Home » Archived » XML Schema Definition (XSD) » xsd.ecore is not based on ecore.ecore
xsd.ecore is not based on ecore.ecore [message #76158] Fri, 07 November 2008 10:35 Go to next message
Hi XSD developers,
I relate to org.eclipse.xsd_2.4.1.v200808251517.jar.
I found out, that xsd.ecore is unlike e.g. uml.ecore not based on
ecore.ecore.
Despite of the fact, that e.g. XSDConcreteComponent extends EObject, it
is not possible to access the functionality of ecore::EObject via
xsd::XSDConcreteComponent. Hence I cannot access e.g. the eResource()
method within an oAW xTend.
Can someone please explain to me, why the modeling of
XSDConcreteComponent in xsd.ecore is different from the JAVA code?
Have a look to uml.ecore to see how it can work. E.g. for uml::Package,
I can access all methods of ecore::EObject in an oAW xTend.
Joachim Back
Re: xsd.ecore is not based on ecore.ecore [message #76177 is a reply to message #76158] Fri, 07 November 2008 10:47 Go to previous message
Joachim,
Comments below.
Joachim Back wrote:
> Hi XSD developers,
> ecore.ecore.
Not sure what you mean by that. It certainly doesn't extend the Ecore
metamodel. UML shouldn't have either, but they ignored me. :-P
> it is not possible to access the functionality of ecore::EObject via
Why do you think it's not possible? It's definitely possible.
There's a difference between explicitly extending EObject (having the
EClass have EObject in the eSuperTypes) and implicitly extending it (all
modeled objects implement EObject and InternalEObject)...
> uml::Package, I can access all methods of ecore::EObject in an oAW xTend.
I think this is more a question for xtend. They should assume that
EObject's methods are available even if the model doesn't have explicit
inheritance.
> Regards,
> Joachim Back
Re: xsd.ecore is not based on ecore.ecore [message #603416 is a reply to message #76158] Fri, 07 November 2008 10:47 Go to previous message
Joachim,
Comments below.
Joachim Back wrote:
> Hi XSD developers,
> ecore.ecore.
inheritance.
> Regards,
> Joachim Back
Previous Topic:xsd.ecore is not based on ecore.ecore
Next Topic:XML schema "fixed" attribute and static final fields
Current Time: Mon Sep 15 01:42:57 EDT 2025
Powered by FUDForum. Page generated in 0.08840 seconds
