Home » Archived » GMT (Generative Modeling Technologies) » [TCS] Inverted Coma symbol
[TCS] Inverted Coma symbol [message #378437] |
Fri, 06 July 2007 10:19  |
Originally posted by: remi.viaux.mbda-systems.com
I have a problem to insert the symbol inverted coma (ie " ) in symbole
table of my .tcs file.
I have tried to handle it with the '\' escape character like this :
template include :
"#""include" "\""
symbols {
invcoma "\""
But I have got this error message from antlr :
[antlr]./file.g:290.178 : unexpected char : '/'
[antlr]TokenStreamException : unexpected char : '-'
Has somebody a solution to defined the inverted coma as a symbol ?
Remi Viaux
PS : I'm just a beginner in TCS so I hope my question won't be too naïve.
Re: [TCS] Inverted Coma symbol [message #378451 is a reply to message #378448] |
Mon, 09 July 2007 05:14   |
Originally posted by: quentin.glineur.obeo.fr
Hi Remi,
It seems that you are trying redefine something that TCS already does
another way.
Among the first thing to build a recognizer is to define what is an
identifier and what is a literal.
Typically, tokens after an include directive (enclosed by '"') are
string literals.
Thus, your lexer part should contain a rule to tokenize string literals:
STRING
( '\\n' {newline();}
| ~('\\"'|'\\n')
Then your syntax part should contain a primitive template:
primitiveTemplate stringSymbol for String using STRING:
value = "%token%",
serializer="'\"' + %value%.toCString() + '\"'";
and a rule looking like this one :
template includeDirective :
"#" "include" include_file{as=stringSymbol}
Quentin Glineur
Remi Viaux a écrit :
> Hello Frederic,
> Yes, of course " is used to delimited strings and keywords but I want it
> to take the role of a simple character.
> How can I do ?
> in the .g file I can see that the symbol is correctly interpreted :
> include returns ....
> SHARP "include" INVCOMA temp=identifier {ei.set(ret,"machin",temp);}
> INVCOMA)
> INVCOMA
> Remi Viaux
Re: [TCS] Inverted Coma symbol [message #378504 is a reply to message #378451] |
Tue, 17 July 2007 07:48   |
Hi Quentin,
I have tried to rewrite this new primitive template and it's theems to
recognize "___" as stringSymbol.
But I think this can't resolve my problem, because I don't want to
recognize string in code (that's what the lexer do I think), I want to use
" as a keyword like other symbols like '#' can already do.
The purpose is to make the difference between :
' include "local" ' and ' include <global> '
Remi Viaux
Quentin Glineur wrote:
> Hi Remi,
> another way.
> string literals.
> STRING
> ( '\n' {newline();}
> | ~('\"'|'\n')
> value = "%token%",
> serializer="'"' + %value%.toCString() + '"'";
> Regards,
> Quentin Glineur
>> Hello Frederic,
>> How can I do ?
>> INVCOMA)
>> INVCOMA
>> Thanks,
>> Remi Viaux
Re: [TCS] Inverted Coma symbol [message #378524 is a reply to message #378513] |
Mon, 23 July 2007 07:56   |
It's seems impossible to redefine " as a keyword, I tried many solutions
with backslashes but it doesn't work ...
I'm yet trying to redefine a primitive template to recognize strings like
this : "< file.h >" . But I don't know how to write it ...
I don't know if I have to change the STRING lexer, write another lexer or
just create a primitive template with a serilizer.
Can someone help me with the ANTLR syntax ?
Remi Viaux
>> Hi Quentin,
> You are right !
>> use " as a keyword like other symbols like '#' can already do.
> If it is what you REALLY want, the way to put it in the symbols list is
> to use 3 backslash (it is due to special escape character rendering.
> Maybe you could define another primitiveTemplate dedicated to
> <something> token recognition.
> Then having your class for "include" statement abstract and defining two
> class inheriting from this previous in order to define their respective
> textual form.
> KM3 :
> abstract class includeStmt {
> attribute includedFile : String;
> class localIncludeStmt extends includeStmt {
> class globalIncludeStmt extends includeStmt{
> TCS :
> template includeStmt abstract;
> template localIncludeStmt :
> "include" includedFile {as=stringLiteral}
> template globalIncludeStmt :
> "include" includedFile {as=chevronLiteral}
> I recommend you so because I have a hunch about problems that defining a
> token colliding with other could lead to.
> HTH,
> Quentin GLINEUR
>> Thanks,
>> Remi Viaux
>>> Hi Remi,
>>> another way.
>>> string literals.
>>> STRING
>>> ( 'n' {newline();}
>>> | ~('"'|'n')
>>> value = "%token%",
>>> Regards,
>>> Quentin Glineur
>>>> Hello Frederic,
>>>> it to take the role of a simple character.
>>>> How can I do ?
>>>> INVCOMA)
>>>> INVCOMA
>>>> Thanks,
>>>> Remi Viaux
Re: [TCS] Inverted Coma symbol [message #378528 is a reply to message #378526] |
Wed, 25 July 2007 08:18   |
>> Hi,
> Indeed, the way ANTLR works makes the thing tricky: the lexer tokenizes
> the character stream before passing it to the parser. So if it finds
> double quotes, it will search in its lexer rules how to tokenize it,
> *independently* of what you have defined in your parser rules !
Thanks for the exponation about how ANTLR works it helps me a lot !
> Think of your parser rules (your templates) as mere filters. When token
> stream passes through a filter, it is handled the way defined by the
> rule (in our case, creating the corresponding model element).
>> like this : "< file.h >" . But I don't know how to write it ... I don't
>> know if I have to change the STRING lexer, write another lexer or just
> Try this in the lexer part:
> protected CHEVRON_REGEX
I have try this Lexer but, It seems that it doesn't work. At the injection
I've got the error : "expecting CHEVRON_REGEX found '<'".
> or even better, in the TCS part:
> token CHEVRON_PATTERN : multiLine(start = "<", end = ">");
I don't understand what this solution is. Is it TCS or ANTLR syntax ?
where should I put it in my TCS part ? in the template ? or in a primitive
template ?
Remi Viaux
> Regards,
> Quentin GLINEUR
>> Thanks,
>> Remi Viaux
>>> Hi,
>>>> Hi Quentin,
>>>> to recognize "___" as stringSymbol.
>>> You are right !
>>>> to use " as a keyword like other symbols like '#' can already do.
>>> is to use 3 backslash (it is due to special escape character rendering.
>>> two class inheriting from this previous in order to define their
>>> respective textual form.
>>> KM3 :
>>> TCS :
>>> a token colliding with other could lead to.
>>> HTH,
>>> Quentin GLINEUR
>>>> Thanks,
>>>> Remi Viaux
>>>>> Hi Remi,
>>>>> does another way.
>>>>> string literals.
>>>>> literals:
>>>>> STRING
>>>>> ( 'n' {newline();}
>>>>> | ~('"'|'n')
>>>>> value = "%token%",
>>>>> Regards,
>>>>> Quentin Glineur
>>>>>> Hello Frederic,
>>>>>> want it to take the role of a simple character.
>>>>>> How can I do ?
>>>>>> {ei.set(ret,"machin",temp);} INVCOMA)
>>>>>> INVCOMA
>>>>>> Thanks,
>>>>>> Remi Viaux
Re: [TCS] Inverted Coma symbol [message #378534 is a reply to message #378532] |
Thu, 26 July 2007 11:36  |
--------------060305060200080400090505
Hi Remi,
Remi Viaux a
Re: [TCS] Inverted Coma symbol [message #602249 is a reply to message #378437] |
Fri, 06 July 2007 11:21  |
Are you sure your lexer does not already use " for another purpose
(e.g., as string delimiter)?
Frédéric Jouault
Remi Viaux wrote:
> template include :
> "#""include" "\""
> symbols {
> invcoma "\""
> Remi Viaux
Re: [TCS] Inverted Coma symbol [message #602259 is a reply to message #378442] |
Mon, 09 July 2007 04:34  |
Hello Frederic,
How can I do ?
INVCOMA)
INVCOMA
Remi Viaux
Re: [TCS] Inverted Coma symbol [message #602263 is a reply to message #378448] |
Hi Remi,
another way.
string literals.
STRING
| ~('\\"'|'\\n')
value = "%token%",
Quentin Glineur
> Hello Frederic,
> How can I do ?
> INVCOMA)
> INVCOMA
> Remi Viaux
Re: [TCS] Inverted Coma symbol [message #602309 is a reply to message #378451] |
Hi Quentin,
Remi Viaux
> Hi Remi,
> another way.
> string literals.
> STRING
> ( '\n' {newline();}
> | ~('\"'|'\n')
> value = "%token%",
> Regards,
> Quentin Glineur
>> Hello Frederic,
>> How can I do ?
>> INVCOMA)
>> INVCOMA
>> Thanks,
>> Remi Viaux
Re: [TCS] Inverted Coma symbol [message #602708 is a reply to message #378504] |
Wed, 18 July 2007 06:08  |
--------------000506030407020804090605
Remi Viaux a
Re: [TCS] Inverted Coma symbol [message #602748 is a reply to message #378513] |
Remi Viaux
>> Hi Quentin,
> You are right !
> textual form.
> KM3 :
> TCS :
> HTH,
> Quentin GLINEUR
>> Thanks,
>> Remi Viaux
>>> Hi Remi,
>>> another way.
>>> string literals.
>>> STRING
>>> ( 'n' {newline();}
>>> | ~('"'|'n')
>>> value = "%token%",
>>> Regards,
>>> Quentin Glineur
>>>> Hello Frederic,
>>>> How can I do ?
>>>> INVCOMA)
>>>> INVCOMA
>>>> Thanks,
>>>> Remi Viaux
Re: [TCS] Inverted Coma symbol [message #602754 is a reply to message #378524] |
Mon, 23 July 2007 09:31  |
--------------000208030900000207040602
Remi Viaux a
Re: [TCS] Inverted Coma symbol [message #602762 is a reply to message #378526] |
>> Hi,
template ?
Remi Viaux
> Regards,
> Quentin GLINEUR
>> Thanks,
>> Remi Viaux
>>> Hi,
>>>> Hi Quentin,
>>> You are right !
>>> KM3 :
>>> TCS :
>>> HTH,
>>> Quentin GLINEUR
>>>> Thanks,
>>>> Remi Viaux
>>>>> Hi Remi,
>>>>> does another way.
>>>>> string literals.
>>>>> literals:
>>>>> STRING
>>>>> ( 'n' {newline();}
>>>>> | ~('"'|'n')
>>>>> value = "%token%",
>>>>> Regards,
>>>>> Quentin Glineur
>>>>>> Hello Frederic,
>>>>>> How can I do ?
>>>>>> INVCOMA
>>>>>> Thanks,
>>>>>> Remi Viaux
Re: [TCS] Inverted Coma symbol [message #602768 is a reply to message #378528] |
Thu, 26 July 2007 03:58  |
--------------070308050301010806090300
Remi Viaux a
Re: [TCS] Inverted Coma symbol [message #602776 is a reply to message #378530] |
Thu, 26 July 2007 09:43  |
Hi Quentin,
I almost succeded !
The problem with the direct approach CHEVRON_REGEX was the "protected"
word.
So after remove it, it works proprely.
I have this for know :
_______________________________________________________
TCS
primitiveTemplate chevronExpression for string using CHEVRON_REGEX
value = "%token%";
Template StdIncludeExpression
"#""include"
file {as=chevronExpression}
Lexer
CHEVRON_REGEX
_________________________________________________________
There remain still some problems :
- I think there might be ambiguity problems with superior and inferior
symbols in other expression (ANTLR rise some warnings), but for now I
don't care.
- In the file token I recover all the CHEVRON expression i.e a string
with "<" at the beginning and ">" at the end.
Whereas I want just the string that is between the CHEVRON.
- The final problem is about the other template wich use STRING lexer.
But this lexer doesn't handle between ' and not between ". So I try to
modify it to recognize things like this "file.h". But for know I don't
succeded.
Do you have any solution to recover the string in chevronExpression,
without '<' '>' symbols ?
Remi Viaux
Re: [TCS] Inverted Coma symbol [message #602782 is a reply to message #378532] |
Hi Remi,
Remi Viaux a
Current Time: Sat Jul 26 10:14:15 EDT 2025
Powered by FUDForum. Page generated in 0.15702 seconds
