Home » Archived » Visual Editor (VE) » Use VE from Composite i.s.o Shell
Use VE from Composite i.s.o Shell [message #69752] Wed, 03 November 2004 06:47 Go to next message
Originally posted by: lf_killspam.hemmis.be
I just started using the VE this morning, but I am already confronted
with a limitation I did not expect. But maybe it is not a limitation at
all and am I just using the VE the wrong way.
I thought I could use VE to put components on a composite. So I started
by creating a class which extends Composite, which I then opened with
the visual editor. But then I was not able to put any components on my
composite. I had to start with a Shell on which I was then able to all
the components I wanted and change their properties.
But that is not exactly what I wanted to do. I would like to create
parts (as Composites) of a window (shell) with the visual editor and
then, based on certain user preferences, put several of those 'parts'
together on 1 shell. Is it possible to start of with the VE from a
composite instead of having to create a shell in every 'visual class'?
Re: Use VE from Composite i.s.o Shell [message #69827 is a reply to message #69752] Wed, 03 November 2004 09:58 Go to previous messageGo to next message
Instead of creating the composite by hand first, use the New->Visual
Class wizard instead, and choose the style SWT->Composite. This will
make sure everything about the project and the class are set up correctly.
Rich Kulp
Re: Use VE from Composite i.s.o Shell [message #69865 is a reply to message #69827] Wed, 03 November 2004 11:11 Go to previous messageGo to next message
Actually, that was part of my problem. I was not able to find the
'File->New->Visual Class' wizard in the menu, so I tried things by hand.
But I had not been looking very well. I found it in
'File->New->Other->Java->New Visual Class'.
Would this be because I am working in the PDE (I'm working on a RCP
application), or is it an error in the VE help?
Anyway. Thanks for the help Rich. Works perfectly now.
Re: Use VE from Composite i.s.o Shell [message #69885 is a reply to message #69865] Wed, 03 November 2004 11:20 Go to previous message
There are two possibilities, one is your are installing into a
configuration after you had customized the perspective. Customized
perspectives don't always show the new shortcuts near the top. Or the
second is your perspective is not the Java or Java Browsing perspective.
The shortcuts are only added to those perspectives because you normally
would only be doing java developement from those perspectives.
Rich Kulp
Re: Use VE from Composite i.s.o Shell [message #602545 is a reply to message #69752] Wed, 03 November 2004 09:58 Go to previous message
Rich Kulp
Re: Use VE from Composite i.s.o Shell [message #602560 is a reply to message #69827] Wed, 03 November 2004 11:11 Go to previous message
Re: Use VE from Composite i.s.o Shell [message #602567 is a reply to message #69865] Wed, 03 November 2004 11:20 Go to previous message
Rich Kulp
Previous Topic:Does Eclipse have any VE development tool?
Next Topic:Eclipse or JGraph ???
Current Time: Fri Sep 19 02:43:55 EDT 2025
Powered by FUDForum. Page generated in 0.04972 seconds
