Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo]lazy collection pagination
[Teneo]lazy collection pagination [message #82722] Thu, 10 May 2007 05:08 Go to next message
Since it is no effect to setMaxResult for the query 'select parent fetch
join parent.children ...' , I wonder if there is one way to let lazy
collection only return certain numbers of itetm.
I try to use parent.getChildren().iterator(),but once iterator.hasNext
() or iterator.next() get called, all the item are loaded.
Any workaround idea ?
Thanks in advance!
Anthony Lee
Re: [Teneo]lazy collection pagination [message #82723 is a reply to message #82722] Thu, 10 May 2007 05:18 Go to previous messageGo to next message
A quick google search turned up these two pages:
http://www.hibernate.org/118.html#A8
http://www.javalobby.org/java/forums/t43955.html
but, I am not sure if it works as Teneo implements its own persistable elist....
then Hibernate also has the lazy="extra" attribute on a list-mapping but this is not implemented yet
with Teneo (there is a bugzilla for this but I did not have time yet).
gr. Martin
Anthony wrote:
> Thanks in advance!
> Anthony Lee
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo]lazy collection pagination [message #82725 is a reply to message #82723] Thu, 10 May 2007 05:58 Go to previous messageGo to next message
Thank you for your tips.
According to http://www.javalobby.org/java/forums/t43955.html,
4 . At 12:46 PM on Aug 23, 2005, R.J. Lorimer wrote:
Reply
Re: Hibernate: Filter Collections
Sandro,
That's the beauty of filtered collections, when they are lazy, they don't
generate 2 select statements.
When you call owner.getPets() it simply gives you the
'PersistentCollection' from Hibernate, which doesn't actually invoke the
SQL until you use it (say via owner.getPets().iterator().next()). Because
of that, you can add a filter to it which is simply a way of adding
additional criteria to the SQL that will be invoked to initialize the
collection.
I create a method just like this:
public static List getPagingResult(Object collection, int beginIndex, int
pageSize){
final Query pagingFilter = sessionController.getSession().createFilter
(collection,"");
pagingFilter.setFirstResult(begin);
pagingFilter.setMaxResult(pageSize);
List pageContent = pagingFilter.list();
and then I try to use the lazy collection as the first parameter to call
this method.
But I got an exception :
org.hibernater.QueryException:The collection was unreferenced
In http://www.hibernate.org/117.html#A11, it says the reason is:
Collection filters are for filtering persistent collections, not query
results.
But it is persistent collection.
Anthony
Martin Taal <mtaal@elver.org> wrote in
news:f1uo0b$com$1@build.eclipse.org:
> elist....
> but this is not implemented yet with Teneo (there is a bugzilla for
> gr. Martin
> Anthony wrote:
>> Hi,
>> fetch join parent.children ...' , I wonder if there is one way to let
>> lazy collection only return certain numbers of itetm.
>> iterator.hasNext
>> Thanks in advance!
>> Anthony Lee
Re: [Teneo]lazy collection pagination [message #82726 is a reply to message #82725] Thu, 10 May 2007 06:05 Go to previous messageGo to next message
It is trial and error, but what you can try is the following:
- cast the collection to PersistableDelegateList
- and then use the getDelegate method on this persistabledelegatelist to get to the underlying
hibernate persistentlist and pass this one to the create filter method.
if the getDelegate returns an elist then you need to track if it also has a delegate..., eventually
there should be an underlying hibernate list.
gr. Martin
Anthony wrote:
> Reply
> Sandro,
> collection.
> pageSize){
> (collection,"");
> this method.
> results.
> Anthony
>> Hi,
>> elist....
>> gr. Martin
>> Anthony wrote:
>>> Hi,
>>> iterator.hasNext
>>> Thanks in advance!
>>> Anthony Lee
The Netherlands
Re: [Teneo]lazy collection pagination [message #82811 is a reply to message #82726] Thu, 10 May 2007 06:25 Go to previous message
news:f1uqp6$k7c$1@build.eclipse.org:
> to get to the underlying hibernate persistentlist and pass this one to
> has a delegate..., eventually there should be an underlying hibernate
> list.
> gr. Martin
> Anthony wrote:
>> Hi,
>> Reply
>> Sandro,
>> don't generate 2 select statements.
>> the SQL until you use it (say via owner.getPets().iterator().next()).
>> Because of that, you can add a filter to it which is simply a way of
>> adding additional criteria to the SQL that will be invoked to
>> initialize the collection.
>> int pageSize){
>> sessionController.getSession().createFilter (collection,"");
>> call this method.
>> query results.
>> Anthony
>>> Hi,
>>> gr. Martin
>>> Anthony wrote:
>>>> Hi,
>>>> let lazy collection only return certain numbers of itetm.
>>>> iterator.hasNext
>>>> Thanks in advance!
>>>> Anthony Lee
Hi ,
Yes, it works!
Thanks a lot!
Anthony
Re: [Teneo]lazy collection pagination [message #606645 is a reply to message #82722] Thu, 10 May 2007 05:18 Go to previous message
gr. Martin
Anthony wrote:
> Thanks in advance!
> Anthony Lee
The Netherlands
Re: [Teneo]lazy collection pagination [message #606647 is a reply to message #82723] Thu, 10 May 2007 05:58 Go to previous message
Reply
Sandro,
collection.
pageSize){
(collection,"");
this method.
results.
Anthony
> elist....
> gr. Martin
> Anthony wrote:
>> Hi,
>> iterator.hasNext
>> Thanks in advance!
>> Anthony Lee
Re: [Teneo]lazy collection pagination [message #606648 is a reply to message #82725] Thu, 10 May 2007 06:05 Go to previous message
gr. Martin
Anthony wrote:
> Reply
> Sandro,
> collection.
> pageSize){
> (collection,"");
> this method.
> results.
> Anthony
>> Hi,
>> elist....
>> gr. Martin
>> Anthony wrote:
>>> Hi,
>>> iterator.hasNext
>>> Thanks in advance!
>>> Anthony Lee
The Netherlands
Re: [Teneo]lazy collection pagination [message #606650 is a reply to message #82726] Thu, 10 May 2007 06:25 Go to previous message
> list.
> gr. Martin
> Anthony wrote:
>> Hi,
>> Reply
>> Sandro,
>> int pageSize){
>> call this method.
>> query results.
>> Anthony
>>> Hi,
>>> gr. Martin
>>> Anthony wrote:
>>>> Hi,
>>>> iterator.hasNext
>>>> Thanks in advance!
>>>> Anthony Lee
Hi ,
Yes, it works!
Thanks a lot!
Anthony
Previous Topic:[Teneo] Problem using Proxy Annotation
Next Topic:[Teneo] Integrating Teneo-Struts-Tomcat
Current Time: Fri Jul 18 17:53:43 EDT 2025
Powered by FUDForum. Page generated in 0.08200 seconds
