headless pde build : InvocationTargetException in generated build.xml [message #547740] |
Mon, 19 July 2010 10:06  |
I am trying to set up a headless build of my product and it works for
the first few plugins (everything gets compiled, I have the classfiles
in the @dot directory), but then at some point I get
path/to/generated/buildxml/of/pluginxy/build.xml:251:
I marked line 251 in the generated script below with a leading 251:
<pathelement
path=" ../../../target/plugins/org.eclipse.xtext.ui_1.0.0.v20100616 1118.jar "/>
<pathelement
path=" ../../../target/plugins/org.eclipse.emf.ecore.edit_2.6.0.v20 100614-1136.jar "/>
<pathelement
path=" ../../../target/plugins/org.eclipse.emf.edit_2.6.0.v20100614 -1136.jar "/>
<pathelement
path=" ../../../target/plugins/org.eclipse.emf.ecore.change_2.5.0.v 20100521-1846.jar "/>
<pathelement
path=" ../../../target/plugins/org.eclipse.emf.edit.ui_2.6.0.v20100 614-1136.jar "/>
<pathelement
path=" ../../../target/plugins/org.eclipse.emf.common.ui_2.6.0.v201 00614-1136.jar "/>
<pathelement
path=" ../../../target/plugins/org.eclipse.xtext.ui.shared_1.0.0.v2 01006161118.jar "/>
<pathelement
path=" ../../../target/plugins/org.eclipse.xtext.builder_1.0.0.v201 006161118.jar "/>
</path>
<!-- compile the source code -->
251: <javac destdir="${build.result.folder}/@dot"
failonerror="${javacFailOnError}" verbose="${javacVerbose}"
debug="${javacDebugInfo}" includeAntRuntime="no"
bootclasspath="${bundleBootClasspath}" source="${bundleJavacSource}"
target="${bundleJavacTarget}" errorProperty="compilation.error.occured"
<compilerarg line="${compilerArg}"
compiler="${build.compiler}"/>
<classpath refid="@dot.classpath" />
<src path="src/" />
<src path="src-gen/" />
<compilerarg
value="@${basedir}/javaCompiler...args"
compiler="org.eclipse.jdt.core.JDTCompilerAdapter" />
<compilerarg line="-log
'${build.result.folder}/@dot${logExtension}&apo s; "
</javac>
<antcall target="checkCompilationResults"/>
<!-- Copy necessary resources -->
<copy todir="${build.result.folder}/@dot"
failonerror="true" overwrite="false">
<fileset dir="src/">
<exclude name="**/*.java"/>
<exclude name="**/package.htm*"/>
</fileset>
<fileset dir="src-gen/">
</fileset>
</copy>
</target>
the target's name is @dot
I have no clue how to debug this. Any help would be highly appreciated!
Tobi
Re: headless pde build : InvocationTargetException in generated build.xml [message #547826 is a reply to message #547740] |
Mon, 19 July 2010 13:19  |
You can try running ant with -verbose to see if you get more error
information.
That is the call to the compiler. It is using the JDT compiler
"org.eclipse.jdt.core.JDTCompilerAdapter", make sure the JDT and its
dependencies are in your eclipse install that is running the build.
-Andrew
> <pathelement
> <pathelement
> <pathelement
> <pathelement
> <pathelement
> <pathelement
> <pathelement
> <pathelement
> </path>
> <src path="src/" />
> <compilerarg
> </javac>
> </fileset>
> </fileset>
> </copy>
> </target>
> Tobi
Re: headless pde build : InvocationTargetException in generated build.xml [message #606285 is a reply to message #547740] |
information.
-Andrew
> <pathelement
> <pathelement
> <pathelement
> <pathelement
> <pathelement
> <pathelement
> <pathelement
> <pathelement
> </path>
> <src path="src/" />
> <compilerarg
> </javac>
> </fileset>
> </fileset>
> </copy>
> </target>
> Tobi
FUDForum. Page generated in 0.22342 seconds
