Home » Archived » XML Schema Definition (XSD) » XML schema "fixed" attribute and static final fields
XML schema "fixed" attribute and static final fields [message #76192] Tue, 11 November 2008 14:01 Go to next message
I am having some issues with EMF 2.4 generating static final fields that
correspond to the "fixed" attribute in the schema definition. For example,
using this snippet my from XML Schema definition:
<xs:attribute name="classCode" type="RoleClass" use="optional"
default="BIRTHPL"/>
Under EMF 2.2, this is what gets generated:
protected static final Object CLASS_CODE_DEFAULT =
CDAR2Factory.eINSTANCE.createFromString(CDAR2Package.getRole Class(),
"BIRTHPL");
protected Object classCode = CLASS_CODE_DEFAULT;
Under EMF 2.4, this is what gets generated:
protected static final Object CLASS_CODE_DEFAULT; // TODO: the default
literal value "BIRTHPL" is not valid.
which obviously fails compilation due to unassigned static final field.
What has changed between the two EMF versions that would cause this issue?
Is there a workaround?
JT
Re: XML schema "fixed" attribute and static final fields [message #76227 is a reply to message #76192] Tue, 11 November 2008 14:24 Go to previous messageGo to next message
John,
Comments below.
> that correspond to the "fixed" attribute in the schema definition. For
> example, using this snippet my from XML Schema definition:
> default="BIRTHPL"/>
> "BIRTHPL");
Probably I need to see more of the schema. What does RoleClass look
like? I wonder why its type would be java.lang.Object and not something
more specific...
> issue? Is there a workaround?
If you provide a test case I can use the reproduce the problem, I'll
look into it.
> JT
Re: XML schema "fixed" attribute and static final fields [message #76277 is a reply to message #76227] Tue, 11 November 2008 15:23 Go to previous message
I can email you more of the schema and/or a working project/test case. Due
to licensing and copyright issues with the schema, this may be the best
option.
JT
Re: XML schema "fixed" attribute and static final fields [message #603436 is a reply to message #76192] Tue, 11 November 2008 14:24 Go to previous message
John,
Comments below.
> default="BIRTHPL"/>
> "BIRTHPL");
more specific...
look into it.
> JT
Re: XML schema "fixed" attribute and static final fields [message #603451 is a reply to message #76227] Tue, 11 November 2008 15:23 Go to previous message
option.
JT
Previous Topic:Dealing with a set of large XML schemas
Next Topic:TODO: The default literal value "EnumMemberA" is invalid
Current Time: Fri Nov 07 02:23:33 EST 2025
Powered by FUDForum. Page generated in 0.04937 seconds
