Home » Archived » Visual Editor (VE) » No property editor
No property editor [message #82785] Tue, 08 March 2005 13:35 Go to next message
I'm trying to launch the visual editor using the latest of everything (I
think, just used the update utility) on Version: 3.1.0
Build id: I20050219-1500
It is bombing out on starting the property editor
This is what the log is showing me:
!ENTRY org.eclipse.ve.java.core 4 0 2005-03-08 11:01:20.78
!MESSAGE Exception thrown.
!STACK 0
java.lang.ClassNotFoundException: org.eclipse.ui.internal.commands.Command
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:359)
at org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:94)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$3.enableDelCommand(JavaVisualEditorPart.java:1968)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$3.focusLost(JavaVisualEditorPart.java:1999)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:108)
Anyone know where to get the class I seem to be missing?
Re: No property editor [message #82801 is a reply to message #82785] Tue, 08 March 2005 14:02 Go to previous messageGo to next message
The released code (the code that is available through the update
manager) does not work on 3.1, it only works on 3.0.1. We are in the
process of getting a developement build out there that does work on 3.1.
The current nightly build kinda works but there are bugs and problems
with it.
> !STACK 0
> at
Rich Kulp
Re: No property editor [message #82814 is a reply to message #82801] Tue, 08 March 2005 15:28 Go to previous message
Ok. Thanks for the info.
Have you gotten this and webtools to work at the same time?
I was using 3.1 because I thought webtools needed it.
Luis
> with it.
>> !STACK 0
>> at
Re: No property editor [message #605767 is a reply to message #82785] Tue, 08 March 2005 14:02 Go to previous message
with it.
> !STACK 0
> at
Rich Kulp
Re: No property editor [message #605769 is a reply to message #82801] Tue, 08 March 2005 15:28 Go to previous message
Luis
> with it.
>> !STACK 0
>> at
Previous Topic:No property editor
Next Topic:[JEM] getting all constructors/fields/methods?
Current Time: Sat Sep 20 22:20:54 EDT 2025
Powered by FUDForum. Page generated in 0.06665 seconds
