Home » Archived » XML Schema Definition (XSD) » Problem with EMF generation from 2 XSDs
Problem with EMF generation from 2 XSDs [message #77818] Mon, 08 June 2009 13:07 Go to next message
I'm trying to generate the code representations of the following XSDs:
http://www.facturae.es/NR/rdonlyres/FA3C95E7-D50C-42CB-9E38- B97BCFDB3CC4/0/1Facturae30.xsd
http://www.w3.org/TR/xmldsig-core/xmldsig-core-schema.xsd
As you can see, the first one references the second through this element:
<xs:element ref="ds:Signature" minOccurs="0">
</xs:element>
After generating the code, when I try to test it using a sample XML I
receive a NullPointerException trying to parse that particular element.
I also try to use the editor that EMF generates to create a new XML
document for the first XSD, but although the "Signature" element is listed
as an available child in the corresponding drop-down list, the option is
grayed, so I can't select it.
I think that the problem may be in the fact that the referenced element is
from a different namespace. However, the second edition of EMF book, in
chapter 9.5.8 says that this option should be possible, so I'm puzzled.
By the way, the sample XML file is this one:
http://www.facturae.es/NR/rdonlyres/DB04EF8B-301E-459B-8852- 6193579E4FEF/0/factura2_ejemplo30.xml
Thanks in advance,
Rodrigo García
Re: Problem with EMF generation from 2 XSDs [message #77835 is a reply to message #77818] Mon, 08 June 2009 14:34 Go to previous messageGo to next message
Rodrigo,
It looks like the "#" in the target namespace is getting EMF upset;
that's normally the separator between a base URI and the fragment. If
you change the Facturae's GenPackage's "Initialize by Loading" property
to false, the null pointer problem goes away.
Rodrigo Garcia wrote:
> <xs:element ref="ds:Signature" minOccurs="0"> </xs:element>
> listed as an available child in the corresponding drop-down list, the
> option is grayed, so I can't select it.
> element is from a different namespace. However, the second edition of
> EMF book, in chapter 9.5.8 says that this option should be possible,
> so I'm puzzled.
> Thanks in advance,
> Rodrigo García
Re: Problem with EMF generation from 2 XSDs [message #77850 is a reply to message #77835] Tue, 09 June 2009 05:29 Go to previous message
Thanks for your quick response. My problem is now mostly solved. The
GenPackage property change did the trick.
Rodrigo García
Re: Problem with EMF generation from 2 XSDs [message #604230 is a reply to message #77818] Mon, 08 June 2009 14:34 Go to previous message
Rodrigo,
> so I'm puzzled.
> Thanks in advance,
> Rodrigo García
Re: Problem with EMF generation from 2 XSDs [message #604234 is a reply to message #77835] Tue, 09 June 2009 05:29 Go to previous message
Rodrigo García
Previous Topic:Problem with EMF generation from 2 XSDs
Next Topic:Defining mulitple persistency for EMF Model from one xsd
Current Time: Fri Oct 10 01:47:55 EDT 2025
Powered by FUDForum. Page generated in 0.05584 seconds
