Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Is there a way to stop initialize a collection when I only want to add or remove an element?
[Teneo] Is there a way to stop initialize a collection when I only want to add or remove an element? [message #82885] Thu, 10 May 2007 06:54 Go to next message
When I want to add an element to a lazy collection, the collection is
initilized.
According to below Q&A,I set my collection's inverse attribute as "true",
But the collection still be initialized.
Has this issue something to do with Teneo's persistableEList?
How can I prevent this loading?
Q:Why does Hibernate always initialize a collection when I only want to add
A:Unfortunately the collections API defines method return values that may
only be computed by hitting the database. There are three exceptions to
this: Hibernate can add to a <bag>, <idbag> or <list> declared with
inverse="true" without initializing the collection; the return value must
always be true.
If you want to avoid extra database traffic (ie. in performance critical
code), refactor your model to use only many-to-one associations. This is
almost always possible. Then use queries in place of collection access.
Re: [Teneo] Is there a way to stop initialize a collection when I only want to add or remove an elem [message #82900 is a reply to message #82885] Thu, 10 May 2007 07:07 Go to previous messageGo to next message
Yes, this is is currently how Teneo works. You can enter a bugzilla for this but I am not sure if it
is solvable. Also I am currently very busy so it will be a probably 2 weeks before the next teneo
release.
As the hb faq says another option (if you control the model): then for the large collections you can
also choose to change them to many-to-one's (so only persist the reference from the child to the
parent) and load the one-to-many relation (parent to child) on demand through an explicit query
(make the many-reference from the parent to the child transient).
Adding to the parent is then done by setting the parent feature in the child.
gr. Martin
Anthony wrote:
> initilized.
> always be true.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Is there a way to stop initialize a collection when I only want to add or remove an elem [message #82916 is a reply to message #82900] Thu, 10 May 2007 07:12 Go to previous message
Martin Taal <mtaal@elver.org> wrote in
news:f1uueb$g3u$1@build.eclipse.org:
> for this but I am not sure if it is solvable. Also I am currently very
> busy so it will be a probably 2 weeks before the next teneo release.
> the large collections you can also choose to change them to
> through an explicit query (make the many-reference from the parent to
> the child transient). Adding to the parent is then done by setting the
> gr. Martin
> Anthony wrote:
>> Hi,
>> initilized.
>> "true", But the collection still be initialized.
>> === Q:Why does Hibernate always initialize a collection when I only
>> may only be computed by hitting the database. There are three
>> exceptions to this: Hibernate can add to a <bag>, <idbag> or <list>
>> declared with inverse="true" without initializing the collection; the
>> return value must always be true.
>> critical code), refactor your model to use only many-to-one
>> associations. This is almost always possible. Then use queries in
I see, Thanks .
Anthony
Re: [Teneo] Is there a way to stop initialize a collection when I only want to add or remove an elem [message #606656 is a reply to message #82885] Thu, 10 May 2007 07:07 Go to previous message
release.
gr. Martin
Anthony wrote:
> initilized.
> always be true.
The Netherlands
Re: [Teneo] Is there a way to stop initialize a collection when I only want to add or remove an elem [message #606657 is a reply to message #82900] Thu, 10 May 2007 07:12 Go to previous message
> gr. Martin
> Anthony wrote:
>> Hi,
>> initilized.
I see, Thanks .
Anthony
Previous Topic:[Teneo] Is there a way to stop initialize a collection when I only want to add or remove an element?
Next Topic:[Teneo] IdentifierCacheHandler and @Proxy annotation
Current Time: Sun Jul 27 03:23:07 EDT 2025
Powered by FUDForum. Page generated in 1.06636 seconds
