Home » Eclipse Projects » Plugin Development Environment (PDE) » Resources (i.e messages.properties) in PDE Build not built into JAR correctly
Resources (i.e messages.properties) in PDE Build not built into JAR correctly [message #540645] Wed, 16 June 2010 15:50 Go to next message
I am building an RCP product with PDE build.
I have a source folder called resources in the root of my project. The
resources folder follows the package heirarchy in the main src folder.
When I export the product, the result JAR file has the resources folder in
the root, i.e the resources are not copied into the same folder as the class
files.
How do I tell PDE build (the ant tasks) to move these resources into the
folder where the classes are?
Greg
Re: Resources (i.e messages.properties) in PDE Build not built into JAR correctly [message #540887 is a reply to message #540645] Thu, 17 June 2010 10:08 Go to previous message
In your build.properties files, there will be a property like:
source.. = src
Add your resources folder here:
source.. = src, resources
And you should probably remove it from the "bin.includes".
-Andrew
> class files.
> Thanks
> Greg
Re: Resources (i.e messages.properties) in PDE Build not built into JAR correctly [message #606102 is a reply to message #540645] Thu, 17 June 2010 10:08 Go to previous message
source.. = src
-Andrew
> class files.
> Thanks
> Greg
Previous Topic:Resources (i.e messages.properties) in PDE Build not built into JAR correctly
Next Topic:Starting DS for use by plug-in
Current Time: Mon Jul 28 03:35:15 EDT 2025
Powered by FUDForum. Page generated in 0.06692 seconds
