Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Remove whitespaces from generation
Remove whitespaces from generation [message #76988] Wed, 28 March 2007 11:12 Go to next message
Originally posted by: matroska.libero.it
i am using emft jet generation to create java code however i cannot find
how to remove whitespaces (these whitespaces are that from used tags).
Thanks in advance
Tobia Loschiavo
Re: Remove whitespaces from generation [message #76997 is a reply to message #76988] Wed, 28 March 2007 17:05 Go to previous messageGo to next message
John,
Please use the M2T newsgroup for JET2 questions. I've added it to the
"to" list so Paul should see your question. He might need more detail
though. Often the goodness of the answer is proportional to the amount
of information provided in the question...
John Slave wrote:
> find how to remove whitespaces (these whitespaces are that from used
> tags).
> Thanks in advance
> Tobia Loschiavo
Re: Remove whitespaces from generation [message #77290 is a reply to message #76997] Thu, 29 March 2007 08:31 Go to previous messageGo to next message
John:
JET2 removes write space when a tag (or other language element) is alone on
a line.
Rule of thumb: If you don't want write space associated with a tag, put it
on its own line.
So:
<c:iterate select... >
Some code
</c:iterate>
Should produce
Some code
Some code
Some code
But, if you put a comment on the line
<c:iterate select... > <%-- a comment --%>
Some code
</c:iterate>
You'd get:
Some code
Some code
Some code
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:euelal$d3e$1@build.eclipse.org...
> John,
> though. Often the goodness of the answer is proportional to the amount of
> John Slave wrote:
>> Hi,
>> Thanks in advance
>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #77471 is a reply to message #77290] Thu, 29 March 2007 11:16 Go to previous messageGo to next message
Originally posted by: evaandoli.dodo.com.au
I get the same thing and yes I have comments all over the place trying to
make the text understandable.
Are you saying to remove these ghost blank lines you have to remove all
comments ? Seems a shame.
"Paul Elder" <pelder@ca.ibm.com> wrote in message
news:eugbj7$qk8$1@build.eclipse.org...
> John:
> on a line.
> on its own line.
> So:
> Some code
> </c:iterate>
> Should produce
> Some code
> Some code
> Some code
> Some code
> </c:iterate>
> You'd get:
> Some code
> Some code
> Some code
>> John,
>> John Slave wrote:
>>> Hi,
>>> Thanks in advance
>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #77851 is a reply to message #76997] Sat, 31 March 2007 11:31 Go to previous messageGo to next message
Something else I notice is a blank line appears in generation if you put a
<c:log> </c:log> line in.
> John,
> John Slave wrote:
>> Hi,
>> Thanks in advance
>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #77882 is a reply to message #77471] Mon, 02 April 2007 08:03 Go to previous messageGo to next message
Stu:
No, just put them on a separate line.
I'll have another look at the new line trimming algorthim to see if I can
make it more friendly with respect to comments. No promises for this
release, so it still comes down to, put your comments on a separate line.
<%-- Good: do something --%>
<c:iterate ... >
<c:iterate ...> <%-- Bad: will result in a an unexpected new line --%>
Paul
"Stu" <evaandoli@dodo.com.au> wrote in message
news:eugl88$70b$1@build.eclipse.org...
>> John:
>> on a line.
>> it on its own line.
>> So:
>> Some code
>> </c:iterate>
>> Should produce
>> Some code
>> Some code
>> Some code
>> Some code
>> </c:iterate>
>> You'd get:
>> Some code
>> Some code
>> Some code
>>> John,
>>> John Slave wrote:
>>>> Hi,
>>>> tags).
>>>> Thanks in advance
>>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #77898 is a reply to message #77882] Mon, 02 April 2007 08:21 Go to previous messageGo to next message
I have all comments on a separate line so it must be something else. I'll
look more into it and post something with more detail if I can narrow it
down.
The <c:log>Log here</c:log>
Seems to add a blank line is what I have found so far.
Cheers for all your time.
Stu
news:euqrei$jfl$1@build.eclipse.org...
> Stu:
> <c:iterate ... >
> Paul
>>> John:
>>> on a line.
>>> it on its own line.
>>> So:
>>> Some code
>>> </c:iterate>
>>> Should produce
>>> Some code
>>> Some code
>>> Some code
>>> Some code
>>> </c:iterate>
>>> You'd get:
>>> Some code
>>> Some code
>>> Some code
>>>> John,
>>>> John Slave wrote:
>>>>> Hi,
>>>>> tags).
>>>>> Thanks in advance
>>>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #78355 is a reply to message #77898] Wed, 04 April 2007 08:18 Go to previous messageGo to next message
Stu:
would add a line, while
<c:log>
Log here
</c:log>
will not.
The whitespace/line stripping would have to get smarter about the intent of
individual tags to successfully do the right thing on:
and, and the same time:
<f:lc>Lower Case here</f:lc>
I'll give it some thought. Here's a bugzilla to track it...
https://bugs.eclipse.org/bugs/show_bug.cgi?id=180927
Paul
news:euqsgl$rhf$1@build.eclipse.org...
>down.
> Stu
>> Stu:
>> <c:iterate ... >
>> Paul
>>>> John:
>>>> alone on a line.
>>>> it on its own line.
>>>> So:
>>>> Some code
>>>> </c:iterate>
>>>> Should produce
>>>> Some code
>>>> Some code
>>>> Some code
>>>> Some code
>>>> </c:iterate>
>>>> You'd get:
>>>> Some code
>>>> Some code
>>>> Some code
>>>>> John,
>>>>> amount of information provided in the question...
>>>>> John Slave wrote:
>>>>>> Hi,
>>>>>> tags).
>>>>>> Thanks in advance
>>>>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #79526 is a reply to message #78355] Thu, 12 April 2007 00:47 Go to previous messageGo to next message
Ok I got around to finding my problem with a blank line appearing when I
think it shouldnt.
Here is the line that caused trouble:-
PreText1
<c:addTextElement select="$conductorType/valueHolder" name="notFoundName"
var="notFound">NotFound</c:addTextElement>
PostText1
Output looks like:
PreText1
PostText1
I tried:-
var="notFound">
NotFound
</c:addTextElement>
but got the same result.
Stuart
news:ev053l$dvg$1@build.eclipse.org...
> Stu:
> <c:log>
> Log here
> </c:log>
> will not.
> of individual tags to successfully do the right thing on:
> Paul
>>down.
>> Stu
>>> Stu:
>>> can make it more friendly with respect to comments. No promises for this
>>> line.
>>> <c:iterate ... >
>>> Paul
>>>>to make the text understandable.
>>>>> John:
>>>>> alone on a line.
>>>>> put it on its own line.
>>>>> So:
>>>>> Some code
>>>>> </c:iterate>
>>>>> Should produce
>>>>> Some code
>>>>> Some code
>>>>> Some code
>>>>> Some code
>>>>> </c:iterate>
>>>>> You'd get:
>>>>> Some code
>>>>> Some code
>>>>> Some code
>>>>>> John,
>>>>>> the "to" list so Paul should see your question. He might need more
>>>>>> detail though. Often the goodness of the answer is proportional to
>>>>>> the amount of information provided in the question...
>>>>>> John Slave wrote:
>>>>>>> Hi,
>>>>>>> tags).
>>>>>>> Thanks in advance
>>>>>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #79835 is a reply to message #79526] Fri, 13 April 2007 08:17 Go to previous message
Stu:
Thanks for you persistence. I have filed bug 182311
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=182311). I'll be fixed
shortly.
Paul
news:evkdkp$952$1@build.eclipse.org...
> think it shouldnt.
> PreText1
> PostText1
> Output looks like:
> PreText1
> PostText1
> I tried:-
> var="notFound">
> NotFound
> </c:addTextElement>
> Stuart
Re: Remove whitespaces from generation [message #603923 is a reply to message #76988] Wed, 28 March 2007 17:05 Go to previous message
John,
John Slave wrote:
> tags).
> Thanks in advance
> Tobia Loschiavo
Re: Remove whitespaces from generation [message #603979 is a reply to message #76997] Thu, 29 March 2007 08:31 Go to previous message
John:
a line.
on its own line.
So:
Some code
</c:iterate>
Should produce
Some code
Some code
Some code
Some code
</c:iterate>
You'd get:
Some code
Some code
Some code
> John,
> John Slave wrote:
>> Hi,
>> Thanks in advance
>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #604024 is a reply to message #77290] Thu, 29 March 2007 11:16 Go to previous message
> John:
> on a line.
> on its own line.
> So:
> Some code
> </c:iterate>
> Should produce
> Some code
> Some code
> Some code
> Some code
> </c:iterate>
> You'd get:
> Some code
> Some code
> Some code
>> John,
>> John Slave wrote:
>>> Hi,
>>> Thanks in advance
>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #604156 is a reply to message #76997] Sat, 31 March 2007 11:31 Go to previous message
> John,
> John Slave wrote:
>> Hi,
>> Thanks in advance
>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #604170 is a reply to message #77471] Mon, 02 April 2007 08:03 Go to previous message
Stu:
<c:iterate ... >
Paul
>> John:
>> on a line.
>> it on its own line.
>> So:
>> Some code
>> </c:iterate>
>> Should produce
>> Some code
>> Some code
>> Some code
>> Some code
>> </c:iterate>
>> You'd get:
>> Some code
>> Some code
>> Some code
>>> John,
>>> John Slave wrote:
>>>> Hi,
>>>> tags).
>>>> Thanks in advance
>>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #604174 is a reply to message #77882] Mon, 02 April 2007 08:21 Go to previous message
down.
Stu
> Stu:
> <c:iterate ... >
> Paul
>>> John:
>>> on a line.
>>> it on its own line.
>>> So:
>>> Some code
>>> </c:iterate>
>>> Should produce
>>> Some code
>>> Some code
>>> Some code
>>> Some code
>>> </c:iterate>
>>> You'd get:
>>> Some code
>>> Some code
>>> Some code
>>>> John,
>>>> John Slave wrote:
>>>>> Hi,
>>>>> tags).
>>>>> Thanks in advance
>>>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #604333 is a reply to message #77898] Wed, 04 April 2007 08:18 Go to previous message
Stu:
<c:log>
Log here
</c:log>
will not.
Paul
>down.
> Stu
>> Stu:
>> <c:iterate ... >
>> Paul
>>>> John:
>>>> alone on a line.
>>>> it on its own line.
>>>> So:
>>>> Some code
>>>> </c:iterate>
>>>> Should produce
>>>> Some code
>>>> Some code
>>>> Some code
>>>> Some code
>>>> </c:iterate>
>>>> You'd get:
>>>> Some code
>>>> Some code
>>>> Some code
>>>>> John,
>>>>> John Slave wrote:
>>>>>> Hi,
>>>>>> tags).
>>>>>> Thanks in advance
>>>>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #604663 is a reply to message #78355] Thu, 12 April 2007 00:47 Go to previous message
think it shouldnt.
PreText1
PostText1
Output looks like:
PreText1
PostText1
I tried:-
var="notFound">
NotFound
</c:addTextElement>
Stuart
> Stu:
> <c:log>
> Log here
> </c:log>
> will not.
> Paul
>>down.
>> Stu
>>> Stu:
>>> line.
>>> <c:iterate ... >
>>> Paul
>>>>> John:
>>>>> alone on a line.
>>>>> So:
>>>>> Some code
>>>>> </c:iterate>
>>>>> Should produce
>>>>> Some code
>>>>> Some code
>>>>> Some code
>>>>> Some code
>>>>> </c:iterate>
>>>>> You'd get:
>>>>> Some code
>>>>> Some code
>>>>> Some code
>>>>>> John,
>>>>>> John Slave wrote:
>>>>>>> Hi,
>>>>>>> tags).
>>>>>>> Thanks in advance
>>>>>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #604735 is a reply to message #79526] Fri, 13 April 2007 08:17 Go to previous message
Stu:
shortly.
Paul
> think it shouldnt.
> PreText1
> PostText1
> Output looks like:
> PreText1
> PostText1
> I tried:-
> var="notFound">
> NotFound
> </c:addTextElement>
> Stuart
Previous Topic:[teneo] xsd that reference another xsd
Next Topic:[Teneo] Blank hibernate.hbm.xml?
Current Time: Tue Jul 22 02:52:46 EDT 2025
Powered by FUDForum. Page generated in 0.29170 seconds
