Home » Eclipse Projects » Plugin Development Environment (PDE) » Custom Ant tasks and runtime jar libraries
Custom Ant tasks and runtime jar libraries [message #525734] |
Wed, 07 April 2010 11:40  |
Originally posted by: cold.phusion.gmail.com
Hi guys,
I'm trying to define a custom Ant task as an extension which later
should be used in a RCP application. Basically, what I want is an Ant
task which would be available for all plug-ins that are depending on
mine. I've read a lot about the different JVMs and classloaders when
using Ant and Eclipse (I think I got the main point), so I' familiar
with the issue.
However, I can't seem to load any Ant task extensions into my Runtime
Eclipse environment, even when I check out org.eclipse.emf.ant from CVS.
When I disable the installed plug-in and activate the one in my
workspace, I get the following error in my error log (in the Runtime
environment):
The library "ant_tasks/emf.ant.tasks.jar" specified from
"org.eclipse.emf.ant" for the antTasks or antTypes extension does not exist.
Apparently, the runtime library is not built and the extension cannot be
instantiated (I have no compiler errors whatsoever). To be fair, the
plugin.xml of the project contains a comment which probably regards this
issue:
<!-- Replace 'ant_tasks/emf.ant.tasks.jar' by
'ant_tasks/emf.ant.tasks.jar' to be able to debug without regenerating
jars -->
but this doesn't make any sense whichever way you slice it o_O.
Is there any particular way of deploying such Ant tasks in a RCP
environment? Or may be I am missing something? I guess building the Jar
manually might do the trick, but isn't that what the runtime libraries
are for?
Alex
Re: Custom Ant tasks and runtime jar libraries [message #528488 is a reply to message #525734] |
Tue, 20 April 2010 12:18   |
Hi Alex,
The ant tasks need to live in a separate jar from the rest of the bundle
because of how the ant classloaders work. This means the ant tasks
should be kept in a separate source folder which uses a different output
folder than the default
See this help page:
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/ant_contributing_task.htm
I looked at the org.eclipse.emf.ant plugin, it is set up correctly.
You will need that emf.ant.tasks.jar in order to use it in a self hosted
eclipse. The easiest way to do this is to right click on the Manifest
and do PDE Tools -> Create Ant Build File. Right click on the generated
build.xml and do Run As -> Ant Build.
This will create the jar for you. Some projects write a local_build.xml
that is added as an external builder to create the jar automatically
whenever something changes.
-Andrew
Alex Shterev wrote:
> Hi guys,
> with the issue.
> environment):
> exist.
> issue:
> jars -->
> are for?
> Thanks :)
> Best regards,
> Alex
Re: Custom Ant tasks and runtime jar libraries [message #529207 is a reply to message #528488] |
Fri, 23 April 2010 09:06  |
Hi Andrew,
thank you for your reply. Yes, I read the help section on contributing
an Ant task and I understood almost everything except for the part of
deploying that jar file. I assumed it was going to be built by the
standard PDE builder on the fly and will be automatically provided at
runtime to the self hosted Eclipse instance. I tried exporting the
classes as a Jar using Export > Java > Jar file, but it didn't do the
job. Unfortunately it never crossed my mind to check out the Ant PDE
build... :|
I'll try it out later on and I'll get back to you if I have any further
questions.
Thx once again,
Alex
Am 20.04.2010 18:18, schrieb Andrew Niefer:
> Hi Alex,
> See this help page:
> -Andrew
> Alex Shterev wrote:
>> Hi guys,
>> with the issue.
>> CVS. When I disable the installed plug-in and activate the one in my
>> environment):
>> exist.
>> be instantiated (I have no compiler errors whatsoever). To be fair,
>> the plugin.xml of the project contains a comment which probably
>> regards this issue:
>> jars -->
>> Jar manually might do the trick, but isn't that what the runtime
>> libraries are for?
>> Thanks :)
>> Best regards,
>> Alex
Re: Custom Ant tasks and runtime jar libraries [message #605630 is a reply to message #525734] |
Hi Alex,
See this help page:
-Andrew
Alex Shterev wrote:
> Hi guys,
> with the issue.
> environment):
> exist.
> issue:
> jars -->
> are for?
> Thanks :)
> Best regards,
> Alex
Re: Custom Ant tasks and runtime jar libraries [message #605662 is a reply to message #528488] |
Hi Andrew,
build... :|
questions.
Thx once again,
Alex
> Hi Alex,
> See this help page:
> -Andrew
> Alex Shterev wrote:
>> Hi guys,
>> with the issue.
>> environment):
>> exist.
>> regards this issue:
>> jars -->
>> libraries are for?
>> Thanks :)
>> Best regards,
>> Alex
Current Time: Wed Jul 23 00:44:34 EDT 2025
Powered by FUDForum. Page generated in 0.04200 seconds
