Home » Eclipse Projects » Plugin Development Environment (PDE) » Listening for save events from an Editor
Listening for save events from an Editor [message #604407] Wed, 27 January 2010 05:40 Go to next message
Hi all,
In my application I use the XML Editor provided by the Web tools Platform (org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEdito rPart) to work with XML Files.
Now I would like to listen for the events thrown when the editor saves his contents to a file. Acording to what I have found on the web so far IExectionlisteners can be used to do this, so I implemented a listener and tried to add him to the Editor with the following code:
ICommandService service = (ICommandService)editorPart.getEditorSite().getService(IComm andService.class);
service.addExecutionListener(executionListener);
However this does not work, the Listener won't catch any events thrown by the Editor. I also tried the following two other methods to get the Commandservice, without success:
ICommandService service = (ICommandService)Activator.getDefault().getWorkbench().getSe rvice(ICommandService.class);
ICommandService service = (ICommandService)editorPart.getSite().getService(ICommandSer vice.class);
The Editor does save its changes to the file correctly, so that is not the Problem. Any idea what I'm doing wrong here?
Re: Listening for save events from an Editor [message #604415 is a reply to message #604407] Wed, 27 January 2010 06:55 Go to previous message
I just found out that it actually works with
if the File is saved using either the save button or that keyboard shortcut, but not if I exit a changed File and then save it in the resulting popup menu.
I Wonder if that is a bug.
Previous Topic:Listening for save events from an Editor
Next Topic:Replace default classloader for a Eclipse plugin
Current Time: Sat Nov 08 14:19:43 EST 2025
Powered by FUDForum. Page generated in 0.05116 seconds
