Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [teneo-jpox] jdoDatastore initialize failed on with mulitple ecores
[teneo-jpox] jdoDatastore initialize failed on with mulitple ecores [message #82258] Mon, 07 May 2007 04:01 Go to next message
Hi Martin,
I have a xsd that references another xsd eg.
<xs:schema
targetNamespace=" http://www.ibm.com/websphere/appserver/schemas/6.0/ibm-porta l-portletentities.xsd"
elementFormDefault="qualified"
attributeFormDefault="unqualified"
version="0.9.3.0"
xml:lang="en"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:portletentities=" http://www.ibm.com/websphere/appserver/schemas/6.0/ibm-porta l-portletentities.xsd"
xmlns:base=" http://www.ibm.com/websphere/appserver/schemas/6.0/ibm-porta l-base.xsd"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:xlink="http://www.w3.org/1999/xlink">
<xs:import
namespace=" http://www.ibm.com/websphere/appserver/schemas/6.0/ibm-porta l-base.xsd"
schemaLocation="ibm-portal-base.xsd"/>
I am successful in generating the enhanced classes.
But when I tried to generate the tables in the database using the
jdoDatastore.initialize command it failed with this:
13951 [main] ERROR JPOX.RDBMS.Schema - An exception was thrown while
adding/validating class(es) : null
at
org.jpox.store.rdbms.table.AbstractTable.addDatastoreField(A bstractTable.java:223)
at
org.jpox.store.rdbms.table.ClassTable.runSpecifiedCallbacks( ClassTable.java:1045)
at org.jpox.store.rdbms.table.ClassTable.runCallBacks(ClassTabl e.java:891)
at
org.jpox.store.rdbms.table.ClassTable.addFieldMetaData(Class Table.java:578)
at org.jpox.store.rdbms.table.ClassTable.manageClass(ClassTable .java:397)
at
org.jpox.store.rdbms.table.ClassTable.initializeForClass(Cla ssTable.java:831)
at org.jpox.store.rdbms.table.ClassTable.initialize(ClassTable. java:269)
at
org.jpox.store.rdbms.RDBMSManager$ClassAdder.initializeClass Tables(RDBMSManager.java:2950)
at
org.jpox.store.rdbms.RDBMSManager$ClassAdder.addClassTablesA ndValidate(RDBMSManager.java:3311)
at
org.jpox.store.rdbms.RDBMSManager$ClassAdder.run(RDBMSManage r.java:2554)
at
org.jpox.store.rdbms.RDBMSManager$MgmtTransaction.execute(RD BMSManager.java:2406)
at org.jpox.store.rdbms.RDBMSManager.addClasses(RDBMSManager.ja va:821)
at
org.eclipse.emf.teneo.jpox.JpoxDataStore.createSchema(JpoxDa taStore.java:468)
at
org.eclipse.emf.teneo.jpox.JpoxDataStore.initialize(JpoxData Store.java:196)
I have been successful in generating the schema for ibm-portal-base.xsd as
a standalone and as part of this schema ibm-portal-portletentities.xsd.
But it rollback when it tries to create the schema for portletentities.
The part it seems to rollback on seems to be related to section in
portletentities.xsd where it refers to base.xsd.
Am I missing a step?
Julia
Re: [teneo-jpox] jdoDatastore initialize failed on with mulitple ecores [message #82274 is a reply to message #82258] Mon, 07 May 2007 04:15 Go to previous messageGo to next message
Hi Julia,
When generating the jdo for the ibm-portal-portletentities.xsd (or ecore) you also need to select
the base.xsd (or ecore), if you first select on the portletentities xsd and then on the base xsd
then the jdo file will be generated in the java package of the first one.
Then when setting up the datastore you need to pass all the epackages (also from base.xsd) to the
setEPackages method.
gr. Martin
Julia wrote:
> Hi Martin,
> <xs:schema
> attributeFormDefault="unqualified" version="0.9.3.0"
> xml:lang="en"
> <xs:import
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> as a standalone and as part of this schema
> ibm-portal-portletentities.xsd. But it rollback when it tries to create
> the schema for portletentities. The part it seems to rollback on seems
> to be related to section in portletentities.xsd where it refers to
> base.xsd.
> Julia
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [teneo-jpox] jdoDatastore initialize failed on with mulitple ecores [message #82289 is a reply to message #82274] Mon, 07 May 2007 11:51 Go to previous messageGo to next message
Hi Martin,
Yes I did do that and highlighted both ecore files to create the meatadata
package.jdo file. Still got the NPE.
In an attempt to further see if there was some other problem with the xsd
files, I combined the 2 separate xsd files into one - portletentities.xsd.
This eliminated the import statement.
It still give me the null ptr exception.
It appears to fail on one element that reference other elements within the
xsd but 4 level deep eg <elementA> -> <elementB, max unbounded> ->
<elementC, max unbounded> -> <elementD,max unbounded> -> String.
There doesn't appear to have any problems 3 level deep (ie no elementB or
elementA).
Is there something else I need to do?
Re: [teneo-jpox] jdoDatastore initialize failed on with mulitple ecores [message #82303 is a reply to message #82289] Mon, 07 May 2007 13:18 Go to previous messageGo to next message
Hi Julia,
Can you send me the xsd's/ecores involved? Then I can try myself to see where/how it fails.
gr. Martin
Julia wrote:
> Hi Martin,
> meatadata package.jdo file. Still got the NPE.
> xsd files, I combined the 2 separate xsd files into one -
> portletentities.xsd. This eliminated the import statement.
> the xsd but 4 level deep eg <elementA> -> <elementB, max unbounded> ->
> or elementA).
The Netherlands
Re: [teneo-jpox] jdoDatastore initialize failed on with mulitple ecores [message #82469 is a reply to message #82303] Mon, 07 May 2007 17:51 Go to previous messageGo to next message
Hi Martin,
I sent my files via the elver address. Hopefully you will get it.
Julia
Re: [teneo-jpox] jdoDatastore initialize failed on with mulitple ecores [message #82657 is a reply to message #82469] Wed, 09 May 2007 01:12 Go to previous message
Hi Julia,
I spent some time debugging this but I can not determine why jpox has this npe. As far as I can see
this is a jpox issue which needs to be posted at the jpox forum. So I suggest you post the issue there.
When you post you need to post the log output and the package.jdo. Also they will probably ask for a
testcase.
Just initialization of jpox already fails so you don't need to write a testcase which actually
creates and reads data, also you don't need Teneo for this part, just initialization of jpox using
the model classes is enough.
gr. Martin
Julia wrote:
> Hi Martin,
> Julia
The Netherlands
Re: [teneo-jpox] jdoDatastore initialize failed on with mulitple ecores [message #605329 is a reply to message #82258] Mon, 07 May 2007 04:15 Go to previous message
Hi Julia,
gr. Martin
Julia wrote:
> Hi Martin,
> <xs:schema
> xml:lang="en"
> <xs:import
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> base.xsd.
> Julia
The Netherlands
Re: [teneo-jpox] jdoDatastore initialize failed on with mulitple ecores [message #605335 is a reply to message #82274] Mon, 07 May 2007 11:51 Go to previous message
Hi Martin,
elementA).
Re: [teneo-jpox] jdoDatastore initialize failed on with mulitple ecores [message #605339 is a reply to message #82289] Mon, 07 May 2007 13:18 Go to previous message
Hi Julia,
gr. Martin
Julia wrote:
> Hi Martin,
> or elementA).
The Netherlands
Re: [teneo-jpox] jdoDatastore initialize failed on with mulitple ecores [message #606621 is a reply to message #82303] Mon, 07 May 2007 17:51 Go to previous message
Hi Martin,
Julia
Re: [teneo-jpox] jdoDatastore initialize failed on with mulitple ecores [message #606635 is a reply to message #82469] Wed, 09 May 2007 01:12 Go to previous message
Hi Julia,
testcase.
gr. Martin
Julia wrote:
> Hi Martin,
> Julia
The Netherlands
Previous Topic:CDO for Eclipse 3.3?
Next Topic:[Teneo] dataStore.initialize() fails (four .ecore)
Current Time: Wed Jul 23 10:14:45 EDT 2025
Powered by FUDForum. Page generated in 0.13520 seconds
