Home » Eclipse Projects » Plugin Development Environment (PDE) » ClassNotFound SWTError on deployed Startup
ClassNotFound SWTError on deployed Startup [message #605934] Mon, 07 June 2010 01:10 Go to next message
I have an Eclipse product based on features which
validates ok
runs ok from a launch configuration
exports ok from export wizard
When I start the native launcher, the application fails to load. Reading the attached dump, I believe that the root cause is a ClassNotFoundError for SWTError, as shown below.
Caused by: java.lang.ClassNotFoundException: org.eclipse.swt.SWTError
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:494)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:398)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
... 41 more
I have verified that both the plugin
org.eclipse.swt_3.5.2.v3557f.jar
and platform fragment
org.eclipse.swt.win32.win32.x86_3.5.2.v3557f.jar
are in the plugins directory.
Does anyone have an idea as to the cause of this issue?
Can anybody point me to a debugging strategy?
Re: ClassNotFound SWTError on deployed Startup [message #605936 is a reply to message #605934] Mon, 07 June 2010 04:13 Go to previous messageGo to next message
> validates ok
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> ... 41 more
> I have verified that both the plugin org.eclipse.swt_3.5.2.v3557f.jar
See if the solution at http://dev.eclipse.org/newslists/news.eclipse.platform.rcp/m sg32879.html
help fix problem too.
Ankur..
Re: ClassNotFound SWTError on deployed Startup [message #606382 is a reply to message #605934] Fri, 30 July 2010 05:28 Go to previous message
See http://www.eclipse.org/forums/index.php?t=msg&goto=53908 2&
Amazing, what a misleading Exception this bug provokes.
Previous Topic:ClassNotFound SWTError on deployed Startup
Next Topic:Errors when following the Plug-in Cheat Sheet
Current Time: Sat Jul 26 10:59:16 EDT 2025
Powered by FUDForum. Page generated in 0.04208 seconds
