Home » Modeling » Papyrus » Export to PNG and Problems with class diagrams
Export to PNG and Problems with class diagrams [message #606035] Tue, 24 August 2010 03:20 Go to next message
i have to use Eclipse with Papyrus in my practical semester.
No I've got some problems.
First, i wish there would be a step by step tutorial for Papyrus, because i spent a lot of time by learning how this modelling tool works....
My next Point is that i haven't found an option to export my created diagrams into png or something else...
And last, i can't add on class diagrams return parameters.
Can someone help me?
Re: Export to PNG and Problems with class diagrams [message #606042 is a reply to message #606035] Tue, 24 August 2010 05:40 Go to previous messageGo to next message
Normaly, you can export image by using contextual menu on a diagram:
File>Save as image file. If this is not the case, this is a bug
About parameters, are they "return parameters of operation"?
Papyrus team
"Angi" <princiangi@googlemail.com> a
Re: Export to PNG and Problems with class diagrams [message #606046 is a reply to message #606035] Tue, 24 August 2010 06:10 Go to previous messageGo to next message
There is no print symbol, no print in the menu, oder something like save as image.
Yes i wanna add a return parameter on an operation in a class diagram
Re: Export to PNG and Problems with class diagrams [message #606049 is a reply to message #606035] Wed, 25 August 2010 04:21 Go to previous messageGo to next message
Another very funny debug is that in a sequence diagram, if i add an action to a lifeline, and a second one which is on the first action and then i wanna change the order of these actions, the orders are permutes. If i click "send to back" it brings it to the front *g* and if i click "send to front" it goes to back ......
Re: Export to PNG and Problems with class diagrams [message #606053 is a reply to message #606049] Wed, 25 August 2010 04:36 Go to previous messageGo to next message
Hello Angi,
Thanks for pointing this out.
Could you open a bug against MDT Papyrus on the Eclipse bugzilla ?
https://bugs.eclipse.org/bugs/
Even if we are trying our best, MDT Papyrus is not yet free of bugs.
Any help and suggestions are more than welcome :) (by reporting bugs,
providing patchs, discussing the implementation / specification...).
Best Regards,
Thibault
Re: Export to PNG and Problems with class diagrams [message #606905 is a reply to message #606046] Thu, 26 August 2010 03:28 Go to previous messageGo to next message
In the property view, you can create a parameter for an operation, then
select the parameter, you can change the direction "in", "out", "inout",
"return".
About the save of diagram, it is already fixed for the next release at the
end of september.
Papyrus team,
Re: Export to PNG and Problems with class diagrams [message #606912 is a reply to message #606035] Thu, 26 August 2010 03:41 Go to previous messageGo to next message
Thank you,
it works but how can i show it in the class diagram?
I added a parameter but there is nothing in the view.
Just in the Modelexplorer i see my parameter.
Re: Export to PNG and Problems with class diagrams [message #606920 is a reply to message #606035] Mon, 30 August 2010 04:35 Go to previous messageGo to next message
But how can i display it in the diagram( the return parameter)?
I can create it, but it is not shown in the diagram....
And how can i create an actor symbol as a lifeline head in the sequenze diagram?
Re: Export to PNG and Problems with class diagrams [message #606927 is a reply to message #606046] Tue, 31 August 2010 09:18 Go to previous messageGo to next message
Angi wrote on Tue, 24 August 2010 06:10
Maybe you misunderstood Patrick?
The option to export images can be found in the context menu. You have to click into the diagram with the right button of your mouse.Then the context menu appears next to your mouse pointer. The option can not be found in the menu at the top of the window!
In the context menu there are several items starting with "Filter views...", "Add", "Navigate", and the fourth item is "File". Inside "File" you can find "Save As Image File...". You can choose between several formats like GIF, PNG, SVG, and PDF in the dialog. Though PDF is not working for me.
Re: Export to PNG and Problems with class diagrams [message #606931 is a reply to message #606035] Wed, 01 September 2010 08:02 Go to previous messageGo to next message
Oh Thank you,
I found it now and it works. But If someone is new at papyrus he doesn't find this option :)
I think it's a main function which is needed every time....
Re: Export to PNG and Problems with class diagrams [message #676573 is a reply to message #606931] Sun, 05 June 2011 07:16 Go to previous messageGo to next message
I want to export the diagramas I have created with Papyrus over eclipse helios as an image. I have tried what Markus wrote but I can't find the option "Save as image file". I have tried the option "Export...", but I can't find image file type in the output types supported.
I tried to install this plugin ("Image export", it allows exporting GEM/GMF diagrams to images ), which is in the eclipse marketplace, but when I find it in the plugin list, there isn't an install button next to it, so I can't install it.
I want to know what is the problem or if there is other choice to export as image or print a papyrus diagram.
Thanks in advance
Re: Export to PNG and Problems with class diagrams [message #677253 is a reply to message #676573] Tue, 07 June 2011 18:27 Go to previous message
(Tested on Papyrus 0.8.0 RC3)
With the diagram open, right-click anywhere in the diagram, then select
"File/Save as image file".
regards,
Yann
On Sun, 05 Jun 2011 13:16:31 +0200, <forums-noreply@eclipse.org> wrote:
> Hello,
> can't find image file type in the output types supported. I tried to
> I can't install it.
> Thanks in advance
Using Opera's revolutionary email client: http://www.opera.com/mail/
Previous Topic:Diagram Question
Next Topic:Interaction Overview Diagram
Current Time: Wed Jul 23 20:34:49 EDT 2025
Powered by FUDForum. Page generated in 0.04939 seconds
