Home » Archived » Visual Editor (VE) » javaw multiple processes when working with VE
javaw multiple processes when working with VE [message #70295] Mon, 08 November 2004 11:37 Go to next message
Originally posted by: mnatali.bezeqint.net
Hi!
I am a newbie and beg your pardon if the question I want to ask has been
already discussed to death. I've paid attention that when I work with the
VE
(edit/run/stop the Java application) consequently, Task Manager shows me
the growing number of the javaw processes. What can be a reason? Do I do
something wrong? Is it because of VE?
Thanx!
Re: javaw multiple processes when working with VE [message #70337 is a reply to message #70295] Mon, 08 November 2004 12:52 Go to previous messageGo to next message
We need to start another java process up because we need to do
introspection, and we need to run your code so that we can screen scrape
it to the picture you see. We can't do it in the same java process as
the IDE becuase it may not be the same java version, and we don't want
to run user code in the IDE because it could crash the IDE, and because
the class keep changing as you are editing and this causes problems with
class loading because there's no easy way to unload a class and load in
a new version of it without using sophisticated class loader techniques.
Rich Kulp
Re: javaw multiple processes when working with VE [message #70417 is a reply to message #70337] Mon, 08 November 2004 16:22 Go to previous messageGo to next message
Originally posted by: cdouglas.NOSPAMoz.net
Rich Kulp <richkulp@us.NO_SPAM.ibm.com> wrote in news:cmobo5$1m5$2
@eclipse.org:
Would it be possible to not show the client VM in the Windows task list?
This is the real issue here -- I don't think anyone cares that you start a
separate process. What is frustrating is having that new task "appear" on
your task bar, but you can't select it even though it has the name of your
app on it.
Also, once you start running/debugging your app, you know have *two* of
these on your task list, with no obvious differentiation other than "when I
click on this one nothing happens and when I click on this one I get my app
back".
Chas Douglass
Re: javaw multiple processes when working with VE [message #70437 is a reply to message #70417] Mon, 08 November 2004 16:48 Go to previous messageGo to next message
We would like to not show it, but Java doesn't have an API to hide it.
On Windows, we'd have to write JNI code, but even if we did, we'd have
to find the handle for the window, and Java doesn't expose the handle.
We could probably kludge something up but we have so many other things
on the plate too.
It's even worse in Linux, so far we have found no API what-so-ever, even
in JNI land, that can be used to not show it.
Rich Kulp
Re: javaw multiple processes when working with VE [message #70456 is a reply to message #70437] Mon, 08 November 2004 18:03 Go to previous messageGo to next message
Rich Kulp <richkulp@us.NO_SPAM.ibm.com> wrote in news:cmophj$bei$1
@eclipse.org:
> on the plate too.
I suspected as much, but it's good to know it has been looked into.
Chas Douglass
Re: javaw multiple processes when working with VE [message #70515 is a reply to message #70337] Tue, 09 November 2004 03:05 Go to previous message
Thank you!
Natasha
Re: javaw multiple processes when working with VE [message #602717 is a reply to message #70295] Mon, 08 November 2004 12:52 Go to previous message
Rich Kulp
Re: javaw multiple processes when working with VE [message #602743 is a reply to message #70337] Mon, 08 November 2004 16:22 Go to previous message
@eclipse.org:
app on it.
back".
Chas Douglass
Re: javaw multiple processes when working with VE [message #602750 is a reply to message #70417] Mon, 08 November 2004 16:48 Go to previous message
on the plate too.
Rich Kulp
Re: javaw multiple processes when working with VE [message #602756 is a reply to message #70437] Mon, 08 November 2004 18:03 Go to previous message
@eclipse.org:
> on the plate too.
Chas Douglass
Re: javaw multiple processes when working with VE [message #602778 is a reply to message #70337] Tue, 09 November 2004 03:05 Go to previous message
Thank you!
Natasha
Previous Topic:No menu class support using ve 1.0.1 and swt?
Next Topic:VE shows "IWAV0170I Connection creation failed" when trying to load/show a frame
Current Time: Wed Sep 03 10:01:28 EDT 2025
Powered by FUDForum. Page generated in 0.07627 seconds
