"Property marker value too long" exception during build [message #601077] |
Mon, 28 June 2010 05:29  |
Has anyone seen this error? I started getting last week, it occurs during a build, and causes the build to fail. I've provided the full stack trace at the bottom of this post.
I suspect I'm getting a build failure in my project; and AJDT is throwing an internal error when trying to log/display it because the classpath is too large...
The project itself is not especially large, but it does have around 120 dependencies for Spring, Hibernate, CXF, etc.
I'm not sure what to do from here, beyond uninstalling AJDT completely. Any ideas for work-arounds?
org.eclipse.core.runtime.AssertionFailedException: assertion failed: Marker property value is too long: Building with settings:
-> output paths: /home/sean/Documents/MarketPlace/src/target/classes, /home/sean/Documents/MarketPlace/src/target/test-classes
-> classpath: /home/sean/Documents/MarketPlace/src/target/test-classes:/ho me/sean/Documents/MarketPlace/src/target/classes:/home/sean/ .m2/repository/javax/activation/activation/1.1.1/activation- 1.1.1.jar:/home/sean/.m2/repository/javax/persistence/com.sp ringsource.javax.persistence/1.0.0/com.springsource.javax.pe rsistence-1.0.0.jar:/home/sean/.m2/repository/javax/servlet/ com.springsource.javax.servlet/2.5.0/com.springsource.javax. servlet-2.5.0.jar:/home/sean/.m2/repository/javax/servlet/co m.springsource.javax.servlet.jsp.jstl/1.2.0/com.springsource .javax.servlet.jsp.jstl-1.2.0.jar:/home/sean/.m2/repository/ javax/transaction/com.springsource.javax.transaction/1.1.0/c om.springsource.javax.transaction-1.1.0.jar:/home/sean/.m2/r epository/javax/validation/com.springsource.javax.validation /1.0.0.GA/com.springsource.javax.validation-1.0.0.GA.jar:/ho me/sean/.m2/repository/javax/xml/bind/jaxb-api/2.1/jaxb-api- 2.1.jar:/home/sean/.m2/repository/javax/transaction/jta/1.1/ jta-1.1.jar:/home/sean/.m2/repository/javax/mail/mail/1.4.1/ mail-1.4.1.jar:/home/sean/.m2/repository/javax/xml/soap/saaj -api/1.3/saaj-api-1.3.jar:/home/sean/.m2/repository/javax/xm l/stream/stax-api/1.0-2/stax-api-1.0-2.jar:/home/sean/.m2/re pository/antlr/antlr/2.7.6/antlr-2.7.6.jar:/home/sean/.m2/re pository/asm/asm/2.2.3/asm-2.2.3.jar:/home/sean/.m2/reposito ry/cglib/cglib-nodep/2.1_3/cglib-nodep-2.1_3.jar:/home/sean/ .m2/repository/org/antlr/com.springsource.antlr/2.7.6/com.sp ringsource.antlr-2.7.6.jar:/home/sean/.m2/repository/com/mys ql/jdbc/com.springsource.com.mysql.jdbc/5.1.6/com.springsour ce.com.mysql.jdbc-5.1.6.jar:/home/sean/.m2/repository/edu/em ory/mathcs/backport/com.springsource.edu.emory.mathcs.backpo rt/3.1.0/com.springsource.edu.emory.mathcs.backport-3.1.0.ja r:/home/sean/.m2/repository/edu/oswego/cs/concurrent/com.spr ingsource.edu.oswego.cs.dl.util.concurrent/1.3.4/com.springs ource.edu.oswego.cs.dl.util.concurrent-1.3.4.jar:/home/sean/ .m2/repository/org/jboss/javassist/com.springsource.javassis t/3.3.0.ga/com.springsource.javassist-3.3.0.ga.jar:/home/sea n/.m2/repository/net/sourceforge/cglib/com.springsource.net. sf.cglib/2.1.3/com.springsource.net.sf.cglib-2.1.3.jar:/home /sean/.m2/repository/net/sourceforge/ehcache/com.springsourc e.net.sf.ehcache/1.4.1/com.springsource.net.sf.ehcache-1.4.1 .jar:/home/sean/.m2/repository/net/sourceforge/jsr107cache/c om.springsource.net.sf.jsr107cache/1.0.0/com.springsource.ne t.sf.jsr107cache-1.0.0.jar:/home/sean/.m2/repository/org/aop alliance/com.springsource.org.aopalliance/1.0.0/com.springso urce.org.aopalliance-1.0.0.jar:/home/sean/.m2/repository/org /apache/commons/com.springsource.org.apache.commons.beanutil s/1.8.0/com.springsource.org.apache.commons.beanutils-1.8.0. jar:/home/sean/.m2/repository/org/apache/commons/com.springs ource.org.apache.commons.collections/3.2.0/com.springsource. org.apache.commons.collections-3.2.0.jar:/home/sean/.m2/repo sitory/org/apache/commons/com.springsource.org.apache.common s.dbcp/1.2.2.osgi/com.springsource.org.apache.commons.dbcp-1 .2.2.osgi.jar:/home/sean/.m2/repository/org/apache/commons/c om.springsource.org.apache.commons.digester/1.8.1/com.spring source.org.apache.commons.digester-1.8.1.jar:/home/sean/.m2/ repository/org/apache/commons/com.springsource.org.apache.co mmons.fileupload/1.2.0/com.springsource.org.apache.commons.f ileupload-1.2.0.jar:/home/sean/.m2/repository/org/apache/com mons/com.springsource.org.apache.commons.io/1.4.0/com.spring source.org.apache.commons.io-1.4.0.jar:/home/sean/.m2/reposi tory/org/apache/commons/com.springsource.org.apache.commons. logging/1.1.1/com.springsource.org.apache.commons.logging-1. 1.1.jar:/home/sean/.m2/repository/org/apache/commons/com.spr ingsource.org.apache.commons.pool/1.3.0/com.springsource.org .apache.commons.pool-1.3.0.jar:/home/sean/.m2/repository/org /apache/el/com.springsource.org.apache.el/6.0.20/com.springs ource.org.apache.el-6.0.20.jar:/home/sean/.m2/repository/org /apache/log4j/com.springsource.org.apache.log4j/1.2.15/com.s pringsource.org.apache.log4j-1.2.15.jar:/home/sean/.m2/repos itory/org/apache/taglibs/com.springsource.org.apache.taglibs .standard/1.1.2/com.springsource.org.apache.taglibs.standard -1.1.2.jar:/home/sean/.m2/repository/org/apache/tiles/com.sp ringsource.org.apache.tiles/2.1.3/com.springsource.org.apach e.tiles-2.1.3.jar:/home/sean/.m2/repository/org/apache/tiles /com.springsource.org.apache.tiles.core/2.1.3/com.springsour ce.org.apache.tiles.core-2.1.3.jar:/home/sean/.m2/repository /org/apache/tiles/com.springsource.org.apache.tiles.jsp/2.1. 3/com.springsource.org.apache.tiles.jsp-2.1.3.jar:/home/sean /.m2/repository/org/apache/tiles/com.springsource.org.apache .tiles.servlet/2.1.3/com.springsource.org.apache.tiles.servl et-2.1.3.jar:/home/sean/.m2/repository/org/dom4j/com.springs ource.org.dom4j/1.6.1/com.springsource.org.dom4j-1.6.1.jar:/ home/sean/.m2/repository/org/hibernate/com.springsource.org. hibernate/3.2.6.ga/com.springsource.org.hibernate-3.2.6.ga.j ar:/home/sean/.m2/repository/org/hibernate/com.springsource. org.hibernate.annotations/3.3.1.ga/com.springsource.org.hibe rnate.annotations-3.3.1.ga.jar:/home/sean/.m2/repository/org /hibernate/com.springsource.org.hibernate.annotations.common /3.3.0.ga/com.springsource.org.hibernate.annotations.common- 3.3.0.ga.jar:/home/sean/.m2/repository/org/hibernate/com.spr ingsource.org.hibernate.ejb/3.3.2.GA/com.springsource.org.hi bernate.ejb-3.3.2.GA.jar:/home/sean/.m2/repository/org/hiber nate/com.springsource.org.hibernate.validator/4.0.0.GA/com.s pringsource.org.hibernate.validator-4.0.0.GA.jar:/home/sean/ .m2/repository/org/jboss/util/com.springsource.org.jboss.uti l/2.0.4.GA/com.springsource.org.jboss.util-2.0.4.GA.jar:/hom e/sean/.m2/repository/org/joda/com.springsource.org.joda.tim e/1.6.0/com.springsource.org.joda.time-1.6.0.jar:/home/sean/ .m2/repository/org/junit/com.springsource.org.junit/4.7.0/co m.springsource.org.junit-4.7.0.jar:/home/sean/.m2/repository /org/objectweb/asm/com.springsource.org.objectweb.asm/1.5.3/ com.springsource.org.objectweb.asm-1.5.3.jar:/home/sean/.m2/ repository/org/objectweb/asm/com.springsource.org.objectweb. asm.attrs/1.5.3/com.springsource.org.objectweb.asm.attrs-1.5 .3.jar:/home/sean/.m2/repository/org/tuckey/com.springsource .org.tuckey.web.filters.urlrewrite/3.1.0/com.springsource.or g.tuckey.web.filters.urlrewrite-3.1.0.jar:/home/sean/.m2/rep ository/org/slf4j/com.springsource.slf4j.api/1.5.6/com.sprin gsource.slf4j.api-1.5.6.jar:/home/sean/.m2/repository/org/sl f4j/com.springsource.slf4j.log4j/1.5.6/com.springsource.slf4 j.log4j-1.5.6.jar:/home/sean/.m2/repository/com/wave2/common /common/4.1/common-4.1.jar:/home/sean/.m2/repository/commons -codec/commons-codec/1.2/commons-codec-1.2.jar:/home/sean/.m 2/repository/commons-collections/commons-collections/3.2.1/c ommons-collections-3.2.1.jar:/home/sean/.m2/repository/commo ns-httpclient/commons-httpclient/3.1/commons-httpclient-3.1. jar:/home/sean/.m2/repository/commons-lang/commons-lang/2.5/ commons-lang-2.5.jar:/home/sean/.m2/repository/commons-loggi ng/commons-logging/1.1.1/commons-logging-1.1.1.jar:/home/sea n/.m2/repository/org/apache/cxf/cxf-api/2.2/cxf-api-2.2.jar: /home/sean/.m2/repository/org/apache/cxf/cxf-common-schemas/ 2.2/cxf-common-schemas-2.2.jar:/home/sean/.m2/repository/org /apache/cxf/cxf-common-utilities/2.2/cxf-common-utilities-2. 2.jar:/home/sean/.m2/repository/org/apache/cxf/cxf-rt-bindin gs-soap/2.2/cxf-rt-bindings-soap-2.2.jar:/home/sean/.m2/repo sitory/org/apache/cxf/cxf-rt-bindings-xml/2.2/cxf-rt-binding s-xml-2.2.jar:/home/sean/.m2/repository/org/apache/cxf/cxf-r t-core/2.2/cxf-rt-core-2.2.jar:/home/sean/.m2/repository/org /apache/cxf/cxf-rt-databinding-jaxb/2.2/cxf-rt-databinding-j axb-2.2.jar:/home/sean/.m2/repository/org/apache/cxf/cxf-rt- frontend-jaxws/2.2/cxf-rt-frontend-jaxws-2.2.jar:/home/sean/ .m2/repository/org/apache/cxf/cxf-rt-frontend-simple/2.2/cxf -rt-frontend-simple-2.2.jar:/home/sean/.m2/repository/org/ap ache/cxf/cxf-rt-transports-http/2.2/cxf-rt-transports-http-2 .2.jar:/home/sean/.m2/repository/org/apache/cxf/cxf-rt-ws-ad dr/2.2/cxf-rt-ws-addr-2.2.jar:/home/sean/.m2/repository/org/ apache/cxf/cxf-tools-common/2.2/cxf-tools-common-2.2.jar:/ho me/sean/.m2/repository/dom4j/dom4j/1.6.1/dom4j-1.6.1.jar:/ho me/sean/.m2/repository/org/hibernate/ejb3-persistence/1.0.2. GA/ejb3-persistence-1.0.2.GA.jar:/home/sean/.m2/repository/c om/google/code/facebookapi/facebook-java-api/3.0.2/facebook- java-api-3.0.2.jar:/home/sean/.m2/repository/com/google/code /facebookapi/facebook-java-api-annotation-processor/3.0.2/fa cebook-java-api-annotation-processor-3.0.2.jar:/home/sean/.m 2/repository/com/google/code/facebookapi/facebook-java-api-s chema/3.0.2/facebook-java-api-schema-3.0.2.jar:/home/sean/.m 2/repository/com/sun/xml/fastinfoset/FastInfoset/1.2.2/FastI nfoset-1.2.2.jar:/home/sean/.m2/repository/org/apache/geroni mo/specs/geronimo-activation_1.1_spec/1.0.2/geronimo-activat ion_1.1_spec-1.0.2.jar:/home/sean/.m2/repository/org/apache/ geronimo/specs/geronimo-annotation_1.0_spec/1.1.1/geronimo-a nnotation_1.0_spec-1.1.1.jar:/home/sean/.m2/repository/org/a pache/geronimo/specs/geronimo-javamail_1.4_spec/1.5/geronimo -javamail_1.4_spec-1.5.jar:/home/sean/.m2/repository/org/apa che/geronimo/specs/geronimo-jaxws_2.1_spec/1.0/geronimo-jaxw s_2.1_spec-1.0.jar:/home/sean/.m2/repository/org/apache/gero nimo/specs/geronimo-stax-api_1.0_spec/1.0.1/geronimo-stax-ap i_1.0_spec-1.0.1.jar:/home/sean/.m2/repository/org/apache/ge ronimo/specs/geronimo-ws-metadata_2.0_spec/1.1.2/geronimo-ws -metadata_2.0_spec-1.1.2.jar:/home/sean/.m2/repository/org/h amcrest/hamcrest-core/1.1/hamcrest-core-1.1.jar:/home/sean/. m2/repository/org/hamcrest/hamcrest-library/1.1/hamcrest-lib rary-1.1.jar:/home/sean/.m2/repository/org/hibernate/hiberna te-commons-annotations/3.1.0.GA/hibernate-commons-annotation s-3.1.0.GA.jar:/home/sean/.m2/repository/org/hibernate/hiber nate-core/3.3.1.GA/hibernate-core-3.3.1.GA.jar:/home/s
at org.eclipse.core.runtime.Assert.isTrue(Assert.java:110)
at org.eclipse.core.internal.resources.MarkerInfo.checkValidAtt ribute(MarkerInfo.java:63)
at org.eclipse.core.internal.resources.MarkerInfo.setAttribute( MarkerInfo.java:146)
at org.eclipse.core.internal.resources.Marker.setAttribute(Mark er.java:241)
at org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.setMessag e(UIMessageHandler.java:567)
at org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.access$7( UIMessageHandler.java:556)
at org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler$1.run(UIM essageHandler.java:318)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1782)
at org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.showMessa ges(UIMessageHandler.java:339)
at org.eclipse.ajdt.internal.ui.ajde.UIMessageHandler.showOutst andingProblems(UIMessageHandler.java:207)
at org.eclipse.ajdt.internal.builder.UIBuildListener.postAJBuil d(UIBuildListener.java:197)
at org.eclipse.ajdt.core.builder.AJBuilder.postCallListeners(AJ Builder.java:1352)
at org.eclipse.ajdt.core.builder.AJBuilder.build(AJBuilder.java :258)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:627)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:170)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:201)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:253)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:256)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:309)
at org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:341)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:140)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:238)
FUDForum. Page generated in 0.04692 seconds
