Home » Eclipse Projects » Plugin Development Environment (PDE) » Common Navigator Framework mouse events
Common Navigator Framework mouse events [message #604343] Sat, 23 January 2010 10:13 Go to next message
I've been learning how to use the CNF and read everything I can find on the web, but I'm a bit stuck on what seems to be a really trivial thing - opening an editor by clicking on an element in CNF which is provided by a content extension. I want to be able to double-click the element and open that element in my editor.
Any suggestions would be appreciated.
TIA
Re: Common Navigator Framework mouse events [message #604494 is a reply to message #604343] Wed, 03 February 2010 03:39 Go to previous message
if you use your own ContentNavogatorViewer you can override the
double-click method and call the Command for opening the editor.
Kind regards,
Simon
Alan Chaney schrieb:
> Hi
> TIA
Previous Topic:disabling project menu in menu bar
Next Topic:Problem with run configuration of a product
Current Time: Mon Jul 21 22:33:15 EDT 2025
Powered by FUDForum. Page generated in 0.03334 seconds
