Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Save of resource takes VERY long time
[Teneo] Save of resource takes VERY long time [message #73134] Wed, 28 February 2007 12:15 Go to next message
Martin,
I am now able to load my resource, and it is VERY fast. I am impressed
with the performance. Now, I have modified one attribute of one object,
and then call .save() on the resource. But the save operation takes VERY
long, many minutes. I have turned on debugging again and I see tons of
other objects being loaded during the save...? The debug output file grows
over 20M in just a few seconds.
Any ideas.?
Thanks again,
Mark.
Re: [Teneo] Save of resource takes VERY long time [message #73151 is a reply to message #73134] Wed, 28 February 2007 12:20 Go to previous messageGo to next message
Martin,
Some more info.
This VERY long save time only occurs on the first save. All the subsequent
saves occurs fairly quick, like you might expect.
It is the first save that takes sometimes 10 minutes.
Mark.
Re: [Teneo] Save of resource takes VERY long time [message #73187 is a reply to message #73151] Wed, 28 February 2007 13:11 Go to previous messageGo to next message
Martin,
I have stepped into the validateContents() method of StoreResource during
the saves. On the initial save, again only modifying on attribute of a
single object, the Hash modifiedEObjects contains 1304 objects. Doing the
same modification a second time the Hash modifiedEObjects is empty.
In all cases the modifications are saved.
Mark.
Re: [Teneo] Save of resource takes VERY long time [message #73205 is a reply to message #73187] Wed, 28 February 2007 13:26 Go to previous messageGo to next message
Martin,
Sorry, not modifiedEObjects, but newEObjects.
Mark.
Re: [Teneo] Save of resource takes VERY long time [message #73222 is a reply to message #73205] Wed, 28 February 2007 14:19 Go to previous messageGo to next message
Mark,
newEObjects should only contain objects which have been explicitly added to the resource. The loaded
eobjects (from the db) should not be there.
Can you set a breakpoint in the method StoreResource.addedEObject and then the line with
newEObjects.add?
I am interested to know why the objects are added to this arraylist.
gr. Martin
Mark wrote:
> Martin,
> Mark.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Save of resource takes VERY long time [message #73260 is a reply to message #73222] Wed, 28 February 2007 15:11 Go to previous messageGo to next message
Martin,
Here is the stack at the break point you asked for. The break point was
only hit about 10 times, not 1300. These calls to addedEObject() seem to
result from the call to getModelChildren() in the root editPart of the
tree view.
Mark.
HibernateResource(StoreResource).addedEObject(EObject) line: 519
HibernateResource(StoreResource).attachedHelper(EObject) line: 590
HibernateResource(StoreResource).attached(EObject) line: 543
FacilityImpl(BasicEObjectImpl).eBasicSetContainer(InternalEO bject, int,
NotificationChain) line: 912
FacilityImpl.basicSetEchostar(Echostar, NotificationChain) line: 196
FacilityImpl.eInverseAdd(InternalEObject, int, NotificationChain) line:
309
FacilityImpl(BasicEObjectImpl).eInverseAdd(InternalEObject, int, Class,
NotificationChain) line: 985
EReferencePropertyHandler.set(Object, Object, SessionFactoryImplementor)
line: 146
EMFTuplizer(AbstractEntityTuplizer).setPropertyValues(Object , Object[])
line: 337
SingleTableEntityPersister(AbstractEntityPersister).setPrope rtyValues(Object,
Object[], EntityMode) line: 3514
TwoPhaseLoad.initializeEntity(Object, boolean, SessionImplementor,
PreLoadEvent, PostLoadEvent) line: 129
OneToManyLoader(Loader).initializeEntitiesAndCollections(Lis t, Object,
SessionImplementor, boolean) line: 842
OneToManyLoader(Loader).doQuery(SessionImplementor, QueryParameters,
boolean) line: 717
OneToManyLoader(Loader).doQueryAndInitializeNonLazyCollectio ns(SessionImplementor,
QueryParameters, boolean) line: 224
OneToManyLoader(Loader).loadCollection(SessionImplementor, Serializable,
Type) line: 1985
OneToManyLoader(CollectionLoader).initialize(Serializable,
SessionImplementor) line: 36
OneToManyPersister(AbstractCollectionPersister).initialize(S erializable,
SessionImplementor) line: 565
DefaultInitializeCollectionEventListener.onInitializeCollect ion(InitializeCollectionEvent)
line: 60
SessionImpl.initializeCollection(PersistentCollection, boolean) line: 1716
PersistentList(AbstractPersistentCollection).initialize(bool ean) line: 344
PersistentList(AbstractPersistentCollection).read() line: 86
PersistentList.toArray() line: 123
HibernatePersistableEList<E>.doLoad() line: 134
HibernatePersistableEList<E>(PersistableEList<E>).load() line: 185
HibernatePersistableEList<E>(PersistableEList<E>).delegateIsEmpty() line: 349
HibernatePersistableEList<E>(DelegatingEList).isEmpty() line: 232
ServiceNavigator.createPartControl(Composite) line: 154
ViewReference.createPartHelper() line: 332
ViewReference.createPart() line: 197
ViewReference(WorkbenchPartReference).getPart(boolean) line: 566
WorkbenchPage$ActivationList.setActive(IWorkbenchPartReferen ce) line: 3915
WorkbenchPage.restoreState(IMemento, IPerspectiveDescriptor) line: 2929
WorkbenchWindow.restoreState(IMemento, IPerspectiveDescriptor) line: 1936
Workbench.doRestoreState(IMemento, MultiStatus) line: 2857
Workbench.access$14(Workbench, IMemento, MultiStatus) line: 2805
Workbench$19.run() line: 1681
Workbench.runStartupWithProgress(int, Runnable) line: 1421
Workbench.restoreState(IMemento) line: 1679
Workbench.access$12(Workbench, IMemento) line: 1650
Workbench$17.run() line: 1529
SafeRunner.run(ISafeRunnable) line: 37
Workbench.restoreState() line: 1473
WorkbenchConfigurer.restoreState() line: 183
SRDWorkbenchAdvisor(WorkbenchAdvisor).openWindows() line: 702
Workbench.init() line: 1085
Workbench.runUI() line: 1847
Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 419
PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 149
SRDEditor.run(Object) line: 29
PlatformActivator$1.run(Object) line: 78
EclipseAppLauncher.runApplication(Object) line: 92
EclipseAppLauncher.start(Object) line: 68
EclipseStarter.run(Object) line: 400
EclipseStarter.run(String[], Runnable) line: 177
NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not
available [native method]
NativeMethodAccessorImpl.invoke(Object, Object[]) line: 39
DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 25
Method.invoke(Object, Object...) line: 585
Main.invokeFramework(String[], URL[]) line: 336
Main.basicRun(String[]) line: 280
Main.run(String[]) line: 977
Main.main(String[]) line: 952
Re: [Teneo] Save of resource takes VERY long time [message #73278 is a reply to message #73260] Wed, 28 February 2007 15:21 Go to previous messageGo to next message
Martin,
It actually looks like any call which loads an object results in the
called to add the object to the new list...
Mark.
Re: [Teneo] Save of resource takes VERY long time [message #73296 is a reply to message #73260] Wed, 28 February 2007 15:21 Go to previous messageGo to next message
Okay part of it is a bug, in the HibernatePersistableEList.doLoad method the call to
((StoreResource) res).setIsLoading(true); should be done earlier.
However, I do not understand where the 1300 other objects in newEObjects come from as this is the
only location where newEObjects.add is done.
gr. Martin
Mark wrote:
> Martin,
> tree view.
> Mark.
> 309
> line: 146
> line: 337
> boolean) line: 717
> Type) line: 1985
> line: 60
> 1716
> 344
> line: 349
> 3915
> 1936
The Netherlands
Re: [Teneo] Save of resource takes VERY long time [message #73314 is a reply to message #73296] Wed, 28 February 2007 15:26 Go to previous messageGo to next message
Martin,
The other 1300 objects are loaded when I expand a tree item...That is
where I do the edit of the attribute. So the number of objects in the list
makes sense.
Mark.
Re: [Teneo] Save of resource takes VERY long time [message #73350 is a reply to message #73296] Thu, 01 March 2007 11:44 Go to previous messageGo to next message
Martin,
I found a helpful workaround. I added queries to the .ehb file to load the
offending objects at resource load time. At least this minimizes the
initial save time.
Is there a roadmap for the next release...?
Thanks again,
Mark.
Re: [Teneo] Save of resource takes VERY long time [message #73368 is a reply to message #73350] Thu, 01 March 2007 12:05 Go to previous message
Mark,
The overall roadmap is here:
http://www.elver.org/hibernate/status.html
although I don't update this page very often....
If you mean the next release then within a week or so.
gr. Martin
Mark wrote:
> Martin,
> the offending objects at resource load time. At least this minimizes the
> initial save time.
> Thanks again,
> Mark.
The Netherlands
Re: [Teneo] Save of resource takes VERY long time [message #603003 is a reply to message #73134] Wed, 28 February 2007 12:20 Go to previous message
Martin,
Some more info.
Mark.
Re: [Teneo] Save of resource takes VERY long time [message #603012 is a reply to message #73151] Wed, 28 February 2007 13:11 Go to previous message
Martin,
Mark.
Re: [Teneo] Save of resource takes VERY long time [message #603015 is a reply to message #73187] Wed, 28 February 2007 13:26 Go to previous message
Martin,
Mark.
Re: [Teneo] Save of resource takes VERY long time [message #603017 is a reply to message #73205] Wed, 28 February 2007 14:19 Go to previous message
Mark,
newEObjects.add?
gr. Martin
Mark wrote:
> Martin,
> Mark.
The Netherlands
Re: [Teneo] Save of resource takes VERY long time [message #603025 is a reply to message #73222] Wed, 28 February 2007 15:11 Go to previous message
Martin,
tree view.
Mark.
309
line: 146
line: 337
boolean) line: 717
Type) line: 1985
line: 60
Re: [Teneo] Save of resource takes VERY long time [message #603027 is a reply to message #73260] Wed, 28 February 2007 15:21 Go to previous message
Martin,
Mark.
Re: [Teneo] Save of resource takes VERY long time [message #603031 is a reply to message #73260] Wed, 28 February 2007 15:21 Go to previous message
gr. Martin
Mark wrote:
> Martin,
> tree view.
> Mark.
> 309
> line: 146
> line: 337
> boolean) line: 717
> Type) line: 1985
> line: 60
> 1716
> 344
> line: 349
> 3915
> 1936
The Netherlands
Re: [Teneo] Save of resource takes VERY long time [message #603032 is a reply to message #73296] Wed, 28 February 2007 15:26 Go to previous message
Martin,
makes sense.
Mark.
Re: [Teneo] Save of resource takes VERY long time [message #603036 is a reply to message #73296] Thu, 01 March 2007 11:44 Go to previous message
Martin,
initial save time.
Thanks again,
Mark.
Re: [Teneo] Save of resource takes VERY long time [message #603039 is a reply to message #73350] Thu, 01 March 2007 12:05 Go to previous message
Mark,
gr. Martin
Mark wrote:
> Martin,
> initial save time.
> Thanks again,
> Mark.
The Netherlands
Previous Topic:[Teneo] Date and DateTime mapping?
Next Topic:can't add data
Current Time: Sat Nov 08 02:19:46 EST 2025
Powered by FUDForum. Page generated in 0.06261 seconds
