Home » Eclipse Projects » Plugin Development Environment (PDE) » Dynamic loading of jar files using custom classLoader
Dynamic loading of jar files using custom classLoader [message #604706] Tue, 16 February 2010 15:26 Go to next message
I've been searching for possibilities to dynamically load jar files for quite a while and came across a custom classLoader I like ( http://www.javaworld.com/javaworld/javatips/jw-javatip70.htm l). I downloaded the resources from that site (JarClassLoader.java, JarResources.java and MultiClassLoader.java) and put them to use in a small test project which worked out fine. However I want to use the JarClassLoader inside an Eclipse plug-in and for some reason I haven't been able to simply reuse the code from the test project for that purpose. The code I'm using in both the java test project and in the plug-in project is the following:
public static void run() {
JarClassLoader jarLoader = new JarClassLoader ("C:\\somepath\\testjar.jar");
try {
Class c = jarLoader.loadClass ("TestClass", true);
Object o = c.newInstance();
if (o instanceof TestClass) {
System.out.println("works...");
TestClass tc = (TestClass) o;
String test = tc.run();
} catch (ClassNotFoundException e) {
e.printStackTrace();
} catch (InstantiationException e) {
} catch (IllegalAccessException e) {
In the normal java project I have a main method which just calls the method run() and does nothing else. In the Eclipse plug-in project I have an action that when executed also just calls the method run() and nothing else. The problem is that in the Eclipse plug-in the check whether the created object is an instance of the class I desire fails, that is "works..." is never even printed. Although in debug mode it says that the object o is actually an instance of the class TestClass.
Can anyone point me to what I might be doing wrong?
Thank you for your help!
Re: Dynamic loading of jar files using custom classLoader [message #604721 is a reply to message #604706] Wed, 17 February 2010 15:33 Go to previous message
I think the problem is you are comparing class objects created by two
different class loaders, and by definition they are not equal.
The use of TestClass by the class that is using the JarClassLoader means
that the class object for TestClass used in the instanceof expression is
loaded by the class loader for the class using the JarClassLoader.
When you use the JarClassLoader, it creates a different class object for the
same class.
I would be very wary of using my own class loader in an Eclipse plug-in due
to the fact that the plug-in is running in an OSGi framework.
Namaste, Bruce
<dsahalo@gmx.net> wrote in message news:hlev2f$54u$1@build.eclipse.org...
> try {
> Object o = c.newInstance(); if (o instanceof TestClass) {
> TestClass tc = (TestClass) o; String test =
Previous Topic:Adding an item to the Source/generateGroup????
Next Topic:headless build issues/bugs
Current Time: Wed Jul 23 13:31:15 EDT 2025
Powered by FUDForum. Page generated in 0.04427 seconds
