teneo: Yet another DuplicateMappingException problem [message #601876] |
Wed, 31 January 2007 16:42 |
I too am having a problem with a Duplicate<appingException being thrown. I have added the QUALIFY_ENTITY_NAME property with the value QUALIFY_ENTITY_NAME_NSPREFIX and still get the duplicate mapping exception. The complete exception trace is:
Exception in thread "main" org.hibernate.DuplicateMappingException: duplicate import: InterfaceCard refers to both cisco3800.InterfaceCard and types.InterfaceCard (try using auto-import="false")
at org.hibernate.cfg.Mappings.addImport(Mappings.java:141)
at org.hibernate.cfg.HbmBinder.bindPersistentClassCommonValues( HbmBinder.java:614)
at org.hibernate.cfg.HbmBinder.bindClass(HbmBinder.java:527)
at org.hibernate.cfg.HbmBinder.bindJoinedSubclass(HbmBinder.jav a:848)
at org.hibernate.cfg.HbmBinder.handleJoinedSubclass(HbmBinder.j ava:2202)
at org.hibernate.cfg.HbmBinder.bindRoot(HbmBinder.java:153)
at org.hibernate.cfg.Configuration.add(Configuration.java:424)
at org.hibernate.cfg.Configuration.addXML(Configuration.java:38 4)
at org.eclipse.emf.teneo.hibernate.HbDataStore.mapModel(HbDataS tore.java:364)
at org.eclipse.emf.teneo.hibernate.HbDataStore.initialize(HbDat aStore.java:156)
at org.ziptie.cisco.cs3800Load.doLoadDoc(cs3800Load.java:63)
There are two XSDs (one included by the other) with different namespaces, each with a type definition for InterfaceCard. The including XSD extends the type of the included namespace. When I look at the mapping, the entity-name fields are unique (they have the namespaces prefixed) and the descriminator fields are unique (again, the namespace is prefixed). In fact, everything is unique with the exception of the meta tag for "eclassName" - they are both InterfaceCard without any namespace prefixes.
I tried both the default and the "JOINED" Inheritance mapping strategies and both result in the same exception although the mappings are obviously a bit different. Here is the mapping for these types using the default inheritance strategy:
<subclass entity-name="types.InterfaceCard" abstract="false" lazy="false" extends="types.Card" discriminator-value="types.InterfaceCard">
<meta attribute="eclassName">InterfaceCard</meta>
<meta attribute="epackage">http://www.ziptie.org/1.0/zipTypes</meta>
<list name="port" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`interfacecard_port_id`" not-null="false" unique="false"/>
</key>
<list-index column="`interfacecard_port_idx`"/>
<one-to-many entity-name="types.Port"/>
</list>
</subclass>
<subclass entity-name="cisco3800.InterfaceCard" abstract="false" lazy="false" extends="types.InterfaceCard" discriminator-value="cisco3800.InterfaceCard">
<meta attribute="epackage">http://www.ziptie.org/cisco3800</meta>
<property name="icType" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`ictype`"/>
<type name="org.eclipse.emf.teneo.hibernate.mapping.ENumUserType" >
<param name="enumClass">org.ziptie.cisco3800.IcTypeType</param>
</type>
</property>
</subclass>
And here is the mapping for the JOINED strategy:
<joined-subclass entity-name="types.InterfaceCard" abstract="false" lazy="false" extends="types.Card" table="`interfacecard`">
<key>
<column name="`card_id`"/>
</key>
<key update="true">
</key>
</list>
</joined-subclass>
<joined-subclass entity-name="cisco3800.InterfaceCard" abstract="false" lazy="false" extends="types.InterfaceCard" table="`interfacecard`">
<key>
<column name="`interfacecard_id`"/>
</key>
</type>
</property>
</joined-subclass>
Like the default inheritance strategy, the entity-names are unique and the meta attribute eclassName is not. However, note that the table names are the same. That is probably bad mojo.
Outside of hand editing the generated hbm file, is there some other way to fix or control this behavior?
Brian
FUDForum. Page generated in 0.03277 seconds
