[Teneo] correct version for Eclipse 3.2.2 ?? [message #80053] |
Tue, 17 April 2007 12:50  |
Martin,
I co-worked told me that he read somewhere, can't find it now, that 0.8.0
of Teneo requires Eclipse 3.3, and that 0.7.5 should be used with 3.2.
I am currently using Teneo 0.8.0 and Eclipse 3.2.2 with no problems. Is
this supports or should I be using 0.7.5 of Teneo.
Mark.
Re: [Teneo] correct version for Eclipse 3.2.2 ?? [message #80068 is a reply to message #80053] |
Tue, 17 April 2007 13:10   |
Mark,
Teneo does not use specific Eclipse 3.3 features and what I understand is that emf 2.3 is binary
compatible with emf 2.2. So overall it should work. My testcases are however only run in two
configurations:
- Teneo 0.7.5 for emf 2.2 and eclipse 3.2
- Teneo 0.8.0 for emf 2.3 and eclipse 3.3
Note that new features are added to 0.8.0, while for 0.7.5 mainly only bugfixing is done.
So there is no definite answer if 0.8.0 always works fine for 3.2.2 but if you encounter issues with
this configuration then I will try to do my best to answer posts on the newsgroup.
gr. Martin
Mark wrote:
> Martin,
> 0.8.0 of Teneo requires Eclipse 3.3, and that 0.7.5 should be used with
> 3.2.
> Mark.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: teneo download URL for eclipse 3.2 [message #130091 is a reply to message #130075] |
Fri, 10 October 2008 16:48  |
Hi Sudhakar,
I have asked around but not yet got an answer. If I have more information then I will let you know.
gr. Martin
Sudhakar wrote:
> I'm looking for the download link for a version of Teneo that works with
> Eclipse 3.2 . Can someone point me to the right URL. Couldn't locate it
> on the teneo page on eclipse.org
> Thanks
> -sud
The Netherlands
Cell: +31 (0)6 288 48 943
Re: [Teneo] correct version for Eclipse 3.2.2 ?? [message #604791 is a reply to message #80053] |
Mark,
configurations:
gr. Martin
Mark wrote:
> Martin,
> 3.2.
> Mark.
The Netherlands
Re: teneo download URL for eclipse 3.2 [message #620341 is a reply to message #130075] |
Hi Sudhakar,
gr. Martin
> Thanks
> -sud
The Netherlands
FUDForum. Page generated in 0.03997 seconds
