Home » Archived » Eclipse Communications Framework (ECF) » Receiving a file with FileShare
Receiving a file with FileShare [message #606365] |
Tue, 25 July 2006 09:59  |
Now we managed to send a file to the server, w'd like to receive it and do
something useful with it. In our case we simply want a peer-to-peer file
transfer.
I suppose we've got to provide a sub class of BaseFileShareReceiver and
override the receive method. This receive method uses however a packaged
scoped argument FileShareMessage. That is incorrect, right? I think it
should be a public class.
Should the (subclass of) BaseFileShareReceiver contain the reference to e.g.
an outputstream for saving the file? How is the transaction result reported
to this receiver?
Kind regards,
Jaap
Re: Receiving a file with FileShare [message #606369 is a reply to message #606365] |
Tue, 25 July 2006 15:00   |
Hi Jaap,
This is cool! You just jumped ahead...and you've pretty much defined
the needed changes I referred to in my posting of this morning (need to
provide a way to override/change/more flexibly define the receive
behavior).
RE: should the subclass of BaseFileShareReceiver contain the reference
to the outputstream...? Yes, for now. BaseFileShareReceiver can
provide this directly, but it doesn't yet, so for the time being
subclasses must. Note that if you create a BaseFileShareReceiver
subclass you must also override the code in
BaseFileShareSender.getReplicaDescription(...) so that the proper class
is specified (your subclass).
RE: transaction result...AbstractSharedObject subclasses have a method:
protected void creationCompleted()
that is called when the transaction/creation has completed successfully.
If the transaction is aborted, the BaseFileShareReceiver will be
destroyed. If it succeeds, the creationCompleted() will be called.
Thanks for your patience...there's more impl work to be done here, but
it's great to have a specific use case driving it.
Scott
Jaap Reitsma wrote:
> transfer.
> to this receiver?
> Kind regards,
> Jaap
Re: Receiving a file with FileShare [message #607465 is a reply to message #606369] |
Tue, 25 July 2006 16:33   |
Hi Scott,
Bleeding edge technology, that is what it is ;-)
How should an error be reported back to the sender? I suppose a
FileShareMessage(Exception) must be passed back, but how? Through a separate
channel?
I noted that besides listening for a creationCompleted one can inspect the
FileShareMessage because of the isDone flag.
Another question: How does the receiver know the file name? Currently we use
(abuse) the property map for sending the filename, is there another way?
Kind regards,
Jaap
"Scott Lewis" <slewis@composent.com> wrote in message
news:44C66A5B.3090409@composent.com...
> Hi Jaap,
> This is cool! You just jumped ahead...and you've pretty much defined the
> behavior).
> RE: should the subclass of BaseFileShareReceiver contain the reference to
> the outputstream...? Yes, for now. BaseFileShareReceiver can provide
> this directly, but it doesn't yet, so for the time being subclasses must.
> Note that if you create a BaseFileShareReceiver subclass you must also
> override the code in BaseFileShareSender.getReplicaDescription(...) so
> that the proper class is specified (your subclass).
> Scott
> Jaap Reitsma wrote:
>> Hi,
>> do something useful with it. In our case we simply want a peer-to-peer
>> file transfer.
>> e.g. an outputstream for saving the file? How is the transaction result
>> reported to this receiver?
>> Kind regards,
>> Jaap
Re: Receiving a file with FileShare [message #607469 is a reply to message #607465] |
Wed, 26 July 2006 01:08   |
Hi Jaap,
I added some code to BaseFileShareSender and BaseFileShareReceiver to
1) allow subclasses to easily override some of the default behaviors for
sending/receiving (e.g. see fields that are now protected rather than
default)
2) BaseFileShareSender is now passed the 'remoteTarget' ID specified as
a IFileShareContainer.createSender parameter, and this ID is added to
the properties replicated to the BaseFileShareReceivers
3) BaseFileShareReceiver retrieves the given property from '2', if
non-null, and sets a new instance variable 'localTarget' that specifies
the receiver's *suggested* local target
4) In BaseFileShareReceiver.receive method, if localTarget is non-null,
a FileOutputStream with the name specified via the result of the
BaseFileShareReceiver.receiveAndSaveToFile
5) the data from the message is then saved to the new FileOutputStream,
effectively saving the file.
This still isn't optimal for the BaseFileShareReceiver, as receiver
subclasses sometimes will want to allow the user to specify the target
file rather than using the 'localTarget' ID passed by the sender (really
just a suggested name, as the receiver can do whatever it wishes with
the data in terms of storage on local file system.
In any event, hopefully this will be more useful to your team and others.
Scott
Jaap Reitsma wrote:
> Hi Scott,
> channel?
> Kind regards,
> Jaap
>> Hi Jaap,
>> behavior).
>> Scott
>> Jaap Reitsma wrote:
>>> Hi,
>>> file transfer.
>>> Kind regards,
>>> Jaap
Re: Receiving a file with FileShare [message #607471 is a reply to message #607469] |
Wed, 26 July 2006 04:06   |
Hi Scott,
Thanks for the effort, we'll check it out. I will keep you in touch with our
progress. When will the next release be made available?
As earlier noted, don't forget to give FileShareMessage public scope as
opposed to package which it is now (cvs version1.2). This class is used as
an argument in the protected method BaseFileShareReceiver.receive().
Kind regards,
Jaap
news:44C6F8B2.7050904@composent.com...
> Hi Jaap,
> default)
> 2) BaseFileShareSender is now passed the 'remoteTarget' ID specified as a
> IFileShareContainer.createSender parameter, and this ID is added to the
> 4) In BaseFileShareReceiver.receive method, if localTarget is non-null, a
> just a suggested name, as the receiver can do whatever it wishes with the
> Scott
> Jaap Reitsma wrote:
>> Hi Scott,
>> separate channel?
>> the FileShareMessage because of the isDone flag.
>> use (abuse) the property map for sending the filename, is there another
>> way?
>> Kind regards,
>> Jaap
>>> Hi Jaap,
>>> behavior).
>>> Scott
>>> Jaap Reitsma wrote:
>>>> Hi,
>>>> file transfer.
>>>> packaged scoped argument FileShareMessage. That is incorrect, right? I
>>>> think it should be a public class.
>>>> Kind regards,
>>>> Jaap
Re: Receiving a file with FileShare [message #607472 is a reply to message #607471] |
Wed, 26 July 2006 09:38  |
Hi Jaap,
Jaap Reitsma wrote:
> Hi Scott,
Haven't decided, but it could be either
a) next Monday (31) or
b) following Monday (7).
OK thanks. Changed and checked in.
Scott
> Kind regards,
> Jaap
>> Hi Jaap,
>> default)
>> Scott
>> Jaap Reitsma wrote:
>>> Hi Scott,
>>> separate channel?
>>> way?
>>> Kind regards,
>>> Jaap
>>>> Hi Jaap,
>>>> behavior).
>>>> Scott
>>>> Jaap Reitsma wrote:
>>>>> Hi,
>>>>> file transfer.
>>>>> Kind regards,
>>>>> Jaap
Current Time: Sun Jun 08 16:23:00 EDT 2025
Powered by FUDForum. Page generated in 0.26162 seconds
