| Re: Teneo: It is impossible to specify queries order for Hibernate resource [message #68395 is a reply to message #68387] |
Fri, 19 January 2007 11:10  |
Ilya,
What happens is the following: the parameters in the queryset (of the uri) are put in a hashmap
(keyed on parameter name). The getqueries method then retrieves the query parameters from the
hashmap. I can change this by using a treemap instead of a hashmap. This is a small change and will
make the retrieval order of the queries more deterministic (in order of their parameter name).
Please enter a bugzilla for this as well.
Btw you can override getqueries to implement this yourselve for now.
gr. Martin
Ed Merks wrote:
> Ilya,
> Not that I know any of the details, but perhaps if a LinkedHashSet were
> used, the order would be more deterministic...
> Ilya Klyuchnikov wrote:
>> I load very big model from db.
>> I have optimized the queries (and their order) for loading model. But
>> HibernateResource is agnostic to query order cause when it parses URI
>> it puts queries into HashSet and then cannot restore order of queries.
>> Can it be solved?
>> Thanks
>> Ilya
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: Teneo: It is impossible to specify queries order for Hibernate resource [message #601411 is a reply to message #68367] |
Fri, 19 January 2007 09:29  |
Ilya,
> Can it be solved?
> Thanks
> Ilya
| Re: Teneo: It is impossible to specify queries order for Hibernate resource [message #601413 is a reply to message #68387] |
Ilya,
gr. Martin
Ed Merks wrote:
> Ilya,
>> Can it be solved?
>> Thanks
>> Ilya
The Netherlands
FUDForum. Page generated in 0.09263 seconds
