Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Problem using Proxy Annotation
[Teneo] Problem using Proxy Annotation [message #81504] Mon, 30 April 2007 06:23 Go to next message
Originally posted by: cn.arcsolutions.de
Hi Martin!
I've tried to use the new @Proxy annotation in Teneo 0.8.0 but unfortunately I'll can't use it. Every time I try, I get this nice exception. It seems to be a CGLIB problem again, but I'm wondering why nobody else gets it.
Has someone here already solved this problem?
Thanx for any kind of help
Christian
org.hibernate.HibernateException: Could not build tuplizer [org.eclipse.emf.teneo.hibernate.tuplizer.EMFTuplizer]
at org.hibernate.tuple.entity.EntityEntityModeToTuplizerMapping .buildEntityTuplizer(EntityEntityModeToTuplizerMapping.java: 110)
at org.hibernate.tuple.entity.EntityEntityModeToTuplizerMapping . <init>(EntityEntityModeToTuplizerMapping.java:48)
at org.hibernate.tuple.entity.EntityMetamodel.<init>(EntityMetamodel.java:295)
at org.hibernate.persister.entity.AbstractEntityPersister.<init >(AbstractEntityPersister.java:434)
at org.hibernate.persister.entity.JoinedSubclassEntityPersister . <init>(JoinedSubclassEntityPersister.java:91)
at org.hibernate.persister.PersisterFactory.createClassPersiste r(PersisterFactory.java:58)
at org.hibernate.impl.SessionFactoryImpl.<init>(SessionFactoryImpl.java:226)
at org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1294)
at org.eclipse.emf.teneo.hibernate.HbSessionDataStore.buildSess ionFactory(HbSessionDataStore.java:156)
at org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:79)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at org.hibernate.tuple.entity.EntityEntityModeToTuplizerMapping .buildEntityTuplizer(EntityEntityModeToTuplizerMapping.java: 107)
... 12 more
Caused by: net.sf.cglib.core.CodeGenerationException: java.lang.reflect.InvocationTargetException-->null
at net.sf.cglib.core.AbstractClassGenerator.create(AbstractClas sGenerator.java:237)
at net.sf.cglib.proxy.Enhancer.createHelper(Enhancer.java:377)
at net.sf.cglib.proxy.Enhancer.createClass(Enhancer.java:317)
at org.hibernate.proxy.pojo.cglib.CGLIBLazyInitializer.getProxy Factory(CGLIBLazyInitializer.java:117)
at org.hibernate.proxy.pojo.cglib.CGLIBProxyFactory.postInstant iate(CGLIBProxyFactory.java:43)
at org.eclipse.emf.teneo.hibernate.tuplizer.EMFTuplizer.buildPr oxyFactory(EMFTuplizer.java:218)
at org.hibernate.tuple.entity.AbstractEntityTuplizer.<init>(AbstractEntityTuplizer.java:135)
at org.eclipse.emf.teneo.hibernate.tuplizer.EMFTuplizer.<init>(EMFTuplizer.java:75)
... 17 more
at net.sf.cglib.core.ReflectUtils.defineClass(ReflectUtils.java :384)
at net.sf.cglib.core.AbstractClassGenerator.create(AbstractClas sGenerator.java:219)
... 24 more
Caused by: java.lang.NoClassDefFoundError: org/hibernate/proxy/HibernateProxy
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
... 30 more
Re: [Teneo] Problem using Proxy Annotation [message #81521 is a reply to message #81504] Mon, 30 April 2007 06:58 Go to previous messageGo to next message
Hi Christian,
The cause can be that you miss certain required libraries (maybe cglib?).
or/and related to plugin classloading.
A google search on:
cglib java.lang.NoClassDefFoundError HibernateProxy
will give a fair amount of hits. Did you try that?
gr. Martin
Christian Neudert wrote:
> Hi Martin!
> nobody else gets it. Has someone here already solved this problem?
> Christian
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Method)
> Source)
> Source)
> at
> ... 12 more
> at
> at
> at
> at
> at
> at
> ... 17 more
> at
> ... 24 more
> ... 30 more
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Problem using Proxy Annotation [message #81616 is a reply to message #81521] Mon, 30 April 2007 11:01 Go to previous messageGo to next message
Hi Martin,
I've read several post on this sites but none of their problem was mine, or could be fixed with their hints.
I've read that setting default-lazy="false" in the hbm.xml would solve the problem but I can't use a static hbm file.
I've wrapped Hibernate in one plugin as recommended on your site,
so maybe you can send me your plugin, and I can check if it's my fault and where it is!?
thanx
Christian
Re: [Teneo] Problem using Proxy Annotation [message #81631 is a reply to message #81504] Mon, 30 April 2007 11:23 Go to previous messageGo to next message
Maybe this is eclipse 3.3M6 related because I also get Exceptions when trying to use c3p0, which was no problem under 3.2!?
Christian
!ENTRY de.arcsolutions.remarc.platform.data.hibernaterepository 4 1 2007-04-30 17:19:37.584
!MESSAGE
!STACK 0
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:350)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:495)
at de.arcsolutions.remarc.platform.data.hibernaterepository.Hib ernateDataRepositoryRoot.getIClassificationsProvider(Hiberna teDataRepositoryRoot.java:95)
at de.arcsolutions.remarc.platform.ui.classificationsview.Combo Provider.getElements(ComboProvider.java:109)
at org.eclipse.jface.viewers.StructuredViewer.getRawChildren(St ructuredViewer.java:937)
at org.eclipse.jface.viewers.StructuredViewer.getFilteredChildr en(StructuredViewer.java:871)
at org.eclipse.jface.viewers.StructuredViewer.getSortedChildren (StructuredViewer.java:994)
at org.eclipse.jface.viewers.AbstractListViewer.inputChanged(Ab stractListViewer.java:336)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:251)
at org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:1624)
at de.arcsolutions.remarc.platform.ui.classificationsview.Class ificationsViewPart.changeInput(ClassificationsViewPart.java: 424)
at de.arcsolutions.remarc.platform.ui.classificationsview.Switc hRepositioryAction.run(SwitchRepositioryAction.java:59)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3673)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3284)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2337)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2301)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 76)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:463)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:458)
at de.arcsolutions.remarc.rcp.application.PlatformRunnable.run( PlatformRunnable.java:71)
at org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hod(EclipseAppContainer.java:533)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:148)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:356)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:171)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 476)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:416)
at org.eclipse.equinox.launcher.Main.run(Main.java:1141)
at org.eclipse.equinox.launcher.Main.main(Main.java:1116)
Caused by: java.lang.LinkageError: loader constraint violation: loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) previously initiated loading for a different type with name "javax/management/MBeanServer"
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:161)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:501)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:471)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:430)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:413)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at com.mchange.v2.c3p0.management.ActiveManagementCoordinator.a ttemptManageC3P0Registry(ActiveManagementCoordinator.java:52 )
at com.mchange.v2.c3p0.C3P0Registry.attemptRegisterRegistryMBea n(C3P0Registry.java:217)
at com.mchange.v2.c3p0.C3P0Registry.reregister(C3P0Registry.jav a:242)
at com.mchange.v2.c3p0.impl.PoolBackedDataSourceBase.<init>(PoolBackedDataSourceBase.java:228)
at com.mchange.v2.c3p0.impl.AbstractPoolBackedDataSource.<init >(AbstractPoolBackedDataSource.java:62)
at com.mchange.v2.c3p0.impl.AbstractPoolBackedDataSource.<init >(AbstractPoolBackedDataSource.java:68)
at com.mchange.v2.c3p0.PoolBackedDataSource.<init>(PoolBackedDataSource.java:37)
at com.mchange.v2.c3p0.DataSources.pooledDataSource(DataSources .java:267)
at com.mchange.v2.c3p0.DataSources.pooledDataSource(DataSources .java:316)
at org.hibernate.connection.C3P0ConnectionProvider.configure(C3 P0ConnectionProvider.java:159)
at org.hibernate.connection.ConnectionProviderFactory.newConnec tionProvider(ConnectionProviderFactory.java:124)
at org.hibernate.connection.ConnectionProviderFactory.newConnec tionProvider(ConnectionProviderFactory.java:56)
at org.hibernate.tool.hbm2ddl.ManagedProviderConnectionHelper.p repare(ManagedProviderConnectionHelper.java:27)
at org.hibernate.tool.hbm2ddl.SchemaUpdate.execute(SchemaUpdate .java:127)
at org.eclipse.emf.teneo.hibernate.HbDataStore.updateDatabaseSc hema(HbDataStore.java:557)
at org.eclipse.emf.teneo.hibernate.HbDataStore.initializeDataSt ore(HbDataStore.java:199)
at org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:74)
Root exception:
Re: [Teneo] Problem using Proxy Annotation [message #81646 is a reply to message #81616] Mon, 30 April 2007 13:56 Go to previous messageGo to next message
Hi Christian,
I am sorry but I can't really help you on this one. I use Teneo/emf in a web environment and have
less to do with plugin classloading issues. You can set lazy to false but that is the same as not
using proxying. So the proxy annotation gives you many-to-one and one-to-one lazy loading but with
the disadvantage of using cglib.
You can try out different buddy policy settings and check out how cglib loads classes.
gr. Martin
> Hi Martin,
> and where it is!?
> thanx Christian
The Netherlands
Re: [Teneo] Problem using Proxy Annotation [message #81890 is a reply to message #81504] Fri, 04 May 2007 05:24 Go to previous messageGo to next message
I've made it work, after reading
http://www.eclipsezone.com/articles/eclipse-vms/.
Suppose you have 3 plugins : org.mycompany.client, org.mycompany.hibernate
(hibernate libs), org.mycompany.model.
Use :
org.mycompany.model/META-INF/MANIFEST.MF:Eclipse-BuddyPolicy : registered
org.mycompany.client/META-INF/MANIFEST.MF:Eclipse-BuddyPolic y: registered
org.mycompanytalend.hibernate/META-INF/MANIFEST.MF:Eclipse-R egisterBuddy:
org.mycompany.client, org.mycompany.model
and in your code :
Properties properties = new Properties();
properties.setProperty(PersistenceOptions.ALSO_MAP_AS_CLASS, "true");
properties.setProperty(PersistenceOptions.SET_PROXY, "true");
dataStore.setPersistenceProperties(properties);
Matthieu
Le Mon, 30 Apr 2007 12:23:00 +0200, Christian Neudert a écrit:
> Hi Martin!
> Christian
> ... 12 more
> ... 17 more
> ... 24 more
> ... 30 more
Re: [Teneo] Problem using Proxy Annotation [message #82608 is a reply to message #81890] Tue, 08 May 2007 11:44 Go to previous messageGo to next message
Thanks a lot Matthieu!
After reading your post and the article i managed to get it working!
By the way there is some more todo if the datamodel is split over many plugins and has references to each other:
- of course all plugins must be registered as buddys to your hibernate plugin
- also under some circumstances its required to add "dependent" to Eclipse-BuddyPolicy in your hibernate (in my case also in client) plugin!
(for example: "Eclipse-BuddyPolicy: registered, dependent")
cheers
cn
Re: [Teneo] Problem using Proxy Annotation [message #82724 is a reply to message #82608] Thu, 10 May 2007 05:57 Go to previous message
You are totally right
I found the ciscumstances you're talking about, with this error
org.hibernate.MappingException: Could not determine type for:
org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContaine rUserType
The documentation talks about this problem :
http://www.elver.org/hibernate/tutorialtwo/tutorial2_1.html and
http://www.elver.org/hibernate/installation.html#Hibernate+L ibraries
So, thanks Christian
> cheers
> cn
Re: [Teneo] Problem using Proxy Annotation [message #605150 is a reply to message #81504] Mon, 30 April 2007 06:58 Go to previous message
Hi Christian,
A google search on:
gr. Martin
> Hi Martin!
> Christian
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Method)
> Source)
> Source)
> at
> ... 12 more
> at
> at
> at
> at
> at
> at
> ... 17 more
> at
> ... 24 more
> ... 30 more
The Netherlands
Re: [Teneo] Problem using Proxy Annotation [message #605172 is a reply to message #81521] Mon, 30 April 2007 11:01 Go to previous message
Hi Martin,
thanx
Christian
Re: [Teneo] Problem using Proxy Annotation [message #605174 is a reply to message #81504] Mon, 30 April 2007 11:23 Go to previous message
Christian
!MESSAGE
!STACK 0
Root exception:
Re: [Teneo] Problem using Proxy Annotation [message #605177 is a reply to message #81616] Mon, 30 April 2007 13:56 Go to previous message
Hi Christian,
gr. Martin
> Hi Martin,
> and where it is!?
> thanx Christian
The Netherlands
Re: [Teneo] Problem using Proxy Annotation [message #605229 is a reply to message #81504] Fri, 04 May 2007 05:24 Go to previous message
Use :
and in your code :
Matthieu
> Hi Martin!
> Christian
> ... 12 more
> ... 17 more
> ... 24 more
> ... 30 more
Re: [Teneo] Problem using Proxy Annotation [message #606630 is a reply to message #81890] Tue, 08 May 2007 11:44 Go to previous message
cheers
cn
Re: [Teneo] Problem using Proxy Annotation [message #606646 is a reply to message #82608] Thu, 10 May 2007 05:57 Go to previous message
> cheers
> cn
Previous Topic:[Teneo]lazy collection pagination
Next Topic:[Teneo]lazy collection pagination
Current Time: Thu Nov 06 07:51:03 EST 2025
Powered by FUDForum. Page generated in 0.04209 seconds
