Home » Modeling » UML2 » Can enumerations specialize primitive types ?
Can enumerations specialize primitive types ? [message #471821] Tue, 27 March 2007 11:44 Go to next message
A UML Enumeration (metaclass) is a kind of UML Classifier (metaclass),
and the same is true for the UML PrimitiveType.
As we all know, Classifiers can have a Generalization association (and
relationship) between them.
Questions:
1. Does UML2 (i.e. the specs) allow that enumerations in a user model
specialize (via instance of the UML Generalization metaclass) primitive
types defined in a user model (e.g. in a model library) ?
Our specific use case would be that the user model defines an
enumeration which specalizes a primitive type defined in a model library
which specializes one of the UML defined primitive types (that latter
specialization we have working, the question is about the former).
2. Does the UML2 implementation of Eclipse support that ?
Andy
Re: Can enumerations specialize primitive types ? [message #471925 is a reply to message #471821] Tue, 27 March 2007 12:44 Go to previous messageGo to next message
Andy,
The UML2 spec prohibits this, so the UML2 implementation cannot support
it. Or at a minimum, must create a validation error if your model
includes such structures.
I use a model structure almost exactly like what you describe in my XSD
modeling tools, except that I define my datatype model libraries using
instances of DataType instead of PrimitiveType. Modeling this way, an
Enumeration *can* extend a DataType -- this is allowed by the spec. And
a DataType can extend a DataType. But a DataType cannot extend a
PrimitiveType.
Dave Carlson
> Questions:
> Andy
Re: Can enumerations specialize primitive types ? [message #471941 is a reply to message #471925] Wed, 28 March 2007 06:13 Go to previous messageGo to next message
Dave,
would you mind pointing me to the place in the UML specs where it says
that an Enumeration instance cannot specialize an PrimitiveType instance
by means of a Generalization instance ? I did not find any such
restriction in the UML Superstructure Spec V2.1.1.
Andy
Dave Carlson wrote:
> Andy,
> PrimitiveType.
> Cheers,
> Dave Carlson
>> Questions:
>> primitive types defined in a user model (e.g. in a model library) ?
>> library which specializes one of the UML defined primitive types (that
>> latter specialization we have working, the question is about the former).
>> Andy
Re: Can enumerations specialize primitive types ? [message #471944 is a reply to message #471941] Wed, 28 March 2007 08:22 Go to previous messageGo to next message
Andy,
It is a constraint on all Classifier generalizations, p. 54 of the 2.1.1
spec. PrimitiveType is a peer metaclass with Enumeration, both have
DataType as their superclass. Thus, PrimitiveType is not of the same or
more general type wrt Enumeration.
I investigated this a year ago, because I wanted to do exactly what you
are trying to do...
[8] The query maySpecializeType() determines whether this classifier may
have a generalization relationship to classifiers of
the specified type. By default a classifier may specialize classifiers
of the same or a more general type. It is intended to be
redefined by classifiers that have different specialization constraints.
Classifier::maySpecializeType(c : Classifier) : Boolean;
maySpecializeType = self.oclIsKindOf(c.oclType)
> Dave,
Re: Can enumerations specialize primitive types ? [message #471949 is a reply to message #471944] Wed, 28 March 2007 08:47 Go to previous messageGo to next message
In case it isn't clear, the wording of this query might rather use the term
"metaclass" than "type". So, read it as:
have a generalization relationship to classifiers of the specified
[metaclass]. By default a classifier may specialize classifiers
of the same or a more general [metaclass]. It is intended to be
Another important consequence of this constraint is that AssociationClasses
may specialize Classes, but not vice-versa.
I'll pick on the OCL representation of this constraint, too: note that
"oclType" is not a property (nor is "oclType()" an operation) defined by
OCL. As it stands, today, this constraint cannot be specified in OCL; OCL
provides no facility for reflection on the metamodel.
Christian
Dave Carlson wrote:
> Andy,
> are trying to do...
>> Dave,
Re: Can enumerations specialize primitive types ? [message #471962 is a reply to message #471949] Wed, 28 March 2007 11:26 Go to previous messageGo to next message
Dave, Christian,
I think it is clear now. Thanks!
I first was confused whether you are talking about specialization in a
user model, vs. specialization in the UML metaclass hierarchy, but the
key to understand is that the query maySpecializeType() defines a
default rule that (sort of) maps the UML metaclass inheritance hierarchy
into the type inheritance hierarchy of the user model.
I agree with Christian that the clarity of the text would benefit from
talking about metaclasses.
Let me know if you are aware of an existing OMG issue about this,
otherwise I'd submit one.
Thanks again for your help!
Andy
Christian W. Damus wrote:
> Cheers,
> Christian
> Dave Carlson wrote:
>> Andy,
>> are trying to do...
>>> Dave,
Re: Can enumerations specialize primitive types ? [message #471972 is a reply to message #471962] Wed, 28 March 2007 11:53 Go to previous message
Andy,
This issue is close to the topic you are questioning:
http://www.omg.org/issues/issue7223.txt
Also see my posting to the Eclipse UML2 newsgroup in Sept 2005 where I
cited this OMG issue. My reference to RSA in that posting referred to
RSA 6.0. That limitation has been resolved in RSA 7.
http://dev.eclipse.org/newslists/news.eclipse.tools.uml2/msg 01971.html
As far as I can see, the OMG issue has no response and no action plan...
Dave
> Andy
Re: Can enumerations specialize primitive types ? [message #603261 is a reply to message #471821] Tue, 27 March 2007 12:44 Go to previous message
Andy,
PrimitiveType.
Dave Carlson
> Questions:
> Andy
Re: Can enumerations specialize primitive types ? [message #604049 is a reply to message #471925] Wed, 28 March 2007 06:13 Go to previous message
Dave,
Andy
Dave Carlson wrote:
> Andy,
> PrimitiveType.
> Cheers,
> Dave Carlson
>> Questions:
>> Andy
Re: Can enumerations specialize primitive types ? [message #604053 is a reply to message #471941] Wed, 28 March 2007 08:22 Go to previous message
Andy,
are trying to do...
> Dave,
Re: Can enumerations specialize primitive types ? [message #604059 is a reply to message #471944] Wed, 28 March 2007 08:47 Go to previous message
Christian
Dave Carlson wrote:
> Andy,
> are trying to do...
>> Dave,
Re: Can enumerations specialize primitive types ? [message #604079 is a reply to message #471949] Wed, 28 March 2007 11:26 Go to previous message
Dave, Christian,
Andy
> Cheers,
> Christian
> Dave Carlson wrote:
>> Andy,
>> are trying to do...
>>> Dave,
Re: Can enumerations specialize primitive types ? [message #604094 is a reply to message #471962] Wed, 28 March 2007 11:53 Go to previous message
Andy,
Dave
> Andy
Previous Topic:Installing uml2...
Next Topic:Creating a Usage programmatically
Current Time: Sun Jul 27 15:37:12 EDT 2025
Powered by FUDForum. Page generated in 0.05525 seconds
