Home » Eclipse Projects » Plugin Development Environment (PDE) » Programmatically add an extension to a plug-in
Programmatically add an extension to a plug-in [message #604348] Sun, 24 January 2010 11:28 Go to next message
I need to programmatically add an extension to a plug-in project. This is part of the code I am using:
IPluginModelBase model = PluginRegistry.findModel(project);
IPluginExtension extension = createExtension(model, info.getExtensionPointId(),true);
IPluginElement element = model.getPluginFactory().createElement(extension);
element.setName(info.getName());
The element.setName() call is throwing an exception because the model is not editable. How do I create an editable model or is there a better way to add an extension?
Steve
Re: Programmatically add an extension to a plug-in [message #604370 is a reply to message #604348] Mon, 25 January 2010 11:42 Go to previous messageGo to next message
Hi Steve,
Did you figure out how to do this? I'm trying to do the same.
Best,
Louis.
Re: Programmatically add an extension to a plug-in [message #901476 is a reply to message #604370] Sun, 12 August 2012 17:48 Go to previous message
hi, did you Wink ?
(->msg_901475)
[Updated on: Sun, 12 August 2012 17:50] by Moderator
Previous Topic:Modify indent of tree elements
Next Topic:How to make a type work for the run mode?
Current Time: Wed Jul 23 07:46:28 EDT 2025
Powered by FUDForum. Page generated in 0.08713 seconds
