Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMFT examples and eclipse 3.2.2
EMFT examples and eclipse 3.2.2 [message #82791] Thu, 10 May 2007 15:14 Go to next message
Originally posted by: asma.charfi.com
Is the examples of EMFT validation and ocl interpreter example works with
Eclipse 3.2.2 ?
I installed EMFT (ocl,validation,query transaction) using the (software
updates_install new feature)in help menu after installing EMF 2.2.2
I also insatalled all the examples but when I validates models that did not
respect OCL constraints, the validation works normally!
is there any configuration which is not mention it in the exemples (i even
tried to run examples archives but i have the same problem)
thank you for helping me
Re: EMFT examples and eclipse 3.2.2 [message #82842 is a reply to message #82791] Thu, 10 May 2007 06:41 Go to previous messageGo to next message
Asma,
You already have a thread started in the OCL and EMF newsgroups about
this question. You're claiming below that things work normally. Is
that really your intent of the opposite of it? In any case, if there
are problems with OCL validation examples, it's best to ask about them
in the OCL newsgroup. Explain exactly what you tried and which specific
example isn't working.
> Eclipse 3.2.2 ?
Re: EMFT examples and eclipse 3.2.2 [message #83122 is a reply to message #82842] Fri, 11 May 2007 03:39 Go to previous message
hi Merks,
I did not ask the same question that I asked in the ocl group: (here I speak
about EMFT tutorial ) and when I said that validation works normally I mean
that I did not recieve an error message that I have to recieve.
thank you for your advice (asking to OCL group)
"Ed Merks" <merks@ca.ibm.com> a
Re: EMFT examples and eclipse 3.2.2 [message #606652 is a reply to message #82791] Thu, 10 May 2007 06:41 Go to previous message
Asma,
> Eclipse 3.2.2 ?
Re: EMFT examples and eclipse 3.2.2 [message #606671 is a reply to message #82842] Fri, 11 May 2007 03:39 Go to previous message
hi Merks,
Previous Topic:update operation has failed
Next Topic:[teneo] eContainer is set null in inverseAdd() when adding new element into Resource's contentEList
Current Time: Fri Jul 25 21:24:30 EDT 2025
Powered by FUDForum. Page generated in 0.27219 seconds
