Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Persistent error when generating Teneo Hibernate mapping file
Persistent error when generating Teneo Hibernate mapping file [message #74219] |
Thu, 08 March 2007 08:59  |
Hi all,
Im currently attempting to use Teneo to provide a hibernate mapping for
my EMF model of a statistical metamodel.
Teneo does not seem to want to generate the mapping and therefore I have
now stripped my project back to a very simple .ecore file with only 3
classes, Person, Male and Female...each with a couple of attributes.
I generated the .ecore file from a Rose model.
Whenever I attempt to generate the Hibernate mapping using Teneo I get
the following error:
08-Mar-2007 13:29:12 org.eclipse.emf.teneo.hibernate.mapper.GenerateHBM main
SEVERE: Exception while instantiating , message:
There is no detail in the message at all....it always comes out blank.
I am using Eclipse 3.2 with EMF 2.2 and Teneo 0.8, JDK 1.5.
Any help, greatly appreciated.
regards
Duncan
Re: Persistent error when generating Teneo Hibernate mapping file [message #74239 is a reply to message #74219] |
Thu, 08 March 2007 09:08   |
Hi Duncan,
For eclipse 3.2 and emf 2.2 you need to use teneo 0.7.5 (the maintenance build).
If you still get the error after switching versions:
Are you generating through a right-click on the ecore file and then select a teneo submenu?
In this case you can check the error log (see windows > show view and then select error log).
See also this page:
http://www.elver.org/hibernate/troubleshooting.html#manualor mapper
You can also programmatically generate the mapping file through the HbHelper:
http://www.elver.org/hibernate/hbdatastore.html#Getting+the+ Hibernate+Mapping+XML
Just write a small main class and generate it from there.
gr. Martin
Duncan ALexander wrote:
> Hi all,
> for my EMF model of a statistical metamodel.
> main
> regards
> Duncan
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Persistent error when generating Teneo Hibernate mapping file [message #74294 is a reply to message #74239] |
Thu, 08 March 2007 10:57  |
Hi ,
Brilliant, thanks for the speedy response.
That seems to have solved my problem.
I've got another now but Ill start a new thread.
Duncan
Martin Taal wrote:
> Hi Duncan,
> build).
> See also this page:
> HbHelper:
> gr. Martin
>> Hi all,
>> mapping for my EMF model of a statistical metamodel.
>> have now stripped my project back to a very simple .ecore file with
>> only 3 classes, Person, Male and Female...each with a couple of
>> attributes.
>> regards
>> Duncan
Re: Persistent error when generating Teneo Hibernate mapping file [message #603277 is a reply to message #74219] |
Hi Duncan,
See also this page:
gr. Martin
> Hi all,
> main
> regards
> Duncan
The Netherlands
Re: Persistent error when generating Teneo Hibernate mapping file [message #603288 is a reply to message #74239] |
Hi ,
Duncan
Martin Taal wrote:
> Hi Duncan,
> build).
> See also this page:
> HbHelper:
> gr. Martin
>> Hi all,
>> attributes.
>> regards
>> Duncan
Current Time: Sun Jul 27 07:53:56 EDT 2025
Powered by FUDForum. Page generated in 0.24316 seconds
