Home » Archived » Visual Editor (VE) » can't make VE to work with eclipse3
can't make VE to work with eclipse3 [message #69709] Tue, 02 November 2004 23:06 Go to next message
Originally posted by: eclipse3.spymac.com
i am a newbie to eclipse, i have copied ve into eclipse directory, and i
can see the plugin features in about eclipse platform, but i can't open
..java file with ve editor, i couldn't see the option there inside the
menu. thanks very much :)
Andy
Re: can't make VE to work with eclipse3 [message #69811 is a reply to message #69709] Wed, 03 November 2004 09:57 Go to previous messageGo to next message
Make sure you also installed Eclipse SDK (not the RCP, or runtime), EMF
2.0.1, and GEF 3.0.1, and make sure you ran eclipse once with the -clean
option.
Rich Kulp
Re: can't make VE to work with eclipse3 [message #69846 is a reply to message #69811] Wed, 03 November 2004 10:01 Go to previous messageGo to next message
OR use the update manager instead, it will tell you what pre-reqs are
required and not allow an install until then, and it makes sure
everything is installed correctly.
I recommend using the update manager when you want to installed released
versions of code.
Rich Kulp
Re: can't make VE to work with eclipse3 [message #69965 is a reply to message #69846] Thu, 04 November 2004 00:06 Go to previous messageGo to next message
thanks so much:)
i am going to try it now
> versions of code.
Re: can't make VE to work with eclipse3 [message #70276 is a reply to message #69709] Mon, 08 November 2004 11:14 Go to previous message
Originally posted by: steve.sclarkes.me.uk
"andy" <eclipse3@spymac.com> wrote in message
news:cm9kur$nil$1@eclipse.org...
>.java file with ve editor, i couldn't see the option there inside the menu.
>thanks very much :)
> Andy
I'm having the same problem. I've tried everything mentioned in all the
various posts on this subject but without success.
For the record I installed via unzipping the following files:
eclipse-JDT-SDK-3.0.1.zip
eclipse-platform-SDK-3.0.1-win32.zip
emf-sdo-SDK-2.0.1.zip
GEF-SDK-3.0.1.zip
VE-SDK-1.0.1.1.zip
I didn't start eclipse at all until all files were unzipped.
I installed into a new directory and a clean workspace.
I tried -clean.
There were no errors logged.
I also tried with the runtime versions rather than SDKs ... and many other
combinations.
I tried under Linux as well as Windows.
I tried using update manager to install VE.
After many hours I'm about to give up ! Any more ideas ?
Steve
Re: can't make VE to work with eclipse3 [message #602542 is a reply to message #69709] Wed, 03 November 2004 09:57 Go to previous message
option.
Rich Kulp
Re: can't make VE to work with eclipse3 [message #602554 is a reply to message #69811] Wed, 03 November 2004 10:01 Go to previous message
versions of code.
Rich Kulp
Re: can't make VE to work with eclipse3 [message #602597 is a reply to message #69846] Thu, 04 November 2004 00:06 Go to previous message
thanks so much:)
> versions of code.
Re: can't make VE to work with eclipse3 [message #602697 is a reply to message #69709] Mon, 08 November 2004 11:14 Go to previous message
>thanks very much :)
> Andy
GEF-SDK-3.0.1.zip
VE-SDK-1.0.1.1.zip
I tried -clean.
combinations.
Steve
Previous Topic:Visual Editor installation problems
Next Topic:javaw multiple processes when working with VE
Current Time: Fri Nov 07 08:39:57 EST 2025
Powered by FUDForum. Page generated in 0.04576 seconds
