Home » Eclipse Projects » Plugin Development Environment (PDE) » Activator start() method won't get called.
Activator start() method won't get called. [message #603943] Tue, 05 January 2010 05:56 Go to next message
Hi!
My plugin has the following requirement: If any *.JAVA file has changed on the workspace, the last launched java file with a main() has to be launched again.
I have succesfully created an IResourceChangeListener implementation, but i have two problems.
1. Somehow my Activator class start() method won't get called, so i cannot call ResourcesPlugin.getWorkspace().addResourceChangeListener in the start method.
2. I cannot figured it out how to call the last launched java class from my IResourceChangeListener.
Thanks for any help.
Re: Activator start() method won't get called. [message #604041 is a reply to message #603943] Fri, 08 January 2010 15:52 Go to previous messageGo to next message
try using the org.eclipse.ui.startup extension point to register an early startup.
Implement the IStartup interface and add your ResourceChangeListeners in the earlyStartup method calling:
ResourcesPlugin.getWorkspace().addResourceChangeListener(Lis tener);
Best,
Artur
Re: Activator start() method won't get called. [message #604077 is a reply to message #603943] Mon, 11 January 2010 03:01 Go to previous message
It works, Thanks.
Previous Topic:Activator start() method won't get called.
Next Topic:How does PDE implement hotswapping of classes in an OSGi env?
Current Time: Thu Jul 24 20:42:58 EDT 2025
Powered by FUDForum. Page generated in 0.05154 seconds
