Home » Archived » GMT (Generative Modeling Technologies) » [Epsilon] mddi adapter or stand-alone
[Epsilon] mddi adapter or stand-alone [message #378185] Fri, 15 June 2007 06:33 Go to next message
Originally posted by: hein..fokus.fraunhofer
I wonder if there is already an Epsilon adapter for the eclipse mddi
project or is there a tutorial how Epsilon can be used stand-alone?
Thanks in advance
Christian
Re: [Epsilon] mddi adapter or stand-alone [message #378188 is a reply to message #378185] Fri, 15 June 2007 08:16 Go to previous messageGo to next message
Hi Christian,
Christian Hein wrote:
> project
Unfortunately there is no MDDI adapter yet for Epsilon (but any
contribution towards this would be more than welcome :)).
In
http://dev.eclipse.org/viewcvs/indextech.cgi/org.eclipse.gmt /epsilon/org.epsilon.eclipse.help/index.html
there is an example of "Using ETL from Java" for transforming EMF models
in a standalone manner but the code it contains is a bit outdated. I'll
update it and get back to you asap.
Can I ask which language you are particularly interested in so that I
can also write a similar example for it?
> Thanks in advance
> Christian
Dimitrios
Re: [Epsilon] mddi adapter or stand-alone [message #378189 is a reply to message #378188] Fri, 15 June 2007 09:03 Go to previous messageGo to next message
Hi Christian,
I've now updated the "Using ETL from Java" example to work with the
latest version of the code on the CVS
( http://dev.eclipse.org/viewcvs/indextech.cgi/org.eclipse.gmt /epsilon/org.epsilon.eclipse.help/etl/developer/usingetlfrom java.html)
BTW, instructions for obtaining the source code of Epsilon from the CVS
are available at http://www.eclipse.org/gmt/epsilon/doc/EpsilonCVS.pdf
Dimitrios
Dimitrios Kolovos wrote:
> Hi Christian,
>> Hi,
>> project
> In
>> Thanks in advance
>> Christian
> Cheers,
> Dimitrios
Re: [Epsilon] mddi adapter or stand-alone [message #378261 is a reply to message #378188] Mon, 18 June 2007 04:49 Go to previous messageGo to next message
Hi Dimitrios,
> In
Thanks for your help, I'm interested mainly in ETL and EML. BTW Is there
an overview (paper, article) about the languages features that ETL
provides and which not? (comparision with ATL,QVT ...?)
Christian
Re: [Epsilon] mddi adapter or stand-alone [message #378262 is a reply to message #378261] Mon, 18 June 2007 05:31 Go to previous message
Hi Christian,
Documentation on the syntax of ETL can be found in
http://dev.eclipse.org/viewcvs/indextech.cgi/org.eclipse.gmt /epsilon/org.epsilon.eclipse.help/index.html.
Also it'd probably be worth playing with the basic language of Epsilon
(EOL) first as all the languages of the platform (such as ETL and EML)
inherit its syntax and capabilities.
Unfortunately, we don't have a document containing a comprehensive
comparison between ETL and other transformation languages yet (mainly
due to lack of time to do that :) ). However, there is an older post in
the newsgroup that you may find useful:
news://news.eclipse.org:119/f05059$t45$1@build.eclipse.org
(Needlessly to say, should you choose to use ETL in parallel with some
other transformation language it would be really interesting to hear
back on your experiences)
> Cheers,
> Christian
Dimitrios
Re: [Epsilon] mddi adapter or stand-alone [message #601915 is a reply to message #378185] Fri, 15 June 2007 08:16 Go to previous message
Hi Christian,
> project
In
> Thanks in advance
> Christian
Dimitrios
Re: [Epsilon] mddi adapter or stand-alone [message #601923 is a reply to message #378188] Fri, 15 June 2007 09:03 Go to previous message
Hi Christian,
Dimitrios
> Hi Christian,
>> Hi,
>> project
> In
>> Thanks in advance
>> Christian
> Cheers,
> Dimitrios
Re: [Epsilon] mddi adapter or stand-alone [message #602030 is a reply to message #378188] Mon, 18 June 2007 04:49 Go to previous message
Hi Dimitrios,
> In
Christian
Re: [Epsilon] mddi adapter or stand-alone [message #602037 is a reply to message #378261] Mon, 18 June 2007 05:31 Go to previous message
Hi Christian,
> Cheers,
> Christian
Dimitrios
Previous Topic:can somebody give me version numbers of their working MOFScipt Plugin config?
Next Topic:[TCS] TGE: Support for own languages
Current Time: Thu Jul 24 14:14:59 EDT 2025
Powered by FUDForum. Page generated in 0.05703 seconds
