Home » Archived » XML Schema Definition (XSD) » Changing XSDSchema / Clone
Changing XSDSchema / Clone [message #74241] |
Mon, 21 April 2008 17:38  |
Originally posted by: spotthoff.gmx.de
I am trying to change a XSDSchema Object. In my use case I want to change
just a copy of this schema not the original one.
Everything seems to work fine but the cloning does not clone the complexe
types as it seems. In my understanding both lines below should have the
same result concerning the code at the end.
All complexe Types are null. Why? Where is my fault?
1. change.test((XSDSchema)schema.cloneConcreteComponent(true, false));
2. change.test(schema);
But the result of statement 1 is:
bla 2: SKU - org.eclipse.xsd.impl.XSDSimpleTypeDefinitionImpl@1a99561
(element: null) (name: SKU, targetNamespace: null) (variety: <unset>,
final: null, lexicalFinal: null, validFacets: null)
bla 2: USState - org.eclipse.xsd.impl.XSDSimpleTypeDefinitionImpl@8e32e7
(element: null) (name: USState, targetNamespace: null) (variety: <unset>,
and of statement 2:
bla 1: herstellerorg.eclipse.xsd.impl.XSDParticleImpl@1a99561 (element:
[xs:all: null]) (minOccurs: <unset>, maxOccurs: <unset>)
bla 1: Itemsorg.eclipse.xsd.impl.XSDParticleImpl@8e32e7 (element:
[xs:sequence: null]) (minOccurs: <unset>, maxOccurs: <unset>)
bla 1: partsorg.eclipse.xsd.impl.XSDParticleImpl@1b000e7 (element:
bla 1: PurchaseOrderTypeorg.eclipse.xsd.impl.XSDParticleImpl@b76fa
(element: [xs:sequence: null]) (minOccurs: <unset>, maxOccurs: <unset>)
bla 2: SKU - org.eclipse.xsd.impl.XSDSimpleTypeDefinitionImpl@b01d43
(element: [xs:simpleType: null]) (name: SKU, targetNamespace: null)
(variety: atomic, final: [], lexicalFinal: null, validFacets: [length,
minLength, maxLength, pattern, enumeration, whiteSpace])
bla 1: USAddressorg.eclipse.xsd.impl.XSDParticleImpl@513cf0 (element:
bla 2: USState - org.eclipse.xsd.impl.XSDSimpleTypeDefinitionImpl@177b3cd
(element: [xs:simpleType: null]) (name: USState, targetNamespace: null)
#### Test Code:
private void test(XSDSchema s){
XSDTypeDefinition type = null;
EList <XSDTypeDefinition> types = s.getTypeDefinitions();
for(Iterator<XSDTypeDefinition> it = types.iterator();
it.hasNext();){
XSDTypeDefinition typ = it.next();
if(typ.getComplexType()!= null){
XSDParticle t = typ.getComplexType();
System.out.println("bla1: " + typ.getName() + t);
if(typ.getSimpleType()!= null){
System.out.println("bla2: " + typ.getName() +
typ.getSimpleType());
Re: Changing XSDSchema / Clone [message #74259 is a reply to message #74241] |
Mon, 21 April 2008 18:12   |
Spotti,
I'm really not sure I understand 1. verses 2... Keep in mind that
imports and includes will not be resolved if
xsdSchema.getSchemaLocation() == null; generally the schema location
will be set when the XSDSchema is added to an XSDResourceImpl's
getContents, at which point the location will be set to the resource's
URI...
spotti wrote:
> change just a copy of this schema not the original one.
> complexe types as it seems. In my understanding both lines below
> should have the same result concerning the code at the end. All
> bla 2: USState -
> org.eclipse.xsd.impl.XSDSimpleTypeDefinitionImpl@8e32e7 (element:
> null) (name: USState, targetNamespace: null) (variety: <unset>, final:
> and of statement 2:
> (element: [xs:all: null]) (minOccurs: <unset>, maxOccurs: <unset>)
> bla 2: USState -
> org.eclipse.xsd.impl.XSDSimpleTypeDefinitionImpl@177b3cd (element:
> #### Test Code:
> it.hasNext();){
Re: Changing XSDSchema / Clone [message #74291 is a reply to message #74275] |
Mon, 21 April 2008 19:33  |
Spotti,
References to types, even if they are in the same schema, will not be
resolved until the schema is assigned a schema location. In fact, all
references will resolve to placeholders (objects not contained by any
schema) until the schema location has been set. So, in general, a
schema that's not contained in XSDResourceImpl (which indirectly sets
the resource's URI as the schema's location) will not be all that
functionally completely. If you want to work with a schema that's fully
analyzed and has properly resolved references it will need to be in a
resource within a resource set.
spotti wrote:
> The difference between these examples lies in the output. The schema
> object in version one does not have any complexe types which are not
> null. In version 2, the uncloned schema object, simple AND complexe
> type are found which are not null.
> my example xsd-file does not have any imports or includes. It is
> confusing that SimpleTypeDefinitions are not null contrasting the
> complexe types.
> My goal is to change the schema and decide later whether to write the
> new or the old unchanged schema. While the changes are done on the new
> version(or copy) I read out the old one. Therefor I need both
> versions. Otherwise I get an exception.
Re: Changing XSDSchema / Clone [message #602980 is a reply to message #74241] |
Spotti,
URI...
spotti wrote:
> bla 2: USState -
> and of statement 2:
> bla 2: USState -
> #### Test Code:
> it.hasNext();){
Re: Changing XSDSchema / Clone [message #602984 is a reply to message #74259] |
Mon, 21 April 2008 18:35  |
object in version one does not have any complexe types which are not null.
In version 2, the uncloned schema object, simple AND complexe type are
my example xsd-file does not have any imports or includes. It is confusing
that SimpleTypeDefinitions are not null contrasting the complexe types.
My goal is to change the schema and decide later whether to write the new
version(or copy) I read out the old one. Therefor I need both versions.
Re: Changing XSDSchema / Clone [message #602988 is a reply to message #74275] |
Spotti,
> complexe types.
Current Time: Thu Jul 24 23:08:07 EDT 2025
Powered by FUDForum. Page generated in 0.08380 seconds
