Home » Eclipse Projects » Plugin Development Environment (PDE) » Does doc.zip no longer work in 3.5?
Does doc.zip no longer work in 3.5? [message #495732] |
Thu, 05 November 2009 15:47  |
Is there something special I need to do to make help content that is
contained in a doc.zip file show up properly in Eclipse 3.5?
I have a help plugin structured like this:
doc.zip (contains html/filename.html and pdf/filename.pdf as well as a whole
pile of images that have semi-random automatically generated filenames)
plugin.xml
toc.xml
nl/ja/JP/doc.zip
nl/ja/JP/toc.xml
When you click on the link to the HTML or PDF documents in the toc.xml, you
get a "Help Content Not found" message claiming the link to be broken. If I
unzip the contents of the doc.zip file into the plugin's jar, it can resolve
the links.
The zipped up version works just fine in Eclipse 3.4.
Kristina Taylor
Re: Does doc.zip no longer work in 3.5? [message #496291 is a reply to message #496237] |
Mon, 09 November 2009 10:48  |
I think I may have mischaracterized the problem. It turns out that this
doesn't work in Eclipse 3.4 either. I was basing that claim on what the QA
person told me, but it turns out she had the older version of our plugin
installed.
The older version of our plugin was packaged as a bunch of files loose in a
folder. The new version is all in one jar file (like the attached). If I
unzip the doc.zip file, and shove the contents back into the .jar, it can
find the HTML help file. Alternatively, if I unzip the entire .jar, but
leave the doc.zip content zipped up, it can find the HTML file. It looks
like the problem is that Eclipse won't handle a doc.zip file nested inside a
plugin.jar file. This is true in both Eclipse 3.4 and 3.5. I haven't
tested 3.3 and earlier.
Drop the attached file into your dropins/plugins directory, and you should
see the behaviour I'm talking about. I'm hoping there's something simple
I'm missing that I should be specifying in a manifest file or something to
get this to work.
Kristina
"Ankur Sharma" <ankur_sharma@in.ibm.com> wrote in message
news:4AF80A76.8040807@in.ibm.com...
> I am not replicate the behavior in 3.4. By the sound of it, it might be a
> bug we introduced in 3.5.
> If you can send me a sample plug-in, I may look more into it and possibly
> fix it too.
>> whole
>> plugin.xml
>> toc.xml
>> nl/ja/JP/doc.zip
>> nl/ja/JP/toc.xml
>> you
>> If I
>> resolve
>> the links.
>> Thanks,
>> Kristina Taylor
> hth,
> Ankur..
> Eclipse PDE UI Committer ? IBM India Software Lab, Bangalore
> +91-99456-94011 ? @ankur_sharma ? http://blog.ankursharma.org
Re: Does doc.zip no longer work in 3.5? [message #603114 is a reply to message #495732] |
Mon, 09 November 2009 07:26  |
I am not replicate the behavior in 3.4. By the sound of it, it might be a bug we introduced in 3.5.
If you can send me a sample plug-in, I may look more into it and possibly fix it too.
> plugin.xml
> toc.xml
> nl/ja/JP/doc.zip
> nl/ja/JP/toc.xml
> the links.
> Kristina Taylor
hth,
Ankur..
Re: Does doc.zip no longer work in 3.5? [message #603120 is a reply to message #496237] |
installed.
get this to work.
Kristina
> fix it too.
>> whole
>> plugin.xml
>> toc.xml
>> nl/ja/JP/doc.zip
>> nl/ja/JP/toc.xml
>> you
>> If I
>> resolve
>> the links.
>> Thanks,
>> Kristina Taylor
> hth,
> Ankur..
Current Time: Sun Jul 27 06:34:12 EDT 2025
Powered by FUDForum. Page generated in 0.24096 seconds
