Home » Eclipse Projects » Mylyn » mediawiki templates and wikitext
mediawiki templates and wikitext [message #557803] Wed, 08 September 2010 22:40 Go to next message
I am using local mediawiki files and transform them to Eclipse help.
My question is if there is support to use mediawiki templates when files
are local in my workspace?
I am copying snippets from an existing wiki, and one template that is in
use there looks like this:
|style="font-weight:bold;font-family:monospace;{{{style}}}"|{{{1}}}
The template is called 'command' and is used like this on the wiki page:
{{Command|unzip}}
I do not want to include all those formatting instructions directly in
the mediawiki file, so hoping templates can be used, or that someone has
other suggestions. (There is probably a simple solution to the specific
template above such as '''<code>unzip</code>''' or something, but this
was just an example).
- henrik
Re: mediawiki templates and wikitext [message #558005 is a reply to message #557803] Thu, 09 September 2010 14:16 Go to previous messageGo to next message
Henrik,
WikiText provides API for providing a means to resolve templates. The
following may help you:
org.eclipse.mylyn.wikitext.mediawiki.core.TemplateResolver
org.eclipse.mylyn.wikitext.mediawiki.core.MediaWikiLanguage. setTemplateProviders(List <TemplateResolver>)
So far these have not been exposed in Ant tasks.
I had thought that a file-based template resolver would be useful, where
a folder could be specified in which files correspond to templates (in
your case, Command.mediawiki) however I didn't get around to
implementing it.
Feel free to contribute something in this area!
David
> {{Command|unzip}}
> Regards
> - henrik
Re: mediawiki templates and wikitext [message #558217 is a reply to message #558005] Fri, 10 September 2010 08:43 Go to previous message
Thanks David.
For now I went with the simpler solution of changing the content. Next
time it may not be as straight forward and I may end up implementing
local template support...
- henrik
On 9/9/10 8:16 PM, David Green wrote:
> Henrik,
> implementing it.
> David
>> {{Command|unzip}}
>> Regards
>> - henrik
Re: mediawiki templates and wikitext [message #602107 is a reply to message #557803] Thu, 09 September 2010 14:16 Go to previous message
Henrik,
implementing it.
David
> {{Command|unzip}}
> Regards
> - henrik
Re: mediawiki templates and wikitext [message #602122 is a reply to message #558005] Fri, 10 September 2010 08:43 Go to previous message
Thanks David.
- henrik
> Henrik,
> implementing it.
> David
>> {{Command|unzip}}
>> Regards
>> - henrik
Previous Topic:How to retrieve context-artifacts and change them
Next Topic:mediawiki to help - links questions
Current Time: Thu Jul 24 21:37:21 EDT 2025
Powered by FUDForum. Page generated in 0.25762 seconds
