Home » Eclipse Projects » Mylyn » Can not create TaskList view in Eclipse 3.6 using Mylyn 3.4.0(TaskList view exception)
Can not create TaskList view in Eclipse 3.6 using Mylyn 3.4.0 [message #554860] |
Tue, 24 August 2010 10:48  |
I have just installed the current version of Mylyn from
http://download.eclipse.org/tools/mylyn/update/e3.4/
My version of Eclipse is Version: 3.6.0 , Build id: I20100129-1300
I get the following MethodNotFoundException when the Task list view loads up:
Could not create the view: org.eclipse.mylyn.internal.tasks.ui.views.TaskListFilteredTr ee.getTextSearchControl()Lorg/eclipse/mylyn/internal/provisi onal/commons/ui/TextSearchControl;
java.lang.NoSuchMethodError: org.eclipse.mylyn.internal.tasks.ui.views.TaskListFilteredTr ee.getTextSearchControl()Lorg/eclipse/mylyn/internal/provisi onal/commons/ui/TextSearchControl;
at org.eclipse.mylyn.internal.tasks.ui.views.TaskListView.resto reState(TaskListView.java:680)
at org.eclipse.mylyn.internal.tasks.ui.views.TaskListView.creat ePartControl(TaskListView.java:931)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:367)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:226)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.WorkbenchPage$ActivationList.setActi ve(WorkbenchPage.java:4218)
at org.eclipse.ui.internal.WorkbenchPage$18.runWithException(Wo rkbenchPage.java:3277)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3501)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3148)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$28.runWithException(Workbe nch.java:1384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2315)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 20)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:367)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 611)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:566)
at org.eclipse.equinox.launcher.Main.run(Main.java:1363)
Any clues?
Joel
[Updated on: Tue, 24 August 2010 10:50] by Moderator
Re: Error loading Task view Eclipse 3.6, Mylyn [message #554963 is a reply to message #554864] |
Tue, 24 August 2010 19:01   |
Hi Steffen,
As requested, thanks.
*** Date: Tuesday, 24 August 2010 23:55:36 British Summer Time
*** Platform Details:
*** System properties:
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=I20100129-1300
eclipse.commands=-os
linux
-ws
gtk
-arch
x86
-showsplash
/opt/eclipse/eclipse-SDK-3.6M5/eclipse//plugins/org.eclipse. platform_3.6.0.v201001291300/splash.bmp
-launcher
/opt/eclipse/eclipse-SDK-3.6M5/eclipse/eclipse
-name
Eclipse
--launcher.library
/opt/eclipse/eclipse-SDK-3.6M5/eclipse//plugins/org.eclipse. equinox.launcher.gtk.linux.x86_1.1.0.v20100108/eclipse_1305. so
-startup
/opt/eclipse/eclipse-SDK-3.6M5/eclipse//plugins/org.eclipse. equinox.launcher_1.1.0.v20100118.jar
-vm
/opt/jdk1.6.0_18/bin/../jre/lib/i386/client/libjvm.so
eclipse.home.location=file:/opt/eclipse/eclipse-SDK-3.6M5/ec lipse/
eclipse.launcher=/opt/eclipse/eclipse-SDK-3.6M5/eclipse/ecli pse
eclipse.launcher.name=Eclipse
eclipse.p2.data.area=@config.dir/../p2/
eclipse.p2.profile=SDKProfile
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1282660899181
eclipse.vm=/opt/jdk1.6.0_18/bin/../jre/lib/i386/client/libjv m.so
eclipse.vmargs=-Djava.library.path=/usr/lib/jni
-Xms40m
-Xmx1024m
-javaagent:/opt/eclipse/eclipse-SDK-3.6M5/eclipse/lombok.jar
-Xbootclasspath/a:/opt/eclipse/eclipse-SDK-3.6M5/eclipse/lom bok.jar
-XX:MaxPermSize=750m
-Djava.class.path=/opt/eclipse/eclipse-SDK-3.6M5/eclipse//pl ugins/org.eclipse.equinox.launcher_1.1.0.v20100118.jar
equinox.use.ds=true
file.encoding=UTF-8
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/opt/eclipse/eclipse-SDK-3.6M5/eclipse//plug ins/org.eclipse.equinox.launcher_1.1.0.v20100118.jar:/opt/ec lipse/eclipse-SDK-3.6M5/eclipse/lombok.jar
java.class.version=50.0
java.endorsed.dirs=/opt/jdk1.6.0_18/jre/lib/endorsed
java.ext.dirs=/opt/jdk1.6.0_18/jre/lib/ext:/usr/java/package s/lib/ext
java.home=/opt/jdk1.6.0_18/jre
java.io.tmpdir=/tmp
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_18-b07
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_18
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=16.0-b13
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.NoOpLog
org.eclipse.equinox.launcher.splash.location=/opt/eclipse/ec lipse-SDK-3.6M5/eclipse//plugins/org.eclipse.platform_3.6.0. v201001291300/splash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.ec lipse.equinox.simpleconfigurator/bundles.info
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,OSGi/Minimum-1.2,JRE-1.1,J2SE-1.2,J2SE-1.3,J2S E-1.4,J2SE-1.5,JavaSE-1.6
org.osgi.framework.language=en
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=2.6.32
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.kerberos,javax.security.auth.lo gin,javax.security.auth.spi,javax.security.auth.x500,javax.s ecurity.cert,javax.security.sasl,javax.sound.midi,javax.soun d.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax .sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rows et.spi,javax.swing,javax.swing.border,javax.swing.colorchoos er,javax.swing.event,javax.swing.filechooser,javax.swing.pla f,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing. plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.sw ing.text,javax.swing.text.html,javax.swing.text.html.parser, javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax .tools,javax.transaction,javax.transaction.xa,javax.xml,java x.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotati on.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers ,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,j avax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.cry pto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.dataty pe,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,java x.xml.stream,javax.xml.stream.events,javax.xml.stream.util,j avax.xml.transform,javax.xml.transform.dom,javax.xml.transfo rm.sax,javax.xml.transform.stax,javax.xml.transform.stream,j avax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax. xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,java x.xml.ws.spi,javax.xml.ws.wsaddressing,javax.xml.xpath,org.i etf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.p ortable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage ,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.om g.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.om g.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.Dyn amicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.Dyna micAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPac kage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.Port ableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPacka ge,org.omg.PortableServer,org.omg.PortableServer.CurrentPack age,org.omg.PortableServer.POAManagerPackage,org.omg.Portabl eServer.POAPackage,org.omg.PortableServer.portable,org.omg.P ortableServer.ServantLocatorPackage,org.omg.SendingContext,o rg.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w 3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.l s,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.tra versal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.x ml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.5.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=i386
os.name=Linux
os.version=2.6.32-22-generic
osgi.arch=x86
osgi.bundles=reference:file: org.eclipse.equinox.simpleconfigurator_1.0.200.v20100123-101 9.jar @1:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=/home/joel/.eclipse/org.eclipse.platform_3. 5.0_1022604495/configuration/org.eclipse.osgi/bundles
osgi.configuration.area=file:/home/joel/.eclipse/org.eclipse .platform_3.5.0_1022604495/configuration/
osgi.framework=file:/opt/eclipse/eclipse-SDK-3.6M5/eclipse/p lugins/org.eclipse.osgi_3.6.0.v20100128-1430.jar
osgi.framework.extensions=
osgi.framework.shape=jar
osgi.framework.version=3.6.0.v20100128-1430
osgi.install.area=file:/opt/eclipse/eclipse-SDK-3.6M5/eclips e/
osgi.instance.area=file:/mnt/data/data/dev/workspace/
osgi.instance.area.default=file:/home/joel/workspace/
osgi.logfile=/mnt/data/data/dev/workspace/.metadata/.log
osgi.manifest.cache=/home/joel/.eclipse/org.eclipse.platform _3.5.0_1022604495/configuration/org.eclipse.osgi/manifests
osgi.nl=en_GB
osgi.os=linux
osgi.sharedConfiguration.area=file:/opt/eclipse/eclipse-SDK- 3.6M5/eclipse/configuration/
osgi.splashLocation=/opt/eclipse/eclipse-SDK-3.6M5/eclipse// plugins/org.eclipse.platform_3.6.0.v201001291300/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/opt/eclipse/eclipse-SDK-3.6M5/eclipse/plugins
osgi.tracefile=/mnt/data/data/dev/workspace/.metadata/trace. log
osgi.ws=gtk
path.separator=:
sun.arch.data.model=32
sun.boot.class.path=/opt/jdk1.6.0_18/jre/lib/resources.jar:/ opt/jdk1.6.0_18/jre/lib/rt.jar:/opt/jdk1.6.0_18/jre/lib/sunr sasign.jar:/opt/jdk1.6.0_18/jre/lib/jsse.jar:/opt/jdk1.6.0_1 8/jre/lib/jce.jar:/opt/jdk1.6.0_18/jre/lib/charsets.jar:/opt /jdk1.6.0_18/jre/classes:/opt/eclipse/eclipse-SDK-3.6M5/ecli pse/lombok.jar
sun.boot.library.path=/opt/jdk1.6.0_18/jre/lib/i386
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=gnome
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=UTF-8
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=unknown
user.country=GB
user.dir=/home/joel
user.home=/home/joel
user.language=en
user.name=joel
user.timezone=Europe/London
*** Features:
com.collabnet.subversion.merge.feature (2.0.1) "CollabNet Subversion Merge Client"
org.eclipse.cvs (1.2.0.v20090814-7B77FEc8sF79P8FDY5CK8D) "Eclipse CVS Client"
org.eclipse.datatools.connectivity.feature (1.8.0.v201005280400-7C7b8cEt1ZvsifWcrT8a-F-sz05R) "Data Tools Platform Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.core.feature (1.8.0.v201005280400-7B7C77CcNBGKBaIdEbPQ) "DTP ODA Designer UI Framework Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature (1.8.0.v201005280400-4107w3121151A1A53) "DTP ODA Designer UI Framework Plug-in"
org.eclipse.datatools.connectivity.oda.feature (1.8.0.v201005280400-7H7C6CcNBHBBZKjEXLf) "DTP Open Data Access"
org.eclipse.datatools.doc.user (1.8.0.v201005280400-47C08w95ENAK6AFDFK7) "Data Tool Platform User Documentation"
org.eclipse.datatools.enablement.apache.derby.feature (1.8.0.v201005280400-77778cBmKDNOMeKqJ5Sh7QBR) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.feature (1.8.0.v201005280400-7J8x0BWwUK6x2yoco_A-q71HMuLt) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature (1.8.0.v201005280400-67C0AqGBJVKbHlH1GU7QBR) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.ibm.feature (1.8.0.v201005280400-7F47SFC7sRbrSZope9vW) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.ingres.feature (1.8.0.v201005280400-540AkF77g7VBLBPH7) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.jdbc.feature (1.8.0.v201005280400-4-29oB56N5N7L6PAQ) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.jdt.feature (1.8.0.v201005280400-2-07w31211518181A) "Data Tools Platform Connectivity JDT Extension Plug-in"
org.eclipse.datatools.enablement.msft.feature (1.8.0.v201005280400-542AkF79P7QCP9SDB) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.mysql.feature (1.8.0.v201005280400-546AkF78Y7R9PAX77) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.oda.designer.feature (1.8.0.v201005280400-3328s73533D7B5993) "Eclipse Data Tools Platform XML ODA Designer"
org.eclipse.datatools.enablement.oda.feature (1.8.0.v201005280400-7A7T78DZRDKDDdFyFiKD) "Eclipse Data Tools Platform XML ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature (1.8.0.v201005280400-548cAkF79P7UBMATEE) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.postgresql.feature (1.8.0.v201005280400-542AkF77g7V9N9e77) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sap.feature (1.8.0.v201005280400-540AkF77g7V9N9e77) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sqlite.feature (1.8.0.v201005280400-541AkF79P7N8NAQ77) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sybase.feature (1.8.0.v201005280400-7E45F9NiNWvOOXxPdVT) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.modelbase.feature (1.8.0.v201005280400-77077CcNBGKBWJ_HWVi) "Eclipse Data Tools Platform SQLModel Plug-in"
org.eclipse.datatools.sqldevtools.ddlgen.feature (1.8.0.v201005280400-7A-2F7RZHLz-HvNlPz-Uk) "Eclipse Data Tools Platform FE UI Plug-in"
org.eclipse.datatools.sqldevtools.feature (1.8.0.v201005280400-7N7y3FDrhnWFIFUNhnCz0dmdZNwS) "Eclipse Data Tools Platform SQL Tools Common UI Plug-in"
org.eclipse.datatools.sqldevtools.parsers.feature (1.8.0.v201005280400-622BgJ9CR9XFcEWLP) "Eclipse Data Tools Platform SQL Parser Plugin"
org.eclipse.draw2d (3.6.0.v20100519-2050-45-7w3121163602336) "Graphical Editing Framework Draw2d"
org.eclipse.emf (2.6.0.v20100607-0756) "EMF - Eclipse Modeling Framework Runtime and Tools"
org.eclipse.emf.codegen (2.6.0.v20100607-0756) "EMF Code Generation"
org.eclipse.emf.codegen.ecore (2.6.0.v20100607-0756) "EMF Ecore Code Generator"
org.eclipse.emf.codegen.ecore.ui (2.6.0.v20100607-0756) "EMF Ecore Code Generator UI"
org.eclipse.emf.codegen.ui (2.6.0.v20100607-0756) "EMF Code Generation UI"
org.eclipse.emf.common (2.6.0.v20100607-0756) "EMF Common"
org.eclipse.emf.common.ui (2.6.0.v20100607-0756) "EMF Common UI"
org.eclipse.emf.converter (2.6.0.v20100607-0756) "EMF Model Converter"
org.eclipse.emf.databinding (1.2.0.v20100607-0756) "EMF Data Binding"
org.eclipse.emf.databinding.edit (1.2.0.v20100607-0756) "EMF Edit Data Binding"
org.eclipse.emf.ecore (2.6.0.v20100607-0756) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.6.0.v20100607-0756) "EMF Ecore Edit"
org.eclipse.emf.ecore.editor (2.6.0.v20100607-0756) "EMF Sample Ecore Editor"
org.eclipse.emf.edit (2.6.0.v20100607-0756) "EMF Edit"
org.eclipse.emf.edit.ui (2.6.0.v20100607-0756) "EMF Edit UI"
org.eclipse.emf.mapping (2.6.0.v20100607-0756) "EMF Mapping"
org.eclipse.emf.mapping.ecore (2.6.0.v20100607-0756) "EMF Ecore Mapping"
org.eclipse.emf.mapping.ecore.editor (2.6.0.v20100607-0756) "EMF Ecore Mapping Editor"
org.eclipse.emf.mapping.ui (2.6.0.v20100607-0756) "EMF Mapping UI"
org.eclipse.gef (3.6.0.v20100519-2050-777B-81A2Bz-69793A8B83447) "Graphical Editing Framework GEF"
org.eclipse.help (1.2.0.v20090729-7e7jCWFEx2Xd7ZRvSUw9w9) "Help System Base"
org.eclipse.jdt (3.6.0.v20100124-2000-7z8WFRAFMTdeCo0y7FJt1Zi45027) "Eclipse Java Development Tools"
org.eclipse.jpt.eclipselink.feature (2.3.0.v201005260000-7778BgBgJ9E99RIX999A) "Dali Java Persistence Tools - EclipseLink Support"
org.eclipse.jpt.feature (2.3.0.v201005260000-7N7UEwFD3wTgbU_dxVnWV) "Dali Java Persistence Tools"
org.eclipse.jst.common.fproj.enablement.jdt (3.2.0.v201005241600-377A78s73533C6A6B39) "Eclipse Faceted Project Framework JDT Enablement"
org.eclipse.jst.enterprise_ui.feature (3.2.0.v201005241530-7b7GHTYFSK2W9kPaFClvz0O_NQmN) "Eclipse Java EE Developer Tools"
org.eclipse.jst.ws.axis2tools.feature (1.1.100.v201005241530-78-FF0DZRDKDDePSKwHj) "Axis2 Tools"
org.eclipse.jst.ws.cxf.feature (1.0.0.v201005241530-7H777BFAKlOiOX8lGdLp-67BD) "CXF Web Services Core"
org.eclipse.jst.ws.jaxws.feature (1.0.0.v201005241530-7E777BF8NcJSSJxUETx_l) "JAX-WS Tools Core"
org.eclipse.pde (3.6.0.v20090930-7b7kFD4FEx2XgdbEz-p9LZCG) "PDE"
org.eclipse.platform (3.6.0.v20100121-9hF71GITFufnsj44XsigdRiv20ClbUb3ou) "Eclipse Platform"
org.eclipse.rcp (3.6.0.v20091106-9KAiFD4Fs-UyZKdfDWGdrej) "Eclipse RCP"
org.eclipse.sdk (3.6.0.v20100125-7Q7m-DPZ2Yfx5pLps68lIy-7ym3O5o5FWg9xhf2Ry4o Vi) "Eclipse Project SDK"
org.eclipse.tptp.platform.core (4.7.0.v201005032111-8X8ZFXNFLWUl6kmjuaADv7) "TPTP Platform"
org.eclipse.tptp.platform.core.doc.user (4.4.0.v201005032111-795-8s73533E4D5C7C) "TPTP Platform Project Documentation"
org.eclipse.tptp.platform.doc.user (4.4.0.v201005032111-7977-7FE7A5yB897CK9JCJJD) "TPTP Platform Project Documentation"
org.eclipse.tptp.platform.instrumentation.ui (4.3.0.v201005032111-7979-8s7353394E5I33) "TPTP Instrumentation UI Core"
org.eclipse.tptp.platform.integration.pde (4.5.0.v201005032111-54-7w312116172711) "TPTP Platform Integration PDE"
org.eclipse.tptp.platform.jvmti (4.5.0.v201005032111-797A-8s73533E4E6E33) "TPTP JVMTI Profiler Client"
org.eclipse.tptp.platform.probekit (4.5.0.v201005032111-7H7BF8NAkF7B77SBNCPEI) "TPTP ProbeKit"
org.eclipse.tptp.platform.probekit.doc.user (4.4.0.v201005032111-52-7w312116323449) "Probekit User Documentation"
org.eclipse.tptp.platform.profile.server (4.5.0.v201005032111-7H7F-AkF7B77R7VBV77) "TPTP Profile on Server"
org.eclipse.tptp.platform.report (4.4.0.v201005032111-7D7A-9oB5855K5N8N55) "TPTP Charting Service"
org.eclipse.tptp.platform.samples (4.5.0.v201005032111-7D7A-9oB5855K5N8N55) "TPTP Platform Samples"
org.eclipse.tptp.platform.trace (4.5.0.v201005032111-7L7O8ZBgJ9E99ZC_El99) "TPTP Platform Trace"
org.eclipse.tptp.trace (4.3.0.v201005032111-794F9w8s73533E3B5I33) "TPTP Trace"
org.eclipse.tptp.trace.arm (4.3.0.v201005032111-793-8s73533E3H5F5C) "TPTP ARM Monitoring "
org.eclipse.tptp.trace.arm.ui (4.4.0.v201005032111-7977-8s73533D3F5F33) "Instrument ARM UI"
org.eclipse.tptp.trace.jvmti (4.3.0.v201005032111-54-7w312117132A11) "TPTP Trace JVMTI Client"
org.eclipse.wst.common.fproj (3.2.0.v201005290030-377A78s73533D5L355B) "Eclipse Faceted Project Framework"
org.eclipse.wst.jsdt.feature (1.2.0.v201005270528-7C78FGDF9JgLWLMBWz-Ose6) "Eclipse JavaScript Development Tools"
org.eclipse.wst.web_ui.feature (3.2.0.v201005241510-7O7CFb3EMf84nP-FHuc10NTz--M3) "Eclipse Web Developer Tools"
org.eclipse.wst.xml_ui.feature (3.2.0.v201005241510-7H7AFUIDxumQGOb7ocjUR2Pvz-28) "Eclipse XML Editors and Tools"
org.eclipse.wst.xml.xpath2.processor.feature (1.1.3.v201005241600-67K0BgJ9DIATEXATHP) "Eclipse XPath 2 Developers Tools"
org.eclipse.wst.xsl.feature (1.1.0.v201005241600-7S7WFAKFIpS---NRIS1pbfYBUIQ) "Eclipse XSL Developer Tools"
org.tigris.subversion.clientadapter.feature (1.6.7) "Subversion Client Adapter"
org.tigris.subversion.clientadapter.javahl.feature (1.6.9.1) "Subversion JavaHL"
org.tigris.subversion.clientadapter.svnkit.feature (1.6.7) "SVNKit Client Adapter"
org.tigris.subversion.subclipse (1.6.7) "SVN Team Provider Core"
org.tigris.subversion.subclipse.graph.feature (1.0.7) "Subversion Revision Graph"
org.tigris.subversion.subclipse.mylyn (3.0.0) "Subclipse Integration for Mylyn 3.x"
*** Plug-in Registry:
ch.qos.logback.classic (0.9.19.v20100519-1505) "Logback Classic Module" [Resolved]
ch.qos.logback.core (0.9.19.v20100419-1216) "Logback Core Module" [Resolved]
ch.qos.logback.slf4j (0.9.19.v20100519-1910) "Logback Native SLF4J Logger Module" [Resolved]
com.collabnet.subversion.merge (2.0.1) "CollabNet Subversion Merge Client" [Starting]
com.ibm.icu (4.2.1.v20100112) "International Components for Unicode for Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.41.v200903070017) "JSch" [Resolved]
com.sun.jna (3.2.3) "JNA Library Plug-in" [Starting]
java_cup.runtime (0.10.0.v201005080400) "Java Cup" [Resolved]
javax.activation (1.1.0.v201005080500) "Apache Geronimo Activation Plug-in" [Resolved]
javax.jws (2.0.0.v201005080400) "Web Services Metadata" [Resolved]
javax.mail (1.4.0.v201005080615) "Javax Mail Plug-in" [Resolved]
javax.servlet (2.5.0.v200910301333) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200806031607) "Java Server Pages API Bundle" [Resolved]
javax.wsdl (1.5.1.v201005080630) "WSDL4J" [Resolved]
javax.wsdl (1.6.2.v201005080631) "WSDL4J" [Resolved]
javax.xml (1.3.4.v201005080400) "JAXP XML" [Resolved]
javax.xml.bind (2.1.9.v201005080401) "XML Binding for Java" [Resolved]
javax.xml.rpc (1.1.0.v201005080400) "JAX-RPC" [Resolved]
javax.xml.soap (1.2.0.v201005080501) "SAAJ" [Resolved]
javax.xml.stream (1.0.1.v201004272200) "Java XML Streaming API" [Resolved]
javax.xml.ws (2.1.0.v200902101523) "Java API for XML Web Services (JAX-WS)" [Resolved]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v201004271650) "SourceForge LPG" [Resolved]
org.apache.ant (1.7.1.v20090120-1145) "Apache Ant" [Resolved]
org.apache.axis (1.4.0.v201005080400) "Apache Web Services" [Resolved]
org.apache.batik.bridge (1.6.0.v200912221622) "Apache Batik Bridge/GVT/Scripting" [Resolved]
org.apache.batik.css (1.6.0.v200912221622) "Apache Batik CSS" [Resolved]
org.apache.batik.dom (1.6.0.v200912221622) "Apache Batik DOM" [Resolved]
org.apache.batik.dom.svg (1.6.0.v200805290154) "Apache Batik SVG DOM" [Resolved]
org.apache.batik.ext.awt (1.6.0.v200805290154) "Apache Batik AWT Utilities" [Resolved]
org.apache.batik.extension (1.6.0.v200805290154) "Apache Batik Extension" [Resolved]
org.apache.batik.parser (1.6.0.v200805290154) "Apache Batik Parser" [Resolved]
org.apache.batik.pdf (1.6.0.v200806031500) "Apache Batik PDF" [Resolved]
org.apache.batik.svggen (1.6.0.v200805290154) "Apache Batik SVG Generation" [Resolved]
org.apache.batik.swing (1.6.0.v200805290154) "Apache Batik Swing" [Resolved]
org.apache.batik.transcoder (1.6.0.v200805290154) "Apache Batik Transcoder" [Resolved]
org.apache.batik.util (1.6.0.v200805290154) "Apache Batik Utilities" [Resolved]
org.apache.batik.util.gui (1.6.0.v200805290154) "Apache Batik GUI Utilities" [Resolved]
org.apache.batik.xml (1.6.0.v200805290154) "Apache Batik XML" [Resolved]
org.apache.bcel (5.2.0.v201005080400) "Apache BCEL" [Resolved]
org.apache.commons.codec (1.3.0.v20100106-1700) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.codec (1.3.0.v20100518-1140) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.collections (3.2.0.v201005080500) "Apache Commons Collections" [Resolved]
org.apache.commons.discovery (0.2.0.v201004190315) "Jakarta-Commons Discovery" [Resolved]
org.apache.commons.el (1.0.0.v200806031608) "Apache Commons JSP 2.0 Expression Language Interpreter" [Resolved]
org.apache.commons.httpclient (3.1.0.v20080605-1935) "Apache Commons Httpclient" [Resolved]
org.apache.commons.lang (2.1.0.v201005080500) "Apache Jakarta Commons Lang" [Resolved]
org.apache.commons.lang (2.3.0.v201005080501) "Apache Jakarta Commons Lang" [Resolved]
org.apache.commons.logging (1.0.4.v200904062259) "Apache Commons Logging Plug-in" [Resolved]
org.apache.commons.logging (1.0.4.v201005080501) "Apache Commons Logging Plug-in" [Resolved]
org.apache.jasper (5.5.17.v200903231320) "Apache Jasper 2 Plug-in" [Resolved]
org.apache.log4j (1.2.15.v201005080500) "Apache Jakarta log4j Plug-in" [Resolved]
org.apache.lucene (1.9.1.v20080530-1600) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v20080530-1600) "Apache Lucene Analysis" [Resolved]
org.apache.oro (2.0.8.v201005080400) "Apache Jakarta ORO" [Resolved]
org.apache.velocity (1.5.0.v200905192330) "Apache Velocity Plug-in" [Resolved]
org.apache.wsil4j (1.0.0.v200901211807) "WSIL4J" [Resolved]
org.apache.xalan (2.7.1.v201005080400) "Xalan-Java" [Resolved]
org.apache.xerces (2.9.0.v201005080400) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.2.0.v201005080400) "Apache XmlResolver" [Resolved]
org.apache.xml.serializer (2.7.1.v201005080400) "Apache XML Commons Serializer" [Resolved]
org.eclipse.ant.core (3.2.200.v20091118) "Ant Build Tool Core" [Starting]
org.eclipse.ant.launching (1.0.0.v20091204) "Ant Launching Support" [Starting]
org.eclipse.ant.ui (3.5.0.v20091130) "Ant UI" [Starting]
org.eclipse.birt.chart.device.extension (2.6.0.v20100310) "BIRT Chart Device Extension(s)" [Starting]
org.eclipse.birt.chart.device.swt (2.6.0.v20100304) "BIRT Chart Device SWT Extension" [Starting]
org.eclipse.birt.chart.engine (2.6.0.v20100311) "BIRT Chart Engine" [Starting]
org.eclipse.birt.chart.engine.extension (2.6.0.v20100304) "BIRT Chart Engine Extension" [Starting]
org.eclipse.birt.core (2.6.0.v20100315) "BIRT Core Package" [Starting]
org.eclipse.compare (3.5.100.I20100126-0755) "Compare Support" [Starting]
org.eclipse.compare.core (3.5.100.I20090714-0800) "Core Compare Support" [Active]
org.eclipse.core.boot (3.1.100.v20080218) "Core Boot" [Starting]
org.eclipse.core.commands (3.6.0.I20100122-0800) "Commands" [Resolved]
org.eclipse.core.contenttype (3.4.100.v20091109) "Eclipse Content Mechanism" [Active]
org.eclipse.core.databinding (1.3.0.I20100125-1345) "JFace Data Binding" [Starting]
org.eclipse.core.databinding.beans (1.2.0.I20091117-0800) "JFace Data Binding for JavaBeans" [Resolved]
org.eclipse.core.databinding.observable (1.3.0.I20090901-0800) "JFace Data Binding Observables" [Active]
org.eclipse.core.databinding.property (1.2.100.I20100119-0800) "JFace Data Binding" [Starting]
org.eclipse.core.databinding.property (1.3.0.I20100601-0800) "JFace Data Binding" [Starting]
org.eclipse.core.expressions (3.4.100.v20091203) "Expression Language" [Active]
org.eclipse.core.externaltools (1.0.0.v20091204) "External Tools Headless Support" [Starting]
org.eclipse.core.filebuffers (3.5.100.v20100124-2000) "File Buffers" [Active]
org.eclipse.core.filesystem (1.3.0.v20100121) "Core File Systems" [Active]
org.eclipse.core.filesystem.linux.x86 (1.3.0.v20100121) "Core File System for Linux" [Resolved]
org.eclipse.core.jobs (3.5.0.v20091221) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.2.100.I20091117-0800) "Internet Connection Management" [Active]
org.eclipse.core.net.linux.x86 (1.1.0.I20081021) "Proxy for Linux" [Resolved]
org.eclipse.core.resources (3.6.0.v20100128-1345) "Core Resource Management" [Active]
org.eclipse.core.runtime (3.6.0.v20091204) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.0.v20090413) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20090413) "Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.3.0.v20091116) "Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.300.v20090911) "Core Variables" [Active]
org.eclipse.cvs (1.0.300.v201001291300) "Eclipse CVS Client" [Starting]
org.eclipse.datatools.connectivity (1.2.0.v201005270426) "Data Tools Platform Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby (1.0.100.v200906020900) "Eclipse Data Tools Platform Derby Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby.dbdefinition (1.0.2.v200906161815) "Eclipse Data Tools Platform Apache Derby Database Definition" [Starting]
org.eclipse.datatools.connectivity.apache.derby.ui (1.0.2.v201005130645) "Eclipse Data Tools Platform Apache Derby UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.console.profile (1.0.0.v200906020553) "DTP Connection Profiles Storage File Editor Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic (1.0.1.v200908130547) "Eclipse Data Tools Platform Generic DB Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic.ui (1.0.1.v201004070709) "Eclipse Data Tools Platform Generic DB UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC (1.0.1.v200906161815) "Eclipse Data Tools Platform DBDefinition Generic JDBC Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda (3.3.0.v201004270801) "DTP Open Data Access" [Starting]
org.eclipse.datatools.connectivity.oda.consumer (3.2.3.v201005281018) "DTP ODA Consumer Helper Component Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.design (3.3.0.v201004020648) "DTP ODA Design Session Model" [Starting]
org.eclipse.datatools.connectivity.oda.design.ui (3.2.3.v201005120503) "DTP ODA Designer UI Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile (3.1.1.v201001131420) "Eclipse Data Tools Platform Flat File ODA Runtime Driver" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.1.1.v201001131420) "Eclipse Data Tools Platform Flat File ODA Designer" [Starting]
org.eclipse.datatools.connectivity.oda.profile (3.2.3.v201005281018) "DTP ODA Connection Profile Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.template.ui (3.2.1.v201004090942) "DTP ODA New Plug-in Template Wizard" [Starting]
org.eclipse.datatools.connectivity.sqm.core (1.2.0.v201005270630) "Eclipse Data Tools Platform SQM Core Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.core.ui (1.2.0.v201002281800) "Eclipse Data Tools Platform SQM UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.server.ui (1.1.100.v200910270503) "Eclipse Data Tools Platform Server UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui (1.2.0.v201005182319) "Data Tools Platform Connectivity UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.dse (1.1.4.v201004270430) "Eclipse Data Tools Platform Data Source Explorer Plug-in" [Starting]
org.eclipse.datatools.doc.user (1.7.0.20090521092446) "Data Tool Platform User Documentation" [Starting]
org.eclipse.datatools.enablement.finfo (1.5.1.v200906161800) "Eclipse Data Tools Platform Enablement" [Starting]
org.eclipse.datatools.enablement.hsqldb (1.0.0.v200906020900) "Eclipse Data Tools Platform HSQLDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform HSQLDB Database Definition Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform HSQLDB UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries (1.0.2.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinitio n (1.0.3.v200906161800) "DB2 UDB iSeries Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.ui (1.0.1.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB UI iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw (1.0.2.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB LUW Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition (1.0.4.v201005211215) "Eclipse Data Tools Platform DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.ui (1.0.2.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB LUW UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries (1.0.2.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB zSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinitio n (1.0.4.v201005211230) "DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.ui (1.0.1.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB zSeries UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix (1.0.1.v201005211230) "Eclipse Data Tools Platform Informix Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.dbdefinition (1.0.4.v201005211230) "Eclipse Data Tools Platform Informix Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.ui (1.0.2.v201005211230) "Eclipse Data Tools Platform Informix UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform IBM UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres (1.0.0.v200906111150) "Ingres DTP Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres.dbdefinition (1.0.0.v200906161800) "Ingres DTP Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres.ui (1.0.0.v200906111150) "Ingres DTP UI Plug-in" [Starting]
org.eclipse.datatools.enablement.jdt.classpath (1.0.1.v201004070709) "Data Tools Platform Connectivity JDT Extension Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver (1.0.1.v201001180222) "Eclipse Data Tools Platform Microsoft SQL Server Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition (1.0.0.v201004211630) "Eclipse Data Tools Platform SQL Server Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.ui (1.0.1.v200908130512) "Eclipse Data Tools Platform Microsoft SQL Server UI Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql (1.0.2.v201002041100) "Eclipse Data Tools Platform MySQL Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.dbdefinition (1.0.4.v200906161800) "Eclipse Data Tools Platform MySQL Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform MySQL UI Plug-in" [Starting]
org.eclipse.datatools.enablement.oda.ws (1.2.2.v201001131420) "Eclipse Data Tools Platform Web Services ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.ws.ui (1.2.2.v201005241330) "Eclipse Data Tools Platform Web Services ODA Designer" [Starting]
org.eclipse.datatools.enablement.oda.xml (1.2.1.v201001151620) "Eclipse Data Tools Platform XML ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.xml.ui (1.2.1.v201005241330) "Eclipse Data Tools Platform XML ODA Designer" [Starting]
org.eclipse.datatools.enablement.oracle (1.0.0.v200908130544) "Eclipse Data Tools Platform Oracle Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.dbdefinition (1.0.101.v201004211630) "Eclipse Data Tools Platform Oracle Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.ui (1.0.2.v201005051303) "Eclipse Data Tools Platform Oracle UI Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql (1.0.1.v200906020900) "PostgreSQL Connection Profile and Driver Template Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql.dbdefinition (1.0.1.v200906161800) "PostgreSQL DB Definition" [Starting]
org.eclipse.datatools.enablement.postgresql.ui (1.0.0.v200906020900) "PostgreSQL Connection Profile and Driver Template UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb (1.0.0.v200906020900) "Eclipse Data Tools Platform MaxDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform MaxDB Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform MaxDB UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite (1.0.0.v201002041100) "Eclipse Data Tools Platform SQLite Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite.dbdefinition (1.0.1.v201002041100) "Eclipse Data Tools Platform SQLite Database Definition Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform SQLite UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase (1.0.1.v200906020900) "High-level Sybase Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa (1.0.1.v200906020900) "Sybase ASA Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform Sybase ASA Database Definition" [Starting]
org.eclipse.datatools.enablement.sybase.asa.models (1.0.0.v200906020900) "Sybase ASA SQL Model" [Starting]
org.eclipse.datatools.enablement.sybase.asa.schemaobjectedit or.examples (2.5.0.200810071) "Sybase ASA Schema Object Editor" [Starting]
org.eclipse.datatools.enablement.sybase.asa.ui (1.0.1.v200906111150) "Sybase ASA Connection Profile UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase (1.0.1.v200906020900) "JDBC/Sybase ASE Connection Profile Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform Sybase ASE Database Definition" [Starting]
org.eclipse.datatools.enablement.sybase.ase.models (1.0.1.v200906020900) "Sybase ASE Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.ui (1.0.1.v200906020900) "ASE Enablement UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.models (1.0.0.v200906020900) "Sybase Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ui (1.0.0.v200906090458) "Sybase UI Plug-in" [Starting]
org.eclipse.datatools.help (1.5.0.v200906020553) "Data Tools Platform Help Utilities" [Resolved]
org.eclipse.datatools.modelbase.dbdefinition (1.0.2.v201002130228) "Eclipse Data Tools Platform DBDefinition Model" [Starting]
org.eclipse.datatools.modelbase.derby (1.0.0.v201002161452) "Eclipse Data Tools Platform Derby Model Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql (1.0.4.v201002250945) "Eclipse Data Tools Platform SQLModel Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.edit (1.0.1.v201002161452) "Eclipse Data Tools Platform SQLModel Edit Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.query (1.1.0.v201005202045) "Eclipse Data Tools Platform SQL Query Model Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.query.edit (1.0.0.v200906022249) "SQL Query Edit Support Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.xml.query (1.0.1.v201004291415) "Eclipse Data Tools Platform SQL XML Query Model Plugin" [Starting]
org.eclipse.datatools.oda.cshelp (1.1.1.v200907031118) "DTP ODA Context-sensitive Help" [Starting]
org.eclipse.datatools.sqltools.common.ui (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Tools Common UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.data.core (1.2.0.v201005241300) "Data Core Plugin" [Starting]
org.eclipse.datatools.sqltools.data.ui (1.2.0.v201005250945) "Data UI Plugin" [Starting]
org.eclipse.datatools.sqltools.db.derby (1.0.0.v200906020900) "Eclipse Data Tools Platform Derby SQL Tools Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.derby.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform Derby SQL Tools UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic (1.0.0.v200906020900) "Eclipse Data Tools Platform SQL Tools Generic Database Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform SQL Tools Generic Database UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.ddlgen.ui (1.0.1.v201002270530) "Eclipse Data Tools Platform FE UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.debugger.core (1.0.1.v201005250945) "Eclipse Data Tools Platform SQL Debugger Framework" [Starting]
org.eclipse.datatools.sqltools.debugger.core.ui (1.0.0.v201003161000) "Eclipse Data Tools Platform SQL Debugger UI Framework" [Starting]
org.eclipse.datatools.sqltools.editor.core (1.0.0.v201001150815) "Eclipse Data Tools Platform SQL Editor Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.editor.core.ui (1.0.0.v201001150815) "Eclipse Data Tools Platform SQL Editor Core UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql (1.0.2.v201004291415) "Eclipse Data Tools Platform SQL Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.lexer (1.0.1.v200906030654) "Eclipse Data Tools Platform Lexer Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.query (1.2.0.v201004291415) "Eclipse Data Tools Platform SQL Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.xml.query (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL XML Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.plan (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Execution Plan View Plug-in" [Starting]
org.eclipse.datatools.sqltools.result (1.1.0.v201005260930) "Eclipse Data Tools Platform SQL Results View Plug-ins" [Starting]
org.eclipse.datatools.sqltools.result.ui (1.1.0.v201005261700) "Eclipse Data Tools Platform SQL Results View UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor (1.0.0.v201003161000) "Eclipse Data Tools Platform SQL Tools Routine Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor.ui (1.0.1.v201004060545) "Eclipse Data Tools Platform SQL Tools Routine Editor UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.schemaobjecteditor (1.1.0.v200906022302) "Schema Object Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.schemaobjecteditor.ui (1.1.1.200810071) "Schema Object Editor Framework" [Starting]
org.eclipse.datatools.sqltools.schemaobjecteditor.ui.pages (1.1.0.200810071) "Schema Object Editor Pages Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql.ui (1.0.0.v200906022302) "Eclipse Data Tools Platform SQL Core UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.sqlbuilder (1.0.1.v201005260600) "SQL Builder" [Starting]
org.eclipse.datatools.sqltools.sqleditor (1.0.1.v201005130745) "Eclipse Data Tools Platform SQL Editor" [Starting]
org.eclipse.datatools.sqltools.sqlscrapbook (1.0.1.v201005250945) "Eclipse Data Tools Platform Sqlscrapbook Plug-in" [Starting]
org.eclipse.datatools.sqltools.tabledataeditor (1.0.1.v201005250945) "Eclipse Data Tools Platform Table Data Editor Plug-in" [Starting]
org.eclipse.debug.core (3.6.0.v20100122) "Debug Core" [Active]
org.eclipse.debug.ui (3.6.0.v20100127-1300) "Debug UI" [Starting]
org.eclipse.draw2d (3.6.0.v20100525-1225) "Graphical Editing Framework Draw2d" [Starting]
org.eclipse.ecf (3.1.0.v20100125-1515) "Eclipse Communication Framework (ECF)" [Starting]
org.eclipse.ecf.filetransfer (3.1.0.v20100125-1515) "ECF Filetransfer API" [Active]
org.eclipse.ecf.identity (3.1.0.v20100125-1515) "ECF Identity API" [Starting]
org.eclipse.ecf.provider.filetransfer (3.0.1.v20100125-1515) "ECF Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.httpclient (4.0.0.v20100125-1515) "ECF HttpClient Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.httpclient.ssl (1.0.0.v20100125-1515) "ECF HttpClient Filetransfer Provider" [Resolved]
org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20100125-1515) "ECF Filetransfer Provider" [Resolved]
org.eclipse.ecf.ssl (1.0.0.v20100125-1515) "Eclipse Communication Framework (ECF)" [Resolved]
org.eclipse.emf (2.6.0.v20100607-0756) "EMF - Eclipse Modeling Framework Runtime and Tools" [Starting]
org.eclipse.emf.ant (2.6.0.v20100521-1846) "EMF Ant Tasks" [Starting]
org.eclipse.emf.codegen (2.6.0.v20100607-0756) "EMF Code Generation" [Starting]
org.eclipse.emf.codegen.ecore (2.6.0.v20100607-0756) "EMF Ecore Code Generator" [Starting]
org.eclipse.emf.codegen.ecore.ui (2.6.0.v20100607-0756) "EMF Ecore Code Generator UI" [Starting]
org.eclipse.emf.codegen.ui (2.6.0.v20100607-0756) "EMF Code Generation UI" [Starting]
org.eclipse.emf.common (2.6.0.v20100607-0756) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.6.0.v20100607-0756) "EMF Common UI" [Starting]
org.eclipse.emf.converter (2.5.0.v20100607-0756) "EMF Model Converter" [Starting]
org.eclipse.emf.databinding (1.2.0.v20100607-0756) "EMF Data Binding" [Starting]
org.eclipse.emf.databinding.edit (1.2.0.v20100607-0756) "EMF Edit Data Binding" [Starting]
org.eclipse.emf.ecore (2.6.0.v20100607-0756) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.5.0.v20100521-1846) "EMF Change Model" [Starting]
org.eclipse.emf.ecore.change.edit (2.5.0.v20100521-1846) "EMF Change Edit" [Starting]
org.eclipse.emf.ecore.edit (2.6.0.v20100607-0756) "EMF Ecore Edit" [Starting]
org.eclipse.emf.ecore.editor (2.6.0.v20100607-0756) "EMF Sample Ecore Editor" [Starting]
org.eclipse.emf.ecore.xmi (2.5.0.v20100521-1846) "EMF XML/XMI Persistence" [Active]
org.eclipse.emf.edit (2.6.0.v20100607-0756) "EMF Edit" [Starting]
org.eclipse.emf.edit.ui (2.6.0.v20100607-0756) "EMF Edit UI" [Starting]
org.eclipse.emf.exporter (2.6.0.v20100521-1846) "EMF Model Exporter" [Starting]
org.eclipse.emf.importer (2.6.0.v20100521-1846) "EMF Model Importer" [Starting]
org.eclipse.emf.importer.ecore (2.6.0.v20100521-1846) "EMF Ecore Importer" [Starting]
org.eclipse.emf.importer.java (2.6.0.v20100521-1846) "EMF Annotated Java Importer" [Starting]
org.eclipse.emf.importer.rose (2.6.0.v20100521-1846) "EMF Rose Importer" [Starting]
org.eclipse.emf.mapping (2.6.0.v20100607-0756) "EMF Mapping" [Starting]
org.eclipse.emf.mapping.ecore (2.6.0.v20100607-0756) "EMF Ecore Mapping" [Starting]
org.eclipse.emf.mapping.ecore.editor (2.6.0.v20100607-0756) "EMF Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2ecore (2.5.0.v20100521-1847) "EMF Ecore to Ecore Mapping" [Starting]
org.eclipse.emf.mapping.ecore2ecore.editor (2.4.0.v20100521-1847) "EMF Ecore to Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2xml (2.5.0.v20100521-1847) "EMF Ecore to XML Mapping" [Starting]
org.eclipse.emf.mapping.ecore2xml.ui (2.5.0.v20100521-1847) "EMF Ecore to XML Mapping Editor" [Starting]
org.eclipse.emf.mapping.ui (2.6.0.v20100607-0756) "EMF Mapping UI" [Starting]
org.eclipse.equinox.app (1.3.0.v20100108) "Equinox Application Container" [Active]
org.eclipse.equinox.common (3.6.0.v20100125) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.concurrent (1.0.0.v20090520-1800) "Equinox Concurrent API" [Starting]
org.eclipse.equinox.ds (1.2.0.v20100125) "Declarative Services" [Active]
org.eclipse.equinox.event (1.2.0.v20100108) "Event Admin" [Active]
org.eclipse.equinox.frameworkadmin (1.0.200.v20100123-1019) "Equinox Framework Admin" [Active]
org.eclipse.equinox.frameworkadmin.equinox (1.0.200.v20100123-1019) "Equinox Framework Admin for Equinox" [Starting]
org.eclipse.equinox.http.jetty (2.0.0.v20090520-1800) "Jetty Http Service" [Starting]
org.eclipse.equinox.http.registry (1.1.0.v20100108) "Http Service Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.1.0.v20100108) "Http Services Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.200.v20090520-1800) "Jasper Jsp Support Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.100.v20090520-1800) "Jasper Jsp Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.1.0.v20100118) "Equinox Launcher" [Resolved]
org.eclipse.equinox.launcher.gtk.linux.x86 (1.1.0.v20100108) "Equinox Launcher Linux X86 Fragment" [Resolved]
org.eclipse.equinox.p2.artifact.repository (1.0.100.v20100123-1019) "Equinox Provisioning Artifact Repository Support" [Active]
org.eclipse.equinox.p2.console (1.0.100.v20100123-1019) "Equinox Provisioning Console" [Starting]
org.eclipse.equinox.p2.core (2.0.0.v20100123-1019) "Equinox Provisioning Core" [Active]
org.eclipse.equinox.p2.director (1.0.100.v20100123-1019) "Equinox Provisioning Director" [Active]
org.eclipse.equinox.p2.director.app (1.0.200.v20100124-0834) "Equinox Provisioning Director Application" [Starting]
org.eclipse.equinox.p2.directorywatcher (1.0.100.v20100123-1019) "Equinox Provisioning Directory Watcher" [Active]
org.eclipse.equinox.p2.engine (2.0.0.v20100127-1500) "Equinox Provisioning Engine" [Active]
org.eclipse.equinox.p2.exemplarysetup (1.0.100.v20100123-1019) "Equinox Provisioning Exemplary Setup" [Active]
org.eclipse.equinox.p2.extensionlocation (1.0.100.v20100123-1019) "Extension Location Repository Support" [Active]
org.eclipse.equinox.p2.garbagecollector (1.0.100.v20100123-1019) "Provisioning Garbage Collector" [Active]
org.eclipse.equinox.p2.jarprocessor (1.0.200.v20100123-1019) "Equinox Provisioning JAR Processor" [Resolved]
org.eclipse.equinox.p2.metadata (2.0.0.v20100127-1500) "Equinox Provisioning Metadata" [Active]
org.eclipse.equinox.p2.metadata.generator (1.0.200.v20100123-1019) "Equinox Provisioning Metadata Generator" [Starting]
org.eclipse.equinox.p2.metadata.repository (1.1.0.v20100123-1019) "Equinox Provisioning Metadata Repository" [Active]
org.eclipse.equinox.p2.operations (2.0.0.v20100124-0834) "Equinox Provisioning Update Checker" [Active]
org.eclipse.equinox.p2.publisher (1.1.0.v20100126) "Equinox Provisioning Publisher" [Active]
org.eclipse.equinox.p2.ql (1.0.0.v20100127-1500) "P2ql Model" [Starting]
org.eclipse.equinox.p2.reconciler.dropins (1.0.100.v20100123-1019) "Dropin Reconciler Plug-in" [Active]
org.eclipse.equinox.p2.repository (2.0.0.v20100127-1500) "Equinox Provisioning Repository" [Active]
org.eclipse.equinox.p2.repository.tools (1.0.100.v20100123-1019) "Equinox p2 repository tools." [Starting]
org.eclipse.equinox.p2.touchpoint.eclipse (2.0.0.v20100124-0834) "Equinox Provisioning Eclipse Touchpoint" [Active]
org.eclipse.equinox.p2.touchpoint.natives (1.0.200.v20100123-1019) "Equinox Provisioning Native Touchpoint" [Starting]
org.eclipse.equinox.p2.ui (2.0.0.v20100126-1839) "Equinox Provisioning UI Support" [Active]
org.eclipse.equinox.p2.ui.sdk (1.0.100.v20100124-0834) "Equinox Provisioning Platform Update Support" [Active]
org.eclipse.equinox.p2.ui.sdk.scheduler (1.0.0.v20100124-0834) "Equinox Provisioning Platform Automatic Update Support" [Active]
org.eclipse.equinox.p2.updatechecker (1.1.0.v20100123-1019) "Equinox Provisioning Update Checker" [Active]
org.eclipse.equinox.p2.updatesite (1.0.200.v20100127-1543) "Update site repository adapter bundle (Incubation)" [Starting]
org.eclipse.equinox.preferences (3.3.0.v20100121) "Eclipse Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.5.0.v20091203) "Extension Registry Support" [Active]
org.eclipse.equinox.security (1.0.200.v20100125) "Equinox Java Authentication and Authorization Service (JAAS)" [Active]
org.eclipse.equinox.security.ui (1.0.200.v20090928) "Equinox Security Default UI" [Starting]
org.eclipse.equinox.simpleconfigurator (1.0.200.v20100123-1019) "Simple Configurator" [Active]
org.eclipse.equinox.simpleconfigurator.manipulator (1.0.200.v20100123-1019) "Simple Configurator Manipulator" [Active]
org.eclipse.equinox.util (1.0.100.v20090520-1800) "Equinox Util Bundle" [Active]
org.eclipse.gef (3.6.0.v20100525-1225) "Graphical Editing Framework GEF" [Starting]
org.eclipse.help (3.5.0.v20100120) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.400.v20090429_1800) "Help Application Server" [Starting]
org.eclipse.help.base (3.5.0.v201001291300) "Help System Base" [Starting]
org.eclipse.help.ui (3.5.0.v20100126) "Help System UI" [Starting]
org.eclipse.help.webapp (3.5.0.v20100111) "Help System Webapp" [Starting]
org.eclipse.hyades.execution (4.5.0.v201005071900) "TPTP Platform Execution Plug-In" [Starting]
org.eclipse.hyades.execution.correlation (4.2.0.v201005061600) "Hyades Runtime Correlation Engine" [Resolved]
org.eclipse.hyades.execution.trace (4.2.0.v201005061600) "Hyades Execution Trace" [Resolved]
org.eclipse.hyades.logging.core (4.4.0.v201005061600) "Hyades Logging Agent, Common Base Events and Logging Facility Support" [Starting]
org.eclipse.hyades.logging.core.sample (4.2.0.v201005061600) "Sample for Hyades Logging Agent, Common Base Events and Logging Facility Support" [Starting]
org.eclipse.hyades.probekit (4.3.0.v201006071900) "Hyades Probekit" [Starting]
org.eclipse.hyades.probekit.doc.user (4.3.0.v201005212338) "Probekit User Documentation" [Starting]
org.eclipse.hyades.probekit.ui (4.1.600.v201005221043) "Probe Editor" [Starting]
org.eclipse.hyades.trace.ui (4.5.100.v201005311900) "Hyades Trace Core UI" [Starting]
org.eclipse.hyades.trace.views (4.1.700.v201006021900) "Hyades Trace Views Plugin" [Starting]
org.eclipse.hyades.ui (4.3.0.v201005181900) "Hyades UI" [Starting]
org.eclipse.jdt (3.6.0.v201001291300) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.apt.core (3.3.400.v20091203-0315) "Java Annotation Processing Core" [Active]
org.eclipse.jdt.apt.pluggable.core (1.0.300.v20090922-0135) "Java Compiler Apt IDE" [Active]
org.eclipse.jdt.apt.ui (3.3.300.v20091027-0900) "Java Annotation Processing UI" [Starting]
org.eclipse.jdt.compiler.apt (1.0.300.v20091027-0900) "Java Compiler Apt" [Resolved]
org.eclipse.jdt.compiler.tool (1.0.100.v_A32a) "Java Compiler Tool Support" [Resolved]
org.eclipse.jdt.core (3.6.0.v_A32a) "Java Development Tools Core" [Active]
org.eclipse.jdt.core.manipulation (1.3.0.v20100124-2000) "Java Code Manipulation Functionality" [Active]
org.eclipse.jdt.debug (3.6.0.v20100111) "JDI Debug Model" [Starting]
org.eclipse.jdt.debug.ui (3.5.0.v20100127-1800) "JDI Debug UI" [Starting]
org.eclipse.jdt.doc.isv (3.6.0.v20100127-1230) "Eclipse JDT Plug-in Developer Guide" [Resolved]
org.eclipse.jdt.doc.user (3.6.0.v20100124-2000) "Eclipse Java development user guide" [Resolved]
org.eclipse.jdt.junit (3.6.0.v20100125-1300) "Java Development Tools JUnit support" [Starting]
org.eclipse.jdt.junit.core (3.6.0.v20100124-2000) "Java Development Tools JUnit core support" [Starting]
org.eclipse.jdt.junit.runtime (3.4.200.v20100124-2000) "Java Development Tools JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.1.100.v20100124-2000) "Java Development Tools JUnit4 runtime support" [Resolved]
org.eclipse.jdt.launching (3.5.100.v20100104) "Java Development Tools Launching Support" [Active]
org.eclipse.jdt.ui (3.6.0.v20100127-0100) "Java Development Tools UI" [Active]
org.eclipse.jem (2.0.400.v201005110200) "Java EMF Model" [Active]
org.eclipse.jem.beaninfo (2.0.300.v200905030615) "Java EMF Model BeanInfo (Introspection) Support" [Starting]
org.eclipse.jem.beaninfo.vm (2.0.300.v201004110600) "JEM Beaninfo VM Jar" [Resolved]
org.eclipse.jem.beaninfo.vm.common (2.0.300.v201004110600) "JEM Beaninfo Common Jar" [Resolved]
org.eclipse.jem.proxy (2.0.300.v201006080510) "Java EMF Model Proxy Support" [Starting]
org.eclipse.jem.util (2.1.0.v201005130500) "Java EMF Model Utilities" [Active]
org.eclipse.jem.workbench (2.0.300.v200910290230) "Java EMF Model Workbench Support" [Active]
org.eclipse.jface (3.6.0.I20100122-0800) "JFace" [Active]
org.eclipse.jface.databinding (1.4.0.I20100125-1345) "JFace Data Binding for SWT and JFace" [Resolved]
org.eclipse.jface.text (3.6.0.v20100127-0100) "JFace Text" [Resolved]
org.eclipse.jpt.branding (2.3.0.v201003030000) "Dali Java Persistence Tools" [Resolved]
org.eclipse.jpt.core (2.3.0.v201006020000) "Dali Java Persistence Tools - Core" [Active]
org.eclipse.jpt.db (1.2.200.v201004290000) "Dali Java Persistence Tools - DB" [Starting]
org.eclipse.jpt.db.ui (1.1.200.v201003290000) "Dali Java Persistence Tools - DB UI" [Resolved]
org.eclipse.jpt.doc.user (1.3.0.v201006080000) "Dali Java Persistence Tools - Documentation" [Resolved]
org.eclipse.jpt.eclipselink.branding (2.3.0.v201001200000) "Dali Java Persistence Tools - EclipseLink Support" [Resolved]
org.eclipse.jpt.eclipselink.core (1.3.0.v201005250000) "Dali Java Persistence Tools - EclipseLink Support - Core" [Starting]
org.eclipse.jpt.eclipselink.core.ddlgen (1.0.300.v201003290000) "Dali Java Persistence Tools - EclipseLink Support - DDL Generation" [Resolved]
org.eclipse.jpt.eclipselink.jaxb.core.schemagen (1.0.0.v201005120000) "Dali Java Persistence Tools - EclipseLink JAXB Support - Schema Generation" [Resolved]
org.eclipse.jpt.eclipselink.ui (1.3.0.v201004280001) "Dali Java Persistence Tools - EclipseLink Support - UI" [Starting]
org.eclipse.jpt.gen (1.3.100.v201004260000) "Dali Java Persistence Tools - Entity Gen" [Resolved]
org.eclipse.jpt.jaxb.core.schemagen (1.0.0.v201005120000) "Dali Java Persistence Tools - JAXB Support - Schema Generation" [Resolved]
org.eclipse.jpt.jaxb.ui (1.0.0.v201006070001) "Dali Java Persistence Tools - JAXB Support - UI" [Starting]
org.eclipse.jpt.ui (2.3.0.v201005190001) "Dali Java Persistence Tools - UI" [Starting]
org.eclipse.jpt.utility (1.5.0.v201005100000) "Dali Java Persistence Tools - Utility" [Resolved]
org.eclipse.jsch.core (1.1.100.I20100112-0800) "JSch Core" [Active]
org.eclipse.jsch.ui (1.1.200.I20090825-0800) "JSch UI" [Starting]
org.eclipse.jsf.branding (3.2.0.v20100522) "JavaServer Faces Tools" [Resolved]
org.eclipse.jst.common.annotations.controller (1.1.300.v200908252030) "Annotation Controller Plug-in" [Resolved]
org.eclipse.jst.common.annotations.core (1.1.300.v201004141630) "Annotation Core Plug-in" [Resolved]
org.eclipse.jst.common.annotations.ui (1.1.300.v201002081900) "Annotations UI Plug-in" [Starting]
org.eclipse.jst.common.frameworks (1.1.400.v201005130500) "Integration Plug-in" [Active]
org.eclipse.jst.common.project.facet.core (1.4.100.v201004202202) "Eclipse Faceted Project Framework JDT Enablement" [Active]
org.eclipse.jst.common.project.facet.ui (1.4.100.v201005171604) "Eclipse Faceted Project Framework JDT Enablement UI" [Starting]
org.eclipse.jst.common.ui (1.0.0.v201005270700) "Common JST UI Plug-in" [Starting]
org.eclipse.jst.ejb.doc.user (1.1.200.v20100519) "EJB docs" [Starting]
org.eclipse.jst.ejb.ui (1.1.500.v201004280901) "WTP EJB UI Plug-in" [Starting]
org.eclipse.jst.ejb.ui.infopop (1.0.300.v2010022311013) "EJB infopop" [Starting]
org.eclipse.jst.j2ee (1.1.400.v201005271900) "Java EE Component" [Active]
org.eclipse.jst.j2ee.core (1.2.0.v201005200200) "J2EE Core Component" [Active]
org.eclipse.jst.j2ee.doc.user (1.1.200.v201005192219) "J2EE tools documentation" [Resolved]
Re: Error loading Task view Eclipse 3.6, Mylyn [message #601981 is a reply to message #554864] |
Hi Steffen,
linux
-ws
gtk
-arch
x86
-showsplash
-launcher
-name
Eclipse
--launcher.library
-startup
-vm
-Xms40m
-Xmx1024m
equinox.use.ds=true
file.encoding=UTF-8
file.separator=/
java.io.tmpdir=/tmp
line.separator=
os.arch=i386
os.name=Linux
osgi.arch=x86
osgi.bundles=reference:file:mailto: org.eclipse.equinox.simpleconfigurator_1.0.200.v20100123-101 9.jar @1:start
osgi.nl=en_GB
osgi.os=linux
osgi.ws=gtk
path.separator=:
sun.cpu.isalist=
sun.desktop=gnome
user.country=GB
user.dir=/home/joel
user.language=en
user.name=joel
*** Features:
Current Time: Wed Jul 23 08:01:34 EDT 2025
Powered by FUDForum. Page generated in 0.23879 seconds
