply to message #83204] Fri, 11 May 2007 07:41 Go to previous message
@build.eclipse.org:
Merks,
Thanks.
Anthony
> Anthony,
containment
a
need
> resource.
> Anthony wrote:
>> Hi,
>> Anthony
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #606680 is a reply to message #83227] Fri, 11 May 2007 08:07 Go to previous message
Anthony,
> @build.eclipse.org:
> Merks,
> Thanks.
> Anthony
>> Anthony,
> containment
> a
> need
>> resource.
>> Anthony wrote:
>>> Hi,
>>> Anthony
<html>
<head>
</head>
Anthony,<br>
<br>
<br>
<br>
type="cite">
@build.eclipse.org:
Merks,
Thanks.
Anthony
</pre>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
resource.
Anthony wrote:
</pre>
<pre wrap="">Hi,
Anthony
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #606681 is a reply to message #83243] Fri, 11 May 2007 08:26 Go to previous message
Merks,
Anthony
> Anthony,
>> @build.eclipse.org:
>> Merks,
>> Thanks.
>> Anthony
>>> Anthony,
>> containment
>>> in to
>> a
>> need
>>> a resource.
>>> Anthony wrote:
>>>> Hi,
>>>> removal.
>>>> Anthony
> <html>
> <head>
> </head>
> Anthony,<br>
> <br>
> <br>
> <br>
> type="cite">
> @build.eclipse.org:
> Merks,
> Thanks.
> Anthony
> </pre>
> </pre>
> </blockquote>
> </pre>
> eContainer and
> </pre>
> </blockquote>
> </pre>
> already in a
> </pre>
> </blockquote>
> </pre>
> it's indirectly
> resource.
> Anthony wrote:
> </pre>
> <pre wrap="">Hi,
> Anthony
> </pre>
> </blockquote>
> </blockquote>
> </pre>
> </blockquote>
> <br>
> </body>
> </html>
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #606682 is a reply to message #83257] Fri, 11 May 2007 08:31 Go to previous message
Anthony,
proxy resolving?
Anthony wrote:
> Merks,
> Anthony
>> Anthony,
>>> @build.eclipse.org:
>>> Merks,
>>> Thanks.
>>> Anthony
>>>> Anthony,
>>> containment
>>>> in to
>>> a
>>> need
>>>> a resource.
>>>> Anthony wrote:
>>>>> Hi,
>>>>> removal.
>>>>> Anthony
>> <html>
>> <head>
>> </head>
>> Anthony,<br>
>> <br>
>> <br>
>> <br>
>> type="cite">
>> @build.eclipse.org:
>> Merks,
>> Thanks.
>> Anthony
>> </pre>
>> </pre>
>> </blockquote>
>> </pre>
>> eContainer and
>> </pre>
>> </blockquote>
>> </pre>
>> already in a
>> </pre>
>> </blockquote>
>> </pre>
>> it's indirectly
>> resource.
>> Anthony wrote:
>> </pre>
>> <pre wrap="">Hi,
>> Anthony
>> </pre>
>> </blockquote>
>> </blockquote>
>> </pre>
>> </blockquote>
>> <br>
>> </body>
>> </html>
<html>
<head>
</head>
Anthony,<br>
<br>
<br>
<br>
<br>
type="cite">
<pre wrap="">Merks,
Anthony
</pre>
Anthony wrote:
</pre>
@build.eclipse.org:
Merks,
Thanks.
Anthony
</pre>
</pre>
</blockquote>
</pre>
in to
</pre>
</blockquote>
<pre wrap="">a
</pre>
</pre>
</blockquote>
<pre wrap="">need
</pre>
a resource.
Anthony wrote:
</pre>
<pre wrap="">Hi,
removal.
Anthony
</pre>
</blockquote>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
<pre wrap="">
&lt;html&gt;
&lt;head&gt;
&lt;/head&gt;
Anthony,&lt;br&gt;
&lt;br&gt;
&lt;br&gt;
&lt;br&gt;
type="cite"&gt;
@build.eclipse.org:
Merks,
Thanks.
Anthony
&lt;/pre&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
eContainer and
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
already in a
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
it's indirectly
resource.
Anthony wrote:
&lt;/pre&gt;
Anthony
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;br&gt;
&lt;/body&gt;
&lt;/html&gt;
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #606683 is a reply to message #83273] Fri, 11 May 2007 08:46 Go to previous message
Merks,
The question is :
Anthony
> Anthony,
> Anthony wrote:
>> Merks,
>> choose
>> Anthony
>>> Anthony,
>>>> @build.eclipse.org:
>>>> Merks,
>>>> Thanks.
>>>> Anthony
>>>>> Anthony,
>>>> containment
>>>> a
>>>>> no
>>>> need
>>>>> in a resource.
>>>>> Anthony wrote:
>>>>>> Hi,
>>>>>> removal.
>>>>>> Anthony
>>> <html>
>>> <head>
>>> </head>
>>> Anthony,<br>
>>> <br>
>>> <br>
>>> <br>
>>> type="cite">
>>> @build.eclipse.org:
>>> Merks,
>>> Thanks.
>>> Anthony
>>> </pre>
>>> </pre>
>>> </blockquote>
>>> </pre>
>>> eContainer and
>>> in to
>>> </pre>
>>> </blockquote>
>>> </pre>
>>> already in a
>>> </pre>
>>> </blockquote>
>>> </pre>
>>> it's indirectly
>>> a resource.
>>> Anthony wrote:
>>> </pre>
>>> <pre wrap="">Hi,
>>> Anthony
>>> </pre>
>>> </blockquote>
>>> </blockquote>
>>> </pre>
>>> </blockquote>
>>> <br>
>>> </body>
>>> </html>
> <html>
> <head>
> </head>
> Anthony,<br>
> <br>
> <br>
> <br>
> <br>
> type="cite">
> <pre wrap="">Merks,
> choose
> Anthony
> </pre>
> Anthony wrote:
> </pre>
> @build.eclipse.org:
> Merks,
> Thanks.
> Anthony
> </pre>
> </pre>
> </blockquote>
> </pre>
> eContainer and
> in to
> </pre>
> </blockquote>
> <pre wrap="">a
> </pre>
> is already in a
> </pre>
> </blockquote>
> <pre wrap="">need
> </pre>
> it's indirectly
> a resource.
> Anthony wrote:
> </pre>
> <pre wrap="">Hi,
> removal.
> Anthony
> </pre>
> </blockquote>
> </blockquote>
> <pre wrap="">
> </pre>
> </blockquote>
> <pre wrap="">
> &lt;html&gt;
> &lt;head&gt;
> &lt;/head&gt;
> Anthony,&lt;br&gt;
> &lt;br&gt;
> &lt;br&gt;
> &lt;br&gt;
> type="cite"&gt;
&amp;
> @build.eclipse.org:
> Merks,
> Thanks.
> Anthony
> &lt;/pre&gt;
> &lt;/pre&gt;
> &lt;/blockquote&gt;
> &lt;/pre&gt;
> &lt;/pre&gt;
> &lt;/blockquote&gt;
> &lt;/pre&gt;
> &lt;/pre&gt;
> &lt;/blockquote&gt;
> &lt;/pre&gt;
> resource.
> Anthony wrote:
> &lt;/pre&gt;
> Anthony
> &lt;/pre&gt;
> &lt;/blockquote&gt;
> &lt;/blockquote&gt;
> &lt;/pre&gt;
> &lt;/blockquote&gt;
> &lt;br&gt;
> &lt;/body&gt;
> &lt;/html&gt;
> </pre>
> </blockquote>
> </pre>
> </blockquote>
> <br>
> </body>
> </html>
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #606684 is a reply to message #83290] Fri, 11 May 2007 08:50 Go to previous message
Anthony,
Anthony wrote:
> Merks,
> The question is :
> Anthony
>> Anthony,
>> Anthony wrote:
>>> Merks,
>>> choose
>>> Anthony
>>>> Anthony,
>>>>> @build.eclipse.org:
>>>>> Merks,
>>>>> Thanks.
>>>>> Anthony
>>>>>> Anthony,
>>>>> containment
>>>>> a
>>>>>> no
>>>>> need
>>>>>> in a resource.
>>>>>> Anthony wrote:
>>>>>>> Hi,
>>>>>>> removal.
>>>>>>> Anthony
>>>> <html>
>>>> <head>
>>>> </head>
>>>> Anthony,<br>
>>>> <br>
>>>> <br>
>>>> <br>
>>>> type="cite">
>>>> @build.eclipse.org:
>>>> Merks,
>>>> Thanks.
>>>> Anthony
>>>> </pre>
>>>> </pre>
>>>> </blockquote>
>>>> </pre>
>>>> eContainer and
>>>> in to
>>>> </pre>
>>>> </blockquote>
>>>> </pre>
>>>> already in a
>>>> </pre>
>>>> </blockquote>
>>>> </pre>
>>>> it's indirectly
>>>> a resource.
>>>> Anthony wrote:
>>>> </pre>
>>>> <pre wrap="">Hi,
>>>> Anthony
>>>> </pre>
>>>> </blockquote>
>>>> </blockquote>
>>>> </pre>
>>>> </blockquote>
>>>> <br>
>>>> </body>
>>>> </html>
>> <html>
>> <head>
>> </head>
>> Anthony,<br>
>> <br>
>> <br>
>> <br>
>> <br>
>> type="cite">
>> <pre wrap="">Merks,
>> choose
>> Anthony
>> </pre>
>> Anthony wrote:
>> </pre>
>> @build.eclipse.org:
>> Merks,
>> Thanks.
>> Anthony
>> </pre>
>> </pre>
>> </blockquote>
>> </pre>
>> eContainer and
>> in to
>> </pre>
>> </blockquote>
>> <pre wrap="">a
>> </pre>
>> is already in a
>> </pre>
>> </blockquote>
>> <pre wrap="">need
>> </pre>
>> it's indirectly
>> a resource.
>> Anthony wrote:
>> </pre>
>> <pre wrap="">Hi,
>> removal.
>> Anthony
>> </pre>
>> </blockquote>
>> </blockquote>
>> <pre wrap="">
>> </pre>
>> </blockquote>
>> <pre wrap="">
>> &lt;html&gt;
>> &lt;head&gt;
>> &lt;/head&gt;
>> Anthony,&lt;br&gt;
>> &lt;br&gt;
>> &lt;br&gt;
>> &lt;br&gt;
>> type="cite"&gt;
> &amp;
>> @build.eclipse.org:
>> Merks,
>> Thanks.
>> Anthony
>> &lt;/pre&gt;
>> &lt;/pre&gt;
>> &lt;/blockquote&gt;
>> &lt;/pre&gt;
>> &lt;/pre&gt;
>> &lt;/blockquote&gt;
>> &lt;/pre&gt;
>> &lt;/pre&gt;
>> &lt;/blockquote&gt;
>> &lt;/pre&gt;
>> resource.
>> Anthony wrote:
>> &lt;/pre&gt;
>> Anthony
>> &lt;/pre&gt;
>> &lt;/blockquote&gt;
>> &lt;/blockquote&gt;
>> &lt;/pre&gt;
>> &lt;/blockquote&gt;
>> &lt;br&gt;
>> &lt;/body&gt;
>> &lt;/html&gt;
>> </pre>
>> </blockquote>
>> </pre>
>> </blockquote>
>> <br>
>> </body>
>> </html>
<html>
<head>
</head>
Anthony,<br>
<br>
<br>
<br>
type="cite">
<pre wrap="">Merks,
The question is :
Anthony
</pre>
Anthony wrote:
</pre>
<pre wrap="">Merks,
choose
Anthony
</pre>
Anthony wrote:
</pre>
@build.eclipse.org:
Merks,
Thanks.
Anthony
</pre>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
<pre wrap="">a
</pre>
no
</pre>
</blockquote>
<pre wrap="">need
</pre>
in a resource.
Anthony wrote:
</pre>
<pre wrap="">Hi,
removal.
Anthony
</pre>
</blockquote>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
&lt;html&gt;
&lt;head&gt;
&lt;/head&gt;
Anthony,&lt;br&gt;
&lt;br&gt;
&lt;br&gt;
&lt;br&gt;
type="cite"&gt;
@build.eclipse.org:
Merks,
Thanks.
Anthony
&lt;/pre&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
eContainer and
in to
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
already in a
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
it's indirectly
a resource.
Anthony wrote:
&lt;/pre&gt;
Anthony
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;br&gt;
&lt;/body&gt;
&lt;/html&gt;
</pre>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
<pre wrap="">
&lt;html&gt;
&lt;head&gt;
&lt;/head&gt;
Anthony,&lt;br&gt;
&lt;br&gt;
&lt;br&gt;
&lt;br&gt;
&lt;br&gt;
type="cite"&gt;
choose
Anthony
&lt;/pre&gt;
Anthony wrote:
&lt;/pre&gt;
@build.eclipse.org:
Merks,
Thanks.
Anthony
&lt;/pre&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
eContainer and
in to
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
is already in a
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
it's indirectly
a resource.
Anthony wrote:
&lt;/pre&gt;
removal.
Anthony
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/blockquote&gt;
&lt;pre wrap=""&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;pre wrap=""&gt;
&amp;lt;br&amp;gt;
&amp;lt;br&amp;gt;
&amp;lt;br&amp;gt;
</pre>
</blockquote>
</pre>
type="cite"&amp;gt;
</pre>
</blockquote>
</pre>
@build.eclipse.org:
Merks,
Thanks.
Anthony
resource.
Anthony
&amp;lt;br&amp;gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;br&gt;
&lt;/body&gt;
&lt;/html&gt;
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #606685 is a reply to message #83310] Fri, 11 May 2007 10:12 Go to previous message
Anthony,
gr. Martin
Ed Merks wrote:
> Anthony,
> Anthony wrote:
>> Merks,
>> The question is :
>> Anthony
>>> Anthony,
>>> Anthony wrote:
>>>> Merks,
>>>> choose
>>>> Anthony
>>>>> Anthony,
>>>>>> @build.eclipse.org:
>>>>>> Merks,
>>>>>> Thanks.
>>>>>> Anthony
>>>>>>> Anthony,
>>>>>> containment
>>>>>> a
>>>>>>> no
>>>>>> need
>>>>>>> in a resource.
>>>>>>> Anthony wrote:
>>>>>>>> Hi,
>>>>>>>> removal.
>>>>>>>> Anthony
>>>>> <html>
>>>>> <head>
>>>>> </head>
>>>>> Anthony,<br>
>>>>> <br>
>>>>> <br>
>>>>> <br>
>>>>> type="cite">
>>>>> @build.eclipse.org:
>>>>> Merks,
>>>>> Thanks.
>>>>> Anthony
>>>>> </pre>
>>>>> </pre>
>>>>> </blockquote>
>>>>> </pre>
>>>>> eContainer and
>>>>> in to
>>>>> </pre>
>>>>> </blockquote>
>>>>> </pre>
>>>>> already in a
>>>>> </pre>
>>>>> </blockquote>
>>>>> </pre>
>>>>> it's indirectly
>>>>> a resource.
>>>>> Anthony wrote:
>>>>> </pre>
>>>>> <pre wrap="">Hi,
>>>>> Anthony
>>>>> </pre>
>>>>> </blockquote>
>>>>> </blockquote>
>>>>> </pre>
>>>>> </blockquote>
>>>>> <br>
>>>>> </body>
>>>>> </html>
>>> <html>
>>> <head>
>>> </head>
>>> Anthony,<br>
>>> <br>
>>> <br>
>>> <br>
>>> <br>
>>> type="cite">
>>> <pre wrap="">Merks,
>>> choose
>>> Anthony
>>> </pre>
>>> Anthony wrote:
>>> </pre>
>>> @build.eclipse.org:
>>> Merks,
>>> Thanks.
>>> Anthony
>>> </pre>
>>> </pre>
>>> </blockquote>
>>> </pre>
>>> eContainer and
>>> in to
>>> </pre>
>>> </blockquote>
>>> <pre wrap="">a
>>> </pre>
>>> is already in a
>>> </pre>
>>> </blockquote>
>>> <pre wrap="">need
>>> </pre>
>>> it's indirectly
>>> a resource.
>>> Anthony wrote:
>>> </pre>
>>> <pre wrap="">Hi,
>>> removal.
>>> Anthony
>>> </pre>
>>> </blockquote>
>>> </blockquote>
>>> <pre wrap="">
>>> </pre>
>>> </blockquote>
>>> <pre wrap="">
>>> &lt;html&gt;
>>> &lt;head&gt;
>>> &lt;/head&gt;
>>> Anthony,&lt;br&gt;
>>> &lt;br&gt;
>>> &lt;br&gt;
>>> &lt;br&gt;
>>> type="cite"&gt;
>> &amp;
>>> @build.eclipse.org:
>>> Merks,
>>> Thanks.
>>> Anthony
>>> &lt;/pre&gt;
>>> &lt;/pre&gt;
>>> &lt;/blockquote&gt;
>>> &lt;/pre&gt;
>>> &lt;/pre&gt;
>>> &lt;/blockquote&gt;
>>> &lt;/pre&gt;
>>> &lt;/pre&gt;
>>> &lt;/blockquote&gt;
>>> &lt;/pre&gt;
>>> resource.
>>> Anthony wrote:
>>> &lt;/pre&gt;
>>> Anthony
>>> &lt;/pre&gt;
>>> &lt;/blockquote&gt;
>>> &lt;/blockquote&gt;
>>> &lt;/pre&gt;
>>> &lt;/blockquote&gt;
>>> &lt;br&gt;
>>> &lt;/body&gt;
>>> &lt;/html&gt;
>>> </pre>
>>> </blockquote>
>>> </pre>
>>> </blockquote>
>>> <br>
>>> </body>
>>> </html>
The Netherlands
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #606688 is a reply to message #83325] Sat, 12 May 2007 04:25 Go to previous message
Martin,
Thanks .
Anthony
> Anthony,
> gr. Martin
> Ed Merks wrote:
>> Anthony,
>> non-transient...
>> Anthony wrote:
>>> Merks,
>>> The question is :
>>> resource
>>> Anthony
>>>> Anthony,
>>>> Anthony wrote:
>>>>> Merks,
>>>>> choose
>>>>> child.
>>>>> Anthony
>>>>>> Anthony,
>>>>>> feature).
>>>>>>> @build.eclipse.org:
>>>>>>> Merks,
>>>>>>> Thanks.
>>>>>>> Anthony
>>>>>>>> Anthony,
>>>>>>> containment
>>>>>>> a
>>>>>>>> is no
>>>>>>> need
>>>>>>>> Anthony wrote:
>>>>>>>>> Hi,
>>>>>>>>> many-To-one
>>>>>>>>> mode
>>>>>>>>> removal.
>>>>>>>>> Anthony
>>>>>> <html>
>>>>>> <head>
>>>>>> </head>
>>>>>> Anthony,<br>
>>>>>> <br>
>>>>>> feature).<br> <br>
>>>>>> <br>
>>>>>> type="cite">
>>>>>> @build.eclipse.org:
>>>>>> Merks,
>>>>>> Thanks.
>>>>>> Anthony
>>>>>> </pre>
>>>>>> </pre>
>>>>>> </blockquote>
>>>>>> </pre>
>>>>>> eContainer and
>>>>>> </pre>
>>>>>> </blockquote>
>>>>>> </pre>
>>>>>> is already in a
>>>>>> no
>>>>>> </pre>
>>>>>> </blockquote>
>>>>>> </pre>
>>>>>> in a resource.
>>>>>> Anthony wrote:
>>>>>> </pre>
>>>>>> <pre wrap="">Hi,
>>>>>> removal.
>>>>>> Anthony
>>>>>> </pre>
>>>>>> </blockquote>
>>>>>> </blockquote>
>>>>>> </pre>
>>>>>> </blockquote>
>>>>>> <br>
>>>>>> </body>
>>>>>> </html>
>>>> <html>
>>>> <head>
>>>> </head>
>>>> Anthony,<br>
>>>> <br>
>>>> <br>
>>>> <br>
>>>> <br>
>>>> type="cite">
>>>> <pre wrap="">Merks,
>>>> choose
>>>> Anthony
>>>> </pre>
>>>> Anthony wrote:
>>>> </pre>
>>>> @build.eclipse.org:
>>>> Merks,
>>>> Thanks.
>>>> Anthony
>>>> </pre>
>>>> </pre>
>>>> </blockquote>
>>>> </pre>
>>>> "child" in to
>>>> </pre>
>>>> </blockquote>
>>>> <pre wrap="">a
>>>> </pre>
>>>> </pre>
>>>> </blockquote>
>>>> <pre wrap="">need
>>>> </pre>
>>>> in a resource.
>>>> Anthony wrote:
>>>> </pre>
>>>> <pre wrap="">Hi,
>>>> removal.
>>>> Anthony
>>>> </pre>
>>>> </blockquote>
>>>> </blockquote>
>>>> <pre wrap="">
>>>> </pre>
>>>> </blockquote>
>>>> <pre wrap="">
>>>> &lt;head&gt;
>>>> &lt;/head&gt;
>>>> Anthony,&lt;br&gt;
>>>> &lt;br&gt;
>>>> &lt;br&gt;
>>>> type="cite"&gt;
>>> &amp;
>>>> @build.eclipse.org:
>>>> Merks,
>>>> Thanks.
>>>> Anthony
>>>> &lt;/pre&gt;
>>>> &lt;/pre&gt;
>>>> &lt;/blockquote&gt;
>>>> &lt;/pre&gt;
>>>> "child" in to
>>>> &lt;/pre&gt;
>>>> &lt;/blockquote&gt;
>>>> &lt;/pre&gt;
>>>> &lt;/pre&gt;
>>>> &lt;/blockquote&gt;
>>>> &lt;/pre&gt;
>>>> in a resource.
>>>> Anthony wrote:
>>>> &lt;/pre&gt;
>>>> removal.
>>>> Anthony
>>>> &lt;/pre&gt;
>>>> &lt;/blockquote&gt;
>>>> &lt;/blockquote&gt;
>>>> &lt;/pre&gt;
>>>> &lt;/blockquote&gt;
>>>> &lt;br&gt;
>>>> &lt;/body&gt;
>>>> &lt;/html&gt;
>>>> </pre>
>>>> </blockquote>
>>>> </pre>
>>>> </blockquote>
>>>> <br>
>>>> </body>
>>>> </html>
Re: [teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEL [message #606689 is a reply to message #83367] Sat, 12 May 2007 07:17 Go to previous message
Anthony,
Anthony wrote:
> Martin,
> Thanks .
> Anthony
>> Anthony,
>> gr. Martin
>> Ed Merks wrote:
>>> Anthony,
>>> non-transient...
>>> Anthony wrote:
>>>> Merks,
>>>> The question is :
>>>> resource
>>>> Anthony
>>>>> Anthony,
>>>>> Anthony wrote:
>>>>>> Merks,
>>>>>> choose
>>>>>> child.
>>>>>> Anthony
>>>>>>> Anthony,
>>>>>>> feature).
>>>>>>>> @build.eclipse.org:
>>>>>>>> Merks,
>>>>>>>> Thanks.
>>>>>>>> Anthony
>>>>>>>>> Anthony,
>>>>>>>> containment
>>>>>>>> a
>>>>>>>>> is no
>>>>>>>> need
>>>>>>>>> Anthony wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> many-To-one
>>>>>>>>>> mode
>>>>>>>>>> removal.
>>>>>>>>>> Anthony
>>>>>>> <html>
>>>>>>> <head>
>>>>>>> </head>
>>>>>>> Anthony,<br>
>>>>>>> <br>
>>>>>>> feature).<br> <br>
>>>>>>> <br>
>>>>>>> type="cite">
>>>>>>> @build.eclipse.org:
>>>>>>> Merks,
>>>>>>> Thanks.
>>>>>>> Anthony
>>>>>>> </pre>
>>>>>>> </pre>
>>>>>>> </blockquote>
>>>>>>> </pre>
>>>>>>> eContainer and
>>>>>>> </pre>
>>>>>>> </blockquote>
>>>>>>> </pre>
>>>>>>> is already in a
>>>>>>> no
>>>>>>> </pre>
>>>>>>> </blockquote>
>>>>>>> </pre>
>>>>>>> in a resource.
>>>>>>> Anthony wrote:
>>>>>>> </pre>
>>>>>>> <pre wrap="">Hi,
>>>>>>> removal.
>>>>>>> Anthony
>>>>>>> </pre>
>>>>>>> </blockquote>
>>>>>>> </blockquote>
>>>>>>> </pre>
>>>>>>> </blockquote>
>>>>>>> <br>
>>>>>>> </body>
>>>>>>> </html>
>>>>> <html>
>>>>> <head>
>>>>> </head>
>>>>> Anthony,<br>
>>>>> <br>
>>>>> <br>
>>>>> <br>
>>>>> <br>
>>>>> type="cite">
>>>>> <pre wrap="">Merks,
>>>>> choose
>>>>> Anthony
>>>>> </pre>
>>>>> Anthony wrote:
>>>>> </pre>
>>>>> @build.eclipse.org:
>>>>> Merks,
>>>>> Thanks.
>>>>> Anthony
>>>>> </pre>
>>>>> </pre>
>>>>> </blockquote>
>>>>> </pre>
>>>>> "child" in to
>>>>> </pre>
>>>>> </blockquote>
>>>>> <pre wrap="">a
>>>>> </pre>
>>>>> </pre>
>>>>> </blockquote>
>>>>> <pre wrap="">need
>>>>> </pre>
>>>>> in a resource.
>>>>> Anthony wrote:
>>>>> </pre>
>>>>> <pre wrap="">Hi,
>>>>> removal.
>>>>> Anthony
>>>>> </pre>
>>>>> </blockquote>
>>>>> </blockquote>
>>>>> <pre wrap="">
>>>>> </pre>
>>>>> </blockquote>
>>>>> <pre wrap="">
>>>>> &lt;head&gt;
>>>>> &lt;/head&gt;
>>>>> Anthony,&lt;br&gt;
>>>>> &lt;br&gt;
>>>>> &lt;br&gt;
>>>>> type="cite"&gt;
>>>> &amp;
>>>>> @build.eclipse.org:
>>>>> Merks,
>>>>> Thanks.
>>>>> Anthony
>>>>> &lt;/pre&gt;
>>>>> &lt;/pre&gt;
>>>>> &lt;/blockquote&gt;
>>>>> &lt;/pre&gt;
>>>>> "child" in to
>>>>> &lt;/pre&gt;
>>>>> &lt;/blockquote&gt;
>>>>> &lt;/pre&gt;
>>>>> &lt;/pre&gt;
>>>>> &lt;/blockquote&gt;
>>>>> &lt;/pre&gt;
>>>>> in a resource.
>>>>> Anthony wrote:
>>>>> &lt;/pre&gt;
>>>>> removal.
>>>>> Anthony
>>>>> &lt;/pre&gt;
>>>>> &lt;/blockquote&gt;
>>>>> &lt;/blockquote&gt;
>>>>> &lt;/pre&gt;
>>>>> &lt;/blockquote&gt;
>>>>> &lt;br&gt;
>>>>> &lt;/body&gt;
>>>>> &lt;/html&gt;
>>>>> </pre>
>>>>> </blockquote>
>>>>> </pre>
>>>>> </blockquote>
>>>>> <br>
>>>>> </body>
>>>>> </html>
<html>
<head>
<title></title>
</head>
Anthony,<br>
<br>
<br>
<br>
type="cite">
Thanks .
Anthony
</pre>
gr. Martin
Ed Merks wrote:
</pre>
non-transient...
Anthony wrote:
</pre>
<pre wrap="">Merks,
The question is :
resource
Anthony
</pre>
Anthony wrote:
</pre>
<pre wrap="">Merks,
choose
child.
Anthony
</pre>
feature).
Anthony wrote:
</pre>
@build.eclipse.org:
Merks,
Thanks.
Anthony
</pre>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
<pre wrap="">a
</pre>
is no
</pre>
</blockquote>
<pre wrap="">need
</pre>
Anthony wrote:
</pre>
<pre wrap="">Hi,
many-To-one
mode
removal.
Anthony
</pre>
</blockquote>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
&lt;html&gt;
&lt;head&gt;
&lt;/head&gt;
Anthony,&lt;br&gt;
&lt;br&gt;
&lt;br&gt;
type="cite"&gt;
@build.eclipse.org:
Merks,
Thanks.
Anthony
&lt;/pre&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
eContainer and
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
is already in a
no
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
in a resource.
Anthony wrote:
&lt;/pre&gt;
removal.
Anthony
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;br&gt;
&lt;/body&gt;
&lt;/html&gt;
</pre>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
&lt;html&gt;
&lt;head&gt;
&lt;/head&gt;
Anthony,&lt;br&gt;
&lt;br&gt;
&lt;br&gt;
&lt;br&gt;
&lt;br&gt;
type="cite"&gt;
choose
Anthony
&lt;/pre&gt;
Anthony wrote:
&lt;/pre&gt;
@build.eclipse.org:
Merks,
Thanks.
Anthony
&lt;/pre&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
"child" in to
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/pre&gt;
in a resource.
Anthony wrote:
&lt;/pre&gt;
removal.
Anthony
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;/blockquote&gt;
&lt;pre wrap=""&gt;
&lt;/pre&gt;
&lt;/blockquote&gt;
&lt;pre wrap=""&gt;
&amp;lt;br&amp;gt;
&amp;lt;br&amp;gt;
</pre>
</blockquote>
</pre>
type="cite"&amp;gt;
</pre>
</blockquote>
</pre>
@build.eclipse.org:
Merks,
Thanks.
Anthony
Previous Topic:update operation has failed
Next Topic:[Teneo] Integrating Teneo-Struts-Tomcat
Current Time: Sat Jul 26 18:58:41 EDT 2025
Powered by FUDForum. Page generated in 0.09529 seconds
