Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Can't add data
[Teneo] Can't add data [message #73414] |
Thu, 01 March 2007 14:48  |
(oops -- forgot to put [Teneo] on subject)
I'm trying to add some emf objects like in the tutorial step 3. I can
create the root object, but then when I try to add something to a list in
that object, it doesn't work. The Server object below returns an
EList<Plugin> object. When I add a Plugin object to the EList, it seems to
work, but then when I read it back again, nothing is there. I put in a
flush, and reopened the session to see what would happen, and even
re-queried, but no use. I must be doing something incorrectly. Any ideas?
public Server addPlugin(String serverID,Plugin plugin) throws
ModelServiceException
Session session=sessionFactory.openSession();
Query query=session.createQuery("FROM Server where id='"+serverID+"'");
Server server=(Server)query.list().get(0);
getLogger().info("initial plugin count:"+server.getPlugins().size());
session.beginTransaction();
server.getPlugins().add(plugin);
session.getTransaction().commit();
session.flush();
session.close();
getLogger().info("new plugin count:"+server.getPlugins().size());
return server;
Output from the log statements shows count of zero.
Re: [Teneo] Can't add data [message #73438 is a reply to message #73414] |
Thu, 01 March 2007 14:59   |
Hi Paul,
Can you try to do session.saveOrUpdate(server) just before the commit?
gr. Martin
> session.flush();
> session.close();
> return server;
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Can't add data [message #73457 is a reply to message #73438] |
Thu, 01 March 2007 15:08   |
I had tried session.update(server) before, but I tried save and saveOrUpdate
as well, and I still get the same result.
Just to make sure I'm initializing correctly, here's the body of my
initialization method:
store = HbHelper.INSTANCE.createRegisterDataStore(DATA_STORE_NAME);
store.setEPackages(new EPackage[] { ModelPackage.eINSTANCE });
store.initialize();
sessionFactory = store.getSessionFactory();
In particular, is the setEPackages correct?
"Martin Taal" wrote in message news:es7bb2$tlq$1@utils.eclipse.org...
> Hi Paul,
> gr. Martin
>> to
>> ideas?
>> session.flush();
>> session.close();
>> return server;
> The Netherlands
Re: [Teneo] Can't add data [message #73474 is a reply to message #73457] |
Thu, 01 March 2007 15:16   |
Yes it looks fine. Can you print the mapping xml (store.getMappingXML()) and then post the mapping
for the server eclass?
Can you try to make other changes to the server object to see if they are persisted (or not)?
gr. Martin
> store.initialize();
>> Hi Paul,
>> gr. Martin
>>> to
>>> ideas?
>>> session.flush();
>>> session.close();
>>> return server;
>> The Netherlands
The Netherlands
Re: [Teneo] Can't add data [message #73873 is a reply to message #73457] |
Tue, 06 March 2007 21:29   |
Call session.save(plugin) before calling
I have noticed that EObjects instantiated by the model factory don't have
the right EList implementations until teneo becomes aware of them (thru the
session).
In particular, the first call to EList.add does not seem to work but
subsequent ones do.
If you left out session.save(plugin) but called the following line twice,
you would get a reference to the plugin.
Disclaimer: maybe I am completely wrong about this but moving my
session.save call up just fixed a problem that I was having adding
references too.
-mike
"Paul Gardiner" <pgardiner@syntellect.com> wrote in message
news:es7bso$upu$1@utils.eclipse.org...
>saveOrUpdate as well, and I still get the same result.
> store.initialize();
>> Hi Paul,
>> gr. Martin
>>> in
>>> to
>>> ideas?
>>> session.flush();
>>> session.close();
>>> return server;
>> The Netherlands
Re: [Teneo] Can't add data [message #73891 is a reply to message #73873] |
Tue, 06 March 2007 21:50  |
Mike,
Just for my understanding, what do you mean with this part of your post?
gr. Martin
> session).
> subsequent ones do.
> references too.
> -mike
>> store.initialize();
>>> Hi Paul,
>>> gr. Martin
>>>> in
>>>> to
>>>> ideas?
>>>> session.flush();
>>>> session.close();
>>>> return server;
>>> The Netherlands
The Netherlands
Re: [Teneo] Can't add data [message #603052 is a reply to message #73414] |
Hi Paul,
gr. Martin
> session.flush();
> session.close();
> return server;
The Netherlands
Re: [Teneo] Can't add data [message #603056 is a reply to message #73438] |
store.initialize();
> Hi Paul,
> gr. Martin
>> to
>> ideas?
>> session.flush();
>> session.close();
>> return server;
> The Netherlands
Re: [Teneo] Can't add data [message #603058 is a reply to message #73457] |
gr. Martin
> store.initialize();
>> Hi Paul,
>> gr. Martin
>>> to
>>> ideas?
>>> session.flush();
>>> session.close();
>>> return server;
>> The Netherlands
The Netherlands
Re: [Teneo] Can't add data [message #603185 is a reply to message #73457] |
session).
subsequent ones do.
references too.
-mike
> store.initialize();
>> Hi Paul,
>> gr. Martin
>>> in
>>> to
>>> ideas?
>>> session.flush();
>>> session.close();
>>> return server;
>> The Netherlands
Re: [Teneo] Can't add data [message #603189 is a reply to message #73873] |
Mike,
gr. Martin
> session).
> subsequent ones do.
> references too.
> -mike
>> store.initialize();
>>> Hi Paul,
>>> gr. Martin
>>>> in
>>>> to
>>>> ideas?
>>>> session.flush();
>>>> session.close();
>>>> return server;
>>> The Netherlands
The Netherlands
Current Time: Wed Jul 23 21:02:00 EDT 2025
Powered by FUDForum. Page generated in 0.11274 seconds
