Home » Eclipse Projects » Plugin Development Environment (PDE) » Hiding commands' UI elements
Hiding commands' UI elements [message #491154] Tue, 13 October 2009 09:31 Go to next message
Hello. I have a toggle Command that must toggle the visibility of four other Commands. They are all contributed to a view's toolbar as toolbar buttons. Does anyone know how to do this? Please help.
It sounds like it would be so simple, but I've been researching this and trying things for about 9 hours total now without any success. One thing I tried was having a static member variable in the toggle command's IHandler, which the other commands use in their isEnabled() methods to decide whether they should be enabled or not. The problem with this is that isEnabled() is only called at initialization (not to mention that the member having to be static means that it will toggle the commands in all instances of the view, but i'm desperate at this point.)
Re: Hiding commands' UI elements [message #491242 is a reply to message #491154] Tue, 13 October 2009 14:54 Go to previous messageGo to next message
I believe you are looking for activities in combination with your own
source provider.
This might help:
http://www.vogella.de/blog/2009/07/13/eclipse-activities/
http://www.vogella.de/articles/EclipseCommands/article.html# commmands_sourceprovider
Best regards, Lars
Re: Hiding commands' UI elements [message #495431 is a reply to message #491242] Wed, 04 November 2009 15:21 Go to previous message
Activities apparently only work on the whole workbench-scope; is there something that can show/hide UI elements depending on which view? For example, show them in one view, but hide them in another instance of the view (same view id).
<edit>Is there a way to do it with "contexts"? (org.eclipse.ui.context) </edit>
Thanks so much for that helpful information. This was a huge step. The SourceProvider came in useful for something too.
[Updated on: Wed, 04 November 2009 15:37] by Moderator
Re: Hiding commands' UI elements [message #603098 is a reply to message #491242] Wed, 04 November 2009 15:21 Go to previous message
Previous Topic:Some inter-plug-in dependencies have not been satisfied
Next Topic:Adding multiple dynamic menus
Current Time: Thu Jul 24 22:28:22 EDT 2025
Powered by FUDForum. Page generated in 0.04530 seconds
