Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Persistent error when generating Teneo Hibernate mapping file
Persistent error when generating Teneo Hibernate mapping file [message #74219] Thu, 08 March 2007 08:59 Go to next message
Hi all,
Im currently attempting to use Teneo to provide a hibernate mapping for
my EMF model of a statistical metamodel.
Teneo does not seem to want to generate the mapping and therefore I have
now stripped my project back to a very simple .ecore file with only 3
classes, Person, Male and Female...each with a couple of attributes.
I generated the .ecore file from a Rose model.
Whenever I attempt to generate the Hibernate mapping using Teneo I get
the following error:
08-Mar-2007 13:29:12 org.eclipse.emf.teneo.hibernate.mapper.GenerateHBM main
SEVERE: Exception while instantiating , message:
There is no detail in the message at all....it always comes out blank.
I am using Eclipse 3.2 with EMF 2.2 and Teneo 0.8, JDK 1.5.
Any help, greatly appreciated.
regards
Duncan
Re: Persistent error when generating Teneo Hibernate mapping file [message #74239 is a reply to message #74219] Thu, 08 March 2007 09:08 Go to previous messageGo to next message
Hi Duncan,
For eclipse 3.2 and emf 2.2 you need to use teneo 0.7.5 (the maintenance build).
If you still get the error after switching versions:
Are you generating through a right-click on the ecore file and then select a teneo submenu?
In this case you can check the error log (see windows > show view and then select error log).
See also this page:
http://www.elver.org/hibernate/troubleshooting.html#manualor mapper
You can also programmatically generate the mapping file through the HbHelper:
http://www.elver.org/hibernate/hbdatastore.html#Getting+the+ Hibernate+Mapping+XML
Just write a small main class and generate it from there.
gr. Martin
Duncan ALexander wrote:
> Hi all,
> for my EMF model of a statistical metamodel.
> main
> regards
> Duncan
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Persistent error when generating Teneo Hibernate mapping file [message #74294 is a reply to message #74239] Thu, 08 March 2007 10:57 Go to previous message
Hi ,
Brilliant, thanks for the speedy response.
That seems to have solved my problem.
I've got another now but Ill start a new thread.
Duncan
Martin Taal wrote:
> Hi Duncan,
> build).
> See also this page:
> HbHelper:
> gr. Martin
>> Hi all,
>> mapping for my EMF model of a statistical metamodel.
>> have now stripped my project back to a very simple .ecore file with
>> only 3 classes, Person, Male and Female...each with a couple of
>> attributes.
>> regards
>> Duncan
Re: Persistent error when generating Teneo Hibernate mapping file [message #603277 is a reply to message #74219] Thu, 08 March 2007 09:08 Go to previous message
Hi Duncan,
See also this page:
gr. Martin
> Hi all,
> main
> regards
> Duncan
The Netherlands
Re: Persistent error when generating Teneo Hibernate mapping file [message #603288 is a reply to message #74239] Thu, 08 March 2007 10:57 Go to previous message
Hi ,
Duncan
Martin Taal wrote:
> Hi Duncan,
> build).
> See also this page:
> HbHelper:
> gr. Martin
>> Hi all,
>> attributes.
>> regards
>> Duncan
Previous Topic:Teneo plan to support java5 annotations instead of EMF?
Next Topic:Missing model element when generating Teneo hibernate mapping
Current Time: Sun Jul 27 02:11:45 EDT 2025
Powered by FUDForum. Page generated in 0.04059 seconds
